Author Topic: ‘76 CB550 power always on  (Read 898 times)
Offline Jcop.550
« on: August 22, 2023, 01:35:12 PM »
Hey guys! Back again with another issue.
1976 cb550 I recently picked up. Sat for many years and I purchased it without a battery or any clue what could be wrong.
Bought a battery, cleaned the carbs, did an oil change and got it to run…BUT the power is always on no matter what position the key is in. I can even take the key out and power will still be on. I have to disconnect the battery every time. Haven’t really dug into that yet since I just got it going within the hour. Any ideas on where to start or what the issue might be?
Offline Gurp
  • I'm no.......
  • Once was a...
Re: ‘76 CB550 power always on
« Reply #1 on: August 22, 2023, 06:04:29 PM »
Sounds like some bad wiring job from a PO or a bad IGN switch.
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline newday777
« Reply #2 on: August 22, 2023, 06:47:43 PM »
Have you looked over the harness and all connectors for melted wires/pins in connectors?
Stu
My current rides
Prior bikes....
Offline Jcop.550
« Reply #3 on: August 22, 2023, 06:57:43 PM »
Haven’t gotten that far. Just reaching out to see if someone knew of something that may be an easy fix. I will check all that though, thanks!
Online PeWe
« Reply #4 on: August 22, 2023, 08:23:52 PM »
Check the fuses, if they sit correctly. It is possible to place them one step sideway, between 2 different circuits and make a short.
Offline Kenzo1979
« Reply #5 on: August 25, 2023, 06:30:53 PM »
Disconnect the ignition harness connector and see if the bike shuts off.  If it does, your ignition key switch is the culprit.  If so, take it apart and rebuild it.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Online grcamna2
« Reply #6 on: August 25, 2023, 09:45:41 PM »
 ;) First thing to check.
75' CB400F/'bunch o' parts'
