I was lucky to find a problem in time for the ongoing head swap.
Oil feed diameter of the 2 holes in head were only 8.5mm!
Not good combination with Heavy duty studs that are 8.0mm thick. Not much for oil to flow there.
The oil restrictors at top have only +1mm hole, but only for max 20mm followed by the narrow holes in cam holders lubing cam and squirting oil over rocker pads etc.
Stock studs are slimmer, 6mm no problem with 8.5mm holes then.
I checked another head I have that was tight enough with 9.0mm.
I massaged all stud holes with 9.0mm drill after another head had married stud threads when alu collapsed a little.
I saw the ported head has meat enough for 9.5mm drill to ensure oil flow outside the thicker 8.0mm stud.
I think at least a 9mm drill is a good idea when going with HD studs.
Oil flow now closer to stock, the thinner 6.0mm studs vs the small 8.5mm holes.
8.0mm vs 9.5mm
This feels better.
I have not tested the flow, closer to stock oil channel is enough for me.
Lack of oil at top-end might not only be clogged oil restrictors or holes in cam holders.
My CX-cam had damaged ex lobes I noticed after I have changed to another cam.
Only the highest point, no scuff marks on head nor cam holder. I could never explain that.
Later cam got better oil and might have helped. Mostly synthetic Red Line.
CX-7 got low quality Castrol 10-40 mineral for break in. 20/50 later. Bad flow might have caused it?
HD studs and tight holes in head. See photo of which.
Understandble why RC made studs with thinner diameter on these 2 in head area.
