Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 131372 times)
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #950 on: September 28, 2025, 08:19:29 AM »
Beautiful 1100!
If it didn't already have an O2 sensor, how will it be used?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #951 on: September 28, 2025, 10:43:28 AM »
Beautiful 1100!
I have an autometer gauge on the handlebars, it reads out digitally and with a color bar graph. It also has a digital memory that I can check later. It seems the carbs came jetted very well when new. My probe was reading rich and led me astray.
Offline Magpie
« Reply #952 on: September 28, 2025, 04:27:41 PM »
Into the guts of it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #953 on: September 30, 2025, 08:05:42 AM »
Is it damaged? Or just routine freshen up?
1973 CB 750 K3
Offline Magpie
« Reply #954 on: October 01, 2025, 08:57:34 AM »
It's new to me so I wanted to see how it looks inside. New rings coming. Cliff.
Offline Kelly E
  • Geriatric Hooligan
« Reply #955 on: October 07, 2025, 02:10:27 PM »
I finally finished installing the National F-16 windscreen on the 77' KZ 1000 LTD. I needed something to block the wind blast. I like the basic design but the quality control could be better. I knew I would have to alter the mounting slots because of moving the front turn signals from the bars to the headlight mount. I had to open the slots up from 10mm to 15mm. I wasn't happy with the amount of vibration at the top of the windscreen and how easily I could push it back further so I made braces for the upper part.
I used some handlebar clamps from an old busted windscreen, some rubber lined 3/16" P clips and a couple pieces of 3/16" rod. I drilled 4mm holes in the upper part of the windscreen to mount the P clips. With an inch of the rods bent about 110° to fit in the P clips and the bottom goes into the bar clamps. I have used this method for other fork/handlebar mount fairings, it works great.
« Last Edit: December 18, 2025, 07:35:25 PM by Kelly E »
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Magpie
« Reply #956 on: October 11, 2025, 10:10:45 AM »
A bit of cleaning and the frame is ready for paint prep and waiting on a friend to go through his Triumph stuff that I can have. This may be a long term project.
Offline BenelliSEI
  • 1969 cb750
« Reply #957 on: October 13, 2025, 07:41:16 AM »
Cliff….. looking at your photo. Replace the oil pump now?
Offline Thunder
« Reply #958 on: October 14, 2025, 06:43:01 AM »
Finished a CB, then found the older "finished" bikes needed a refresh , so CBX on the bench
...Faceplates were $$$, so of course i go an crack one when inserting the needle stop
« Last Edit: October 14, 2025, 06:47:40 AM by Thunder »
Offline grcamna2
« Reply #959 on: October 14, 2025, 09:37:04 AM »
CBX  8)
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #960 on: October 27, 2025, 06:19:32 AM »
Chased these two around all weekend!
Offline pickleknuckles
« Reply #961 on: December 17, 2025, 08:52:10 PM »
Got a free BMW the other day and have it just about torn completely down w 70% of the moss and tree decay cleaned out.
Sent from my Pixel 8 Pro using Tapatalk
Offline grcamna2
« Reply #962 on: December 17, 2025, 09:08:00 PM »
What model Beemer is it ?
« Reply #963 on: December 18, 2025, 03:29:08 AM »
2001 F 650 GS
Offline BenelliSEI
  • 1969 cb750
« Reply #964 on: December 18, 2025, 05:54:46 AM »
2001 F 650 GS
Is that a single or twin?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #965 on: December 18, 2025, 07:09:37 AM »
It amazes me how a new bike ends up tossed away like that.
1973 CB 750 K3
« Reply #966 on: December 18, 2025, 07:54:11 AM »
What really amazes me is that as of January, 2001 was 25 years ago.
This one was a year round daily rider for a mechanic at a local bike shop so it's got some miles on it.
« Reply #967 on: December 18, 2025, 08:02:16 PM »
2001 F 650 GS
Single cylinder Austrian made Rotax.
« Reply #968 on: December 20, 2025, 07:31:02 PM »
Got it all mocked up w the GS Dakar's suspension. Still have to get a 21" front wheel and weld on a bracket for a chain roller that the standard GS frames don't have.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #969 on: December 23, 2025, 06:54:08 AM »
Cool! At this point it looks like a chopper.
1973 CB 750 K3
« Reply #970 on: December 23, 2025, 03:31:16 PM »
Haha. I said the same thing.
« Reply #971 on: December 26, 2025, 11:57:58 AM »
I’ve been busy clearing my property for new fences, then after the fences went up I got sidetracked from bikes when I bought another twin turbo Subaru with a blown turbo and spent a week crawling around under it to replace the blown turbo.
Last week I picked up my seat for my Yamaha VMax from the upholstery shop and installed it, probably the single biggest upgrade (and most expensive) that I’ve done on it so far. The previous owner had painted the side covers flat black and they looked awful so I stripped the paint off and gave the aluminium covers a quick polish. Just waiting for new badges now, and I’ll call it good.
Offline grcamna2
« Reply #972 on: December 26, 2025, 04:28:41 PM »
Your VMax is a beauty;is it the fastest bike you own Terry ?
Offline BenelliSEI
  • 1969 cb750
« Reply #973 on: December 27, 2025, 02:32:58 PM »
Looking good Terry!
« Reply #974 on: January 07, 2026, 05:18:56 PM »
Thanks guys, it's close between the VMax and my Kawasaki ZZR1100, the VMax would keep up (or beat the Kawasaki to) 140 MPH, maybe 150, but the Kawasaki will happily run up to 170. I have been collecting a few parts for the Kawasaki and last week remembered that I had some gold Tokico 6 pot calipers in a box. I wondered if they'd fit the Kawasaki, and was 'rapt that the bolt holes all line up.
Terry's ZZR1100 brake conversion Jan 2026 by Terry Prendergast, on Flickr
The first issue was that the ZZR1100 standard calipers have two 10mm fine mounting bolts, whereas the ZX14(?) caliper bolts are 8mm, so I made some spacers.
Terry's ZZR1100 brake conversion Jan 2026 3 by Terry Prendergast, on Flickr
Terry's ZZR1100 brake conversion Jan 2026 1 by Terry Prendergast, on Flickr
And the caliper now fits straight on:
Terry's ZZR1100 brake conversion Jan 2026 2 by Terry Prendergast, on Flickr
I bought the cheapest possible brake pads and they arrived a few days later. I've just ordered new Venhill hoses (in Kawasaki Green) and once they arrive I'll install the calipers and new lines. I'd installed some 1" handlebar risers last year, and bought a custom "powerbronze" black fairing screen with a bit of a lip on it to (hopefully) redirect the wind blast over my head, it's pretty had to keep your head still at 170 MPH with the stock fairing screen blasting wind into your face and neck. I installed the new screen with some "Kawasaki Green" lightweight screws that Spotty gave me.
Terry's ZZR1100 new fairing screen 1 Jan 2026 by Terry Prendergast, on Flickr
Everything seemed to fit OK, I must take it for a ride again soon. ;D
Terry's ZZR1100 new fairing screen Jan 2026 by Terry Prendergast, on Flickr
