Author Topic: 1978 CB750F3 rebuild start  (Read 11212 times)
Offline denward17
Re: 1978 CB750F3 rebuild start
« Reply #100 on: November 06, 2023, 03:05:56 PM »
Good news!
That tank looks awesome. What color is that called and where did you get the paint?
Offline majorzozo
« Reply #101 on: November 06, 2023, 03:41:46 PM »
Thanks Denward.  VMR paints.  Candy Presto Red.  Wish I could take credit for it but I had a guy from a local body shop paint it.  Came out nice...
« Reply #102 on: November 06, 2023, 04:37:05 PM »
Very nice paint work major
Offline majorzozo
« Reply #103 on: November 06, 2023, 04:52:36 PM »
Thanks Rafster.  Forgot to mention that the valves were also adjusted along with the cam chain.
Offline majorzozo
« Reply #104 on: November 07, 2023, 03:05:43 PM »
Happy to say I'm finished.  All in just shy of 12K invested for a bike that is probably worth 7K (LOL).  Not a 10 but I would say a definite 8.  Rode it for 5 miles today and ran strong through all the gears.  At least for the time being no fuel or oi leaks.  Not sure if this normal but you could definitely feel the heat from the engine.
Looking forward to getting it registered so I can take it on a long ride.  For a first time restoration I definately under estimated how much labor was involved cleaning and reconditioning everything.  Well worth it though as I always wanted a clean 78F.
I think my next project will be a Z50 Minitrail just because it should be way easier. Hahahah.  Thank you all on this is site for the invaluable information and assistance.  Greatly appreciated...
Offline denward17
« Reply #105 on: November 07, 2023, 03:17:07 PM »
Great news!.
You ended up with a beautiful bike and hobby, you can't put a price on the joy of workmanship.
Glad you got it running.
P.S. I kept a spreadsheet on the costs of mine, and I know how you feel about having more invested than could be sold for.  But now you get to enjoy it.
« Reply #106 on: November 07, 2023, 03:36:51 PM »
They nearly always cost far more to restore than they are worth...you get the joy s d frustrations as well as the satisfaction and learning that comes with doing a restore. Many of us enjoy the project a lot and are addicted to that cycle, keeps you out of trouble and better than spending your money on lawyers or other nonsense...
Offline BenelliSEI
  • 1969 cb750
« Reply #107 on: November 07, 2023, 06:22:07 PM »
Well done. You know your bike and you know it’s done right! Enjoy it and keep smiling! I certainly enjoyed watching your progress.
Offline Kelly E
  • Geriatric Hooligan
« Reply #108 on: November 08, 2023, 09:29:28 AM »
The best advice I can give about restoring bikes is don't do a spreadsheet on expenses. If you are doing it for fun a spreadsheet will kill the fun quickly. Besides the wife might find it and have a flaming hissy fit. 8)
Most of the time I have Paul order the parts and give him cash. No paper trail to get me in trouble. ;D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #109 on: December 20, 2023, 10:04:03 PM »
FYI - I have posted this bike for nomination for Bike of the Month.  Can I get someone to "second" it?  If so, please post your second in the following nomination thread:  http://forums.sohc4.net/index.php/topic,180400.msg2266596.html#msg2266596
Offline newday777
« Reply #110 on: December 21, 2023, 01:13:51 AM »
Yes I'll second this!
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #111 on: December 21, 2023, 01:16:49 AM »
It turned out great 👍 Nice job on it.
Stu
My current rides
Prior bikes....
Offline majorzozo
« Reply #112 on: December 21, 2023, 11:12:02 AM »
Thank you for the nomination.  Surprised to just be considered.  Some updates:
As I am sure like all of us just havent had the time to really ride as much as I want.  Have just over a hundred miles so far and the bike had the stock sprockets which were 14 front and 43 rear.  With that set-up I was taching approximately 4800 at 60 MPH.  I changed the rear to 42 teeth and it came down to about 4700 at 60 then I also changed the front to 15 teeth and it came down to 4200 at 60 and approximately 5000 at 70.
Still very cold blooded as it takes about 4 miles before I can fully remove the choke.  It also seems hot so I attached some stick on temperature strips to the valve cover and side cover.  The valve cover runs at about 185 degrees around town and when I stop and shut the bike off it shoots up to about 225 degrees before it starts to cool.  Not sure if this is too hot or not.
Still no fuel or oil leaks but I believe I am still just a tad lean.  I think I am going to increase the main jets to 110 and the idle jets to 38 and see what the response is.   Other thaan that everything works great.
Thanks again...
Offline BenelliSEI
  • 1969 cb750
« Reply #113 on: December 21, 2023, 12:42:33 PM »
I like those graduated heat strips. Where do you get them?
Offline majorzozo
« Reply #114 on: December 21, 2023, 01:38:30 PM »
Amazon.  I think about $15.
Offline bustech51
Re: 1978 CB750F3 rebuild o ring locations
« Reply #115 on: January 01, 2024, 11:46:12 AM »
I'm working on my 1978 cb750F engine.  When I removed the head and cylinders there were 4 small o rings on 4 of the studs between the block and the cylinder.  Not the larger and taller o rings.  I cannot find anything in the manuals regarding these o rings.  I have accounted for all of the other seals (i.e. the ones on the oil control restrictors) and the larger o rings that go between the cyl and the block.
Is there something that i am missing?  They are included in the gasket kit that I bought.
Offline denward17
« Reply #116 on: January 01, 2024, 12:00:06 PM »
This thread may be of some assistance:
http://forums.sohc4.net/index.php/topic,107040.0.html
Offline majorzozo
« Reply #117 on: January 01, 2024, 02:26:35 PM »
I believe those are 4 each of part number 91301-410-000.  Also check out this thread.
http://forums.sohc4.net/index.php?topic=136900.0
Offline BenelliSEI
  • 1969 cb750
« Reply #118 on: January 09, 2024, 11:25:20 AM »
Thanks! Three for $30 (in Canada). I have a part of our induction system on the race car that I am very curious about (temp). Ordered.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #119 on: February 18, 2024, 01:28:44 PM »
Beautiful project, you will enjoy it. Great to see another brought back.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #120 on: February 18, 2024, 03:38:13 PM »
subscribed
75' CB400F/'bunch o' parts'
Offline CB750R
  • 77 CB750F
« Reply #121 on: February 19, 2024, 12:36:22 PM »
Beauty bike congrats! I respect the full restoration effort! I too am sinking a small fortune in a late F model. Mine is far from yours in terms of originality though!
Offline kap384@telus.net
« Reply #122 on: February 24, 2024, 11:00:49 AM »
Great job!!  Love that you went original.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline majorzozo
« Reply #123 on: February 25, 2024, 08:21:50 AM »
Thanks all for the kind compliments.  I finally found a chrome plater who would do an exhaust.  Pacific plating in Santee Ca did my headers and collars.  Pricey at $450 but they were absolutely wasted and they came out like new.  The muffler was not chromed but I had to have the forward end bottom welded as it was rotted out.  The Delkivic I had was too loud for my old wrinkled --- and this stock set-up is much quieter.
Still fighting to get my carbs perfectly tuned but slowly gaining on it...
Offline newday777
« Reply #124 on: February 25, 2024, 04:58:47 PM »
WOW
Did you have to clean the inside out?
« Last Edit: February 26, 2024, 03:26:14 AM by newday777 »
Stu
My current rides
Prior bikes....
