Author Topic: Dewey’s CB750 K2  (Read 12329 times)
Re: Dewey’s CB750 K2
« Reply #50 on: April 26, 2022, 05:31:49 AM »
Too bad you cannot get Testors paint anymore
As in not locally like we could in the 60s and 70s??
https://www.michaels.com/testors-gloss-enamel-paint/M10060394.html
They totally killed their Testor's Model Masters FS color military paints in enamel and acrylic paint line...
Happened during pandemic...
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #51 on: August 24, 2022, 11:00:02 AM »
Get goin' slacker! :-)
I have a motorcycle problem.
Offline SanDogDewey
« Reply #52 on: October 04, 2022, 03:29:42 PM »
So it looks like the bike had a K0 front hub as it has a narrow shoulder. I replaced it with a later model wide shoulder hub. Do I just need a wider gear box retainer cover, or do I need additional parts? I'm guessing the black hub is a 44601-300-030 with a 44643-300-000 retainer.
« Last Edit: October 04, 2022, 03:40:59 PM by SanDogDewey »
Offline SanDogDewey
« Reply #53 on: October 04, 2022, 03:32:25 PM »
The cover will not fit over the wider hub.
Offline SanDogDewey
« Reply #54 on: October 04, 2022, 08:40:05 PM »
Low and behold in the "box 'o parts" that came with the bike, I found the correct piece!
Offline SanDogDewey
« Reply #55 on: October 05, 2022, 07:58:14 PM »
Finished lacing up rear wheel.
Offline SanDogDewey
« Reply #56 on: October 05, 2022, 07:59:15 PM »
I’m back on it!
Offline SanDogDewey
« Reply #57 on: October 05, 2022, 08:28:00 PM »
It's back on 2 wheels!
« Reply #58 on: October 06, 2022, 02:23:21 AM »
« Reply #59 on: October 06, 2022, 07:52:03 AM »
That's nice progress, looking great
Offline SanDogDewey
« Reply #60 on: October 06, 2022, 10:23:24 AM »
It looks like I'm back where I started. But forks have been rebuilt, both wheels respoked with cleared hubs, new fenders front and rear, new bars and controls, gauges rebuilt, new wiring harness, ignition and coils.
« Last Edit: February 16, 2023, 06:10:41 PM by SanDogDewey »
Offline SanDogDewey
« Reply #61 on: October 25, 2022, 05:46:05 PM »
Is there a "proper" way to torque the fork caps? Seems like I read something once about torquing the forward one first?
Got my gauges installed and my headlight bucket threw up a bunch of wires!
« Last Edit: October 25, 2022, 05:49:16 PM by SanDogDewey »
« Reply #62 on: October 25, 2022, 05:55:36 PM »
The K2 came both ways with the fork caps (hence the arguments...). Mine was made 11/71, and it had them "backward" [so says the internet today] right from the crate. The K2 that came after 3/72 build changes occurred (like, no more Stellite valve guides, new 3-piece piston rings, common clutch hub with 7 plates OEM) also had the fork caps on the other way, with the gaps at the back.
...but not always, out of their crates...so, look closely at yours to see if they are marked "F". If so, that side goes to the front, and torque down the side that meets the faces flush first, then the other one. If you have the early "F"-marked ones, you might also find that they like one fork better than the other side: some were hand-finished with a flat file on one side so they were the same width as the fork leg lower.
Offline SanDogDewey
« Reply #63 on: October 25, 2022, 06:01:28 PM »
Thank you Mark!
« Reply #64 on: October 25, 2022, 11:49:38 PM »
Back in 76 and 77 when I was parts manager and had to join in the late night set up parties we were all required to attend into the late night sessions because of the sales numbers of bikes going out the door, it was explained to me to have the gap to the rear, the reason for that was so any sand/road grime wouldn't be pushed into the forward gap and cause corrosion to happen. (It might have been in the assembly manual??, which only the dealers would get)
The caps in 76 and 77 came with a F or sometimes a dot to the front, which coincided with the taller mating surface. Put a straight edge on the mating surfaces of the caps to see the difference in heights.
« Last Edit: October 25, 2022, 11:52:35 PM by newday777 »
Offline SanDogDewey
« Reply #65 on: October 30, 2022, 11:27:57 AM »
No dots or F. Flipped them around a few times and didn’t notice much difference. Torqued the front and then the rear and let it be. Thanks guys!
Offline SanDogDewey
« Reply #66 on: November 03, 2022, 06:23:28 PM »
Put some "jewelry" on the tank and sidecovers. Tried to put the petcock on the tank. Ran a tap through the fiber washer to keep from splitting them. The 6x28 screws were too short. Checked the parts book and yep, that's what they called for. Noticed Yamiya has a pair of 6x35 screws in the parts section for tanks, so I ordered those. Spent about an hour bending the "R" Honda emblem to fit on the left side. Kept it under a heat lamp between bends and had no problems. Put everything on the bike for motivation!
Offline SanDogDewey
« Reply #67 on: November 03, 2022, 06:24:32 PM »
...more pics
Offline scunny
  • don't call me expert
« Reply #68 on: November 03, 2022, 07:29:54 PM »
looking good.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #69 on: November 05, 2022, 12:09:04 AM »
Outstanding paint.
« Reply #70 on: November 05, 2022, 07:58:52 AM »
I just love to see them come back.
Offline SanDogDewey
« Reply #71 on: November 05, 2022, 09:44:41 AM »
So much fun. Gives me great joy!
Offline SanDogDewey
« Reply #72 on: November 05, 2022, 09:46:58 AM »
Outstanding paint.
Thanks, but I can’t take credit for the paint, but I have the “formula” that was used. Nils had it painted by his painter.
« Reply #73 on: November 08, 2022, 05:58:40 PM »
Outstanding paint.
Is that "Nils" as in "Nils Menten"? I sure miss that guy from when he was in Tucson...
Offline SanDogDewey
« Reply #74 on: November 08, 2022, 06:55:42 PM »
Yes, that would be him! We became acquainted when we restoring our CBXs.
