Author Topic: K1 Hot Rod the Rat Race, new/old stuff.  (Read 41441 times)
Re: K1 Hot Rod goes pretty good. Maybe ready for the finished thread?
« Reply #50 on: May 15, 2022, 12:10:25 PM »
 I've done some tire marks in the driveway on the old tires. I've been busy with family things but hope to find some time to swap a plate and ride this evening.
 Yesterday after putting the front wheel back on, I did a short test ride. When I got back to re-check the chain, brakes and etc, it blew a fuse in the driveway. The fuse was intermittently working like someone posted recently when I checked, it came out in pieces. I had a 20 but I need to get a 15 and make sure I have a proper spare. I'm not sure how much the Gerex ignition and aftermarket coils use, it has to be more than stock and maybe more than a Dyna.
« Reply #51 on: May 15, 2022, 08:29:33 PM »
  I only promised the PO wouldn't see all of his stuff on ebay next week.
  I posted the pic on F/B and was amazed at the guys from here that saw it and liked the pic. also that Russ Collins Jr. saw it and liked it.
  Maybe I can get in the shop tomorrow, put on the Daytona seat and drag rear fender, finish checking my work so I can go for a real ride.
  I'm also uncomfortable riding with no turn signals. I'm going to need to put some on it with a left control also. I looked for the horn button and signal switch on the last ride. Those things are ones Honda got right.
« Last Edit: May 16, 2022, 08:53:32 AM by Don R »
« Reply #52 on: May 16, 2022, 02:37:54 PM »
 I put the black Daytona seat on it and got the drag bike rear fender with the lucas type taillight on it off the old drag bike frame. I had to make a license plate bracket, drill and tap to attach it, grind light clearance in the casting, replace the somehow broken taillight, (I had already bought a new one) make a ground wire and finally make jumper wires for the light and brake.
« Reply #53 on: May 16, 2022, 04:20:38 PM »
 The latest version on top, as it was under, next up is a K0 seat.
« Last Edit: May 16, 2022, 04:23:52 PM by Don R »
Re: K1 Hot Rod goes pretty good. Latest version now with a pic.
« Reply #54 on: May 16, 2022, 10:23:12 PM »
 I did not realize how F'n tall the hump looks on that seat. There should be a tool box in there like a Guliari. lol. Maybe with a person in a crouch at the track it's aerodynamic.
« Reply #55 on: May 16, 2022, 11:29:08 PM »
Looks great Don  8)
Sits low in the rear.
« Reply #56 on: May 17, 2022, 02:12:05 AM »
The seat can have a compartment for needed stuff like food, beers, small tent, clothes, personal stuff for overnighting ...... ;D
« Reply #57 on: May 17, 2022, 07:56:57 AM »
 L0L! I noticed the speedo drive was turned, apparently more nut and bolt (and axle) tightening is in order.
   The speedo cable fell apart when I was swapping the front wheel, I also noticed the tach cable was too long and replaced it with a new one I hadn't used on a different project. Then I realized the cable that was on the tach fit on the speedometer. ???
« Reply #58 on: May 17, 2022, 11:37:47 AM »
 I got the axle snugged up, a bearing must have been loose and popped into place.
« Reply #59 on: May 18, 2022, 08:01:28 AM »
  I'm wondering how much of, or if the exhaust smoking is caused by the 29 carbs being rich. I suspect the gerex will fire a fairly wet fuel mixture. Some plug reading and the O2 sensor may be called for here.
   The O2 gauge gave some possibly erroneous readings before, or the 4-1 to 4-4 exhaust swap made a huge difference. I did end up near stock jetting even with the 836, cam and port job.
Offline Shtonecb500
    • Youtube profile
« Reply #60 on: May 18, 2022, 06:10:16 PM »
whats that black box on the back right?
Online Kevin D
  • SE Michigan
« Reply #61 on: May 18, 2022, 06:27:34 PM »
Low Rider, Looks good and looks fast.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #62 on: May 18, 2022, 10:34:21 PM »
That's the Gerex ignition box, an early version of MSD type. It was mounted above the oil cooler, looks better there but I'm told the heat isn't good for them.
« Last Edit: May 19, 2022, 12:08:52 PM by Don R »
Re: K1 Hot Rod goes pretty good. Took it to a no prep street. L0L.
« Reply #63 on: May 22, 2022, 01:20:07 PM »
 I rode it to the Dyno shop today, Watched them tune up a Fiero with a supercharged GXP engine, then hit the industrial road out back. The bike is fast, shifts easily but the clutch is really grabby. I didn't get a launch that I was happy with.
  The other bike from the same guy had the plus 1 or 2 clutch kits with the red fibers and copper coated plates. I have not been inside this one yet. If it is, I may swap it out for a later model stock clutch basket with the gl plate and stock clutches in it.
  If I'm going to street ride, it needs turn signals of some sort even if they are LED strips stuck on the shocks and forks.
« Last Edit: May 22, 2022, 01:22:55 PM by Don R »
« Reply #64 on: May 22, 2022, 01:54:35 PM »
Those red fiber clutch plates don't like to progressively modulate like the stock clutch plates.
I'm glad it's got the power  8)
« Reply #65 on: May 22, 2022, 02:53:11 PM »
[/quote]
  That was what I was thinking when I rode it. My best shift were clutchless, I'd assume the trans is back cut since his other bike was also. I probably had a quarter mile total to work with so may have gotten an 1/8 plus. It seeps a bit of oil and smokes at idle. Could be fuel and oil.
  I'm ordering all the soft parts I can get and choke plungers for the 29's.
 I ordered 4 sets of items from niche-cycle for the 29 smooth bores. I hope they are Decent Mikuni parts. Choke plungers and associated rubber parts. I read a symptom of leaky choke plungers is running rich so at least I have them on the way and will see if it makes any difference.
  I can't really tell if the smoking is blue or black. I haven't re-packed the baffle yet. I don't mind the sound and don't want the packing holding anything corrosive in the RC exhaust.
« Last Edit: May 24, 2022, 10:19:23 AM by Don R »
Re: K1 Hot Rod goes pretty good, just needs some miles put on it.
« Reply #67 on: May 24, 2022, 12:28:53 PM »
I'm glad for you that it's a strong runner Don  8)
« Reply #68 on: May 24, 2022, 02:07:25 PM »
Don, you could read the plugs to see if the smoke is oil or fuel...or both?  Also, I am thinking smell will give a good hint.  Generally too, in my experience, fuel smokes more with throttle open, oil smokes with throttle closed.
« Reply #69 on: May 24, 2022, 02:18:49 PM »
 With the throttle open I was afraid to look back. Just kidding. A little.
  I notice it at idle when returning from a ride but my wife asked about the smoking going down the street. I really expect it to need a rebuild but will continue to ride it just to see. The leakdown test on all four looked pretty good. Compression on one and four was good.
  I'm hoping the transmission problem was why the PO stopped riding it in 87, that's fixed already. He was interested in my reports of progress and what I found. He thanked me and said it was interesting, he remembers a few things at a time.
« Reply #70 on: May 25, 2022, 02:16:58 PM »
  I also need to remember I have some seafoam and a couple oz of 2 stroke oil in the gas and a 1/2 dose of Marvel M.O. in the oil. I also topped off the tank with a gallon of the av gas/ race gas that was stored in the dragster fuel tank over winter. Stuff smells good. The octane should be sufficient.
 It's quite a stew of chemicals, I hope to get a few miles on it soon. The race car, rain and family things are keeping this old Dad hopping.
  That 140/80 radial rear tire clears everything easily, I could have gone 150 I think. It looks low profile like a new 18" car tire.
« Reply #71 on: May 25, 2022, 07:14:26 PM »
Well geez...no wonder you are not sure what's smokin'.  You only got like 10 possible causes there!
« Reply #72 on: May 25, 2022, 07:16:56 PM »
I hope you take more rides on it Don   8)
« Reply #73 on: May 26, 2022, 07:03:49 PM »
 At least a few possibilities L0L. I used the additives because of the smoke, so it was there. I'm just going to try and enjoy it for the summer. I'll use it for a pit bike, and maybe make a lap or two.
Re: K1 Hot Rod motor not so great.
« Reply #74 on: June 03, 2022, 01:51:51 PM »
 I did about 30 miles today but can't ride this drag bike thing on the street with no turn signals. My left thumb says to make turn signal go on, but it isn't there. I've got the clutch in so can't hand signal, a guy waved me to go first today at a stop sign, won't deal with that again.
  I already added the right control because I was uncomfortable with no start, headlight and kill button within easy reach.
  I'm not sure how many ounces I'll add to the total weight with 4 turn signals and a left control and don't care. I ordered a left control and rear mounts. It still needs rear mount rubbers 4-1 doesn't have them.
 Ratty turn signals will be fine on the barn bike, I also have a set of short stem red lens rears on a sissy bar mount.
« Last Edit: June 15, 2022, 11:55:05 AM by Don R »
