I've been considering using chrome vinyl wrap on this frame instead of nickel plating it, I know it's going to be a lot of work but I'm going to at least give it a shot. It's going to take a lot of finesse but I should be able to cut some corners where you cant really see the frame.
I found sulfur yellow 8oz and 12oz touch up paint and was going to order 5-6 cans of that, not sure what blue Ill use for the stripes. Airtech sells the belly pan I need and it just needs paint and the attachments straps they sell with it.
I have a laser tool at the shop but didn't have any triple A batteries, on Monday Ill put a smaller tire on the rear rim, and figure out the sprocket mods and start the new steering stops...I would like to get all the  fabrication done before I start throwing cheap paint on this things and decided which color scheme I'm going with.
So far:
Yellow: tank, belly pan, rear cowl, head light bucket, fairing, side covers, all with blue pinstripe, triple tree.
I might keep the wheels white with fresh paint....otherwise the wheels get painted yellow too, maybe blue or white rim stripes...not sure.
The blue tank doesnt look bad with the white wheels....
