Author Topic: Bridgestone BT45s or Bridgestone Spitfire S11? Or something else?  (Read 9536 times)
Re: Bridgestone BT45s or Bridgestone Spitfire S11? Or something else?
« Reply #75 on: April 19, 2021, 06:16:01 AM »
Took a lot of weight to balance both tires
Hey Andy...I've run across this and have asked that the tire be rotated 180 degrees to reduce the weight.
The tires look good.  I've been shopping for a rear for my Z1, many online stores are out of stock on the 120/90-18
« Reply #76 on: April 19, 2021, 06:49:59 AM »
Stev-o there was no yellow/red dot on these tires so maybe that also added to it. Front took less weight than the rear
« Reply #77 on: April 19, 2021, 10:29:36 AM »
Easier to fit 120 than 130 with stock chain case.
My K6 had a 130 in the 80's when rear should be wide.
It was  OK since most use of it on long holiday with 2 persons and luggage 3000km away and 3000km back home, mostly high speed highways.
