Author Topic: 1971 K0 CB500  (Read 21954 times)
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500 - fluff, buff, flip.
« Reply #50 on: April 29, 2022, 01:07:08 PM »
Finished, here are some more pictures.
I used some stainless steel paint to cover up over the welds
« Last Edit: March 02, 2023, 09:45:58 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #51 on: April 29, 2022, 01:08:24 PM »
You peeled back the outer cover over the inner special 'tuned header' tube which needs to be sealed inside.
They designed the inner exhaust header 'tube' to fit inside the outer chrome section(engineers designed that inner 'tube'/pipe for the exact flow to match the performance of the bike's needs)as the outer section protects the inner part from getting dinged(imo)and changing the flow of the exhaust.
I would peel back a little more of the outer section and seal the inside 'tube' before covering it all back over;otherwise the same acid exhaust water will rust through the inner header 'tube' and create a bigger rust hole all the way through.
« Last Edit: December 15, 2022, 09:22:56 PM by Shtonecb500 »
« Reply #52 on: April 29, 2022, 01:50:10 PM »
Good looking repair;what material did you use ?
Edit:the strong weld repair you did looks like you fixed it.  8)
« Last Edit: April 29, 2022, 03:45:24 PM by grcamna2 »
Offline Shtonecb500
    • Youtube profile
« Reply #53 on: April 29, 2022, 03:11:47 PM »
Thank you. Honestly, idk what grade steel it is, just some scrap out of the bin, i'll post some more pics of the pieces.
Stuff you can get from home depot or ace hardware.
« Last Edit: March 02, 2023, 09:45:29 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #54 on: April 29, 2022, 03:17:42 PM »
Im getting quotes from three different painters, I know the most expensive guy wants around 1500 for a body kit done....im looking for 500-700 bucks.
Offline Shtonecb500
    • Youtube profile
« Reply #55 on: May 01, 2022, 01:32:10 PM »
This frame support is collapsed a little, wonder how that happened?
I got the pipe hung back up on the motor, noticed the coils weren’t mounted correctly, and I cleaned the frame up with degreaser a little.
« Last Edit: December 15, 2022, 09:24:47 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #56 on: May 17, 2022, 09:35:23 AM »
Tank stripped clean and dropped it all off to the painter this morning.
Offline Shtonecb500
    • Youtube profile
« Reply #57 on: May 18, 2022, 06:23:40 PM »
I called three painters and only got one call back, the most expensive one. So, I guess the other guys are busy but at least I know if my wallet hurts on this the paint job is gonna be top notch.
Im thinking this is going to encourage me to get the same color done for my daily 550.
« Reply #58 on: May 18, 2022, 07:27:51 PM »
I know you may have mentioned this earlier,please tell me the color(stock?)you will make it ?
Offline Shtonecb500
    • Youtube profile
« Reply #59 on: May 18, 2022, 08:48:53 PM »
candy gold
« Reply #60 on: May 18, 2022, 09:27:43 PM »
candy gold
 8) Will it have the two-tone color on the tank ?
Offline Shtonecb500
    • Youtube profile
« Reply #61 on: May 21, 2022, 12:44:59 PM »
candy gold
gold paint, black panel with pinstripe, no decal.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #62 on: May 23, 2022, 12:18:01 AM »
Gonna be sharp!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Shtonecb500
    • Youtube profile
« Reply #63 on: June 18, 2022, 05:01:32 AM »
should have paint back soon, im really nervous cause there arent any paint codes, and the body work i provided had paint that was too faded....what kinda gold am i gonna get back?
If the color is off too much and cant sell it i might have to sell my other 550 and keep this.
« Last Edit: June 20, 2022, 12:27:42 PM by Shtonecb500 »
Offline WideAWAKE
« Reply #64 on: June 18, 2022, 06:09:46 PM »
https://vmrpaints.com/products/honda-motorcycle-candy-gold-restoration-paint?rq=mk_honda~ek_cb500~dq_1972
I purchased some candy blue green paint from them and it was spot on.
« Reply #65 on: June 20, 2022, 11:44:51 AM »
VMR has accurate paints, but candy is tricky. The more you apply, the more brilliant the color, which can outshine the original color.
Offline Shtonecb500
    • Youtube profile
« Reply #66 on: June 24, 2022, 02:57:39 PM »
I walked into this shop and gave them a boss maroon 550 tank to reference the decal. I told them the outer black line needs to either be very thin or not there at all, they said ok no problem. I picked up my tank and the first thing he says is "I know you said not to do this line wide, but we couldn't do it thin, hope its ok".
That was the most specific request i had for this paint job and they #$%*ed it  up. I cant find a single 500 tank with an outer fat black line, so this tank isn't correct.
« Last Edit: December 15, 2022, 09:26:10 PM by Shtonecb500 »
Offline WideAWAKE
« Reply #67 on: June 24, 2022, 03:17:10 PM »
Tell em to fix it.
If they can’t, get your money back.
There is no way they are a legit paint shop and can’t spray a 1/32 line.
« Reply #68 on: June 24, 2022, 06:18:39 PM »
Tell em to fix it.
[/quote
+1]
Offline Shtonecb500
    • Youtube profile
« Reply #69 on: June 25, 2022, 07:45:05 AM »
« Last Edit: December 15, 2022, 09:26:53 PM by Shtonecb500 »
Offline Little_Phil
« Reply #70 on: June 25, 2022, 10:14:15 AM »
Wow that's a lot of dough. That side panel alone is a disgrace.
Lesson is never use a sprayer without a proven track record. Many good new sprayers are actually trained by the existing shops.
« Reply #71 on: June 25, 2022, 12:51:53 PM »
im taking the weekend to relax a little and not feel so #$%*ed over. I will for sure ask the shop to see if we can remedy this....
im not interested in this cb500 color scheme with a 550 decal lol.
I Feel you on that !
They need to fix that and make it just like a factory color scheme  >:(
Did you show them a picture of what you were after when you brought the job to them ?
I hope you speak with the owner and present the problem to that person.
Offline Shtonecb500
    • Youtube profile
« Reply #72 on: June 25, 2022, 01:36:54 PM »
i took a 550 tank for them to reference, told them to change the gold stripe to white and to not include the wide black line on the end.
Offline Shtonecb500
    • Youtube profile
« Reply #73 on: July 17, 2022, 06:04:41 PM »
Only going to show the somewhat presentable side of this tank, lol.
Vintage days mid Ohio is this weekend, maybe I’ll get lucky and find a kit to paint or score a deal.
« Last Edit: July 17, 2022, 06:17:42 PM by Shtonecb500 »
Offline Little_Phil
« Reply #74 on: July 18, 2022, 04:03:55 AM »
It's not correct, but presentable. Could do with gong over the tank badges if you are looking to get shot of it.
