Author Topic: 550K valve spring seats/washers  (Read 415 times)
Offline rell
« on: January 30, 2022, 07:15:08 PM »
I am doing a top end on my 1975 CB550K. While reassembling the heads with the help of a video, I realised I did not have any of the washers under the inner valve springs. Since I took my time during the disassembly and organized the parts, I highly doubt they were ever installed. Has anybody seen an example of heads without this inner washer/seat? Should I replace them?
Thanks,
Chris
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 550K valve spring seats/washers
« Reply #1 on: January 30, 2022, 07:40:52 PM »
Does seem a little unusual.
Ideally, you would want to get the calipers out and measure rhe installed height of the valve spring.  Then ad shims until they meet specification.
« Reply #2 on: January 30, 2022, 07:54:45 PM »
You need those hardened washers under each spring. They prevent the springs from wearing into the soft head, which will happen VERY quickly in operation. They are not shims, they are seats.
« Reply #3 on: January 30, 2022, 11:52:08 PM »
They stick to the head and valve guide and are hard to see plus difficult to remove
