Author Topic: 1974 cb750k rescue  (Read 4794 times)
Offline lash
1974 cb750k rescue
« on: January 21, 2024, 04:41:46 PM »
Probably my next build. Before we cleaned off the weeds you couldn’t even tell there was a bike in there!
Offline denward17
Re: 1974 cb750k rescue
« Reply #1 on: January 21, 2024, 04:58:26 PM »
Oh my, looks like a lot of work....plan to go back stockish with it?
Good Luck with build.
Offline lash
« Reply #2 on: January 21, 2024, 05:21:50 PM »
Ya, back to stock.
Offline Mikey G.
« Reply #3 on: January 21, 2024, 05:42:30 PM »
That bracket for the key and voltmeter (ammeter?) is a neat first for me.
Regardless, it looks like a solid start.  Good luck!
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Online BenelliSEI
« Reply #4 on: January 21, 2024, 07:20:05 PM »
That is definitely worse than the K2 I made you take out of my barn. Will be fun to watch this one too! Good Luck! J.
Offline lash
« Reply #5 on: January 21, 2024, 07:34:01 PM »
That would be this one!
« Reply #6 on: January 21, 2024, 07:34:33 PM »
Oil pressure....
« Reply #7 on: January 21, 2024, 07:37:30 PM »
Lash
Is that motor locked up ? Sure looks like it is from the exposed rusted valve rockers. 😕
You will definitely have your work cut out for you on that one.
Offline lash
« Reply #8 on: January 21, 2024, 07:50:48 PM »
Don’t know, but I will be totally surprised if it isn’t. Its still parked out in the shed, not sure when I will start it.
Offline CycleRanger
  • No comment about being an
« Reply #9 on: January 21, 2024, 08:23:51 PM »
Yeah, if that engine is full of water it may be beyond saving.
That's really ambitious, not a project I'd touch.
Good that you saved it from scrap whatever happens.
« Reply #10 on: January 22, 2024, 02:23:57 AM »
That bike reminds me about Terry's Swamp rat! ;D
Online BenelliSEI
« Reply #11 on: January 22, 2024, 02:08:39 PM »
I’ve seen his bikes. By the time he’s done: “Bike of the Month”!
Offline lash
« Reply #12 on: January 25, 2024, 12:03:50 PM »
This is going to be a long haul but started some disassembly today. Looks better already!
« Last Edit: January 25, 2024, 12:05:40 PM by lash »
Online BenelliSEI
« Reply #13 on: January 25, 2024, 01:59:27 PM »
Looks like fun! Always surprises me how we can blow them to pieces in 24 hours!
« Reply #14 on: January 25, 2024, 07:50:41 PM »
Take apart very quick, the other way, much longer time. Small as big jobs.
« Reply #15 on: January 26, 2024, 12:09:10 AM »
subscribed
Offline lash
« Reply #16 on: January 31, 2024, 09:25:30 AM »
A little more progress. Everything off the frame and ready to clean it up. Did the forks yesterday, was hoping to use the old tubes, but they were too scarred so had to go new ones. I’m trying to use as much of the original bike as I can. So far so good.
Online BenelliSEI
« Reply #17 on: January 31, 2024, 02:03:29 PM »
Nice progress! I think I have a set of extra, new tubes? Didn’t you ask me for them? They might be for earlier forks…… will look today.
« Last Edit: February 01, 2024, 05:59:57 AM by BenelliSEI »
« Reply #18 on: February 07, 2024, 03:53:25 AM »
It caught my eye also. Might have to make some up.
I think it is an oil pressure gauge, which is what I want there to be able see it, lighted of course.
I'd probably add a LED volt meter or a LED bulb volt warning light in the plate.
I bought one of these but haven't installed it yet until I make a plate to mount it in.
https://www.ebay.com/itm/190401283689
Or maybe try to fit a voltmeter/USB outlet
Cllena Quick Charge 3.0 Car Charger, 12V/24V 36W Dual QC3.0 USB Charger Socket Power Outlet with LED Voltmeter for Car Marine Boat Rv ATV UTV Truck Golf Cart etc. (Green) https://a.co/d/fSUeZRB
« Last Edit: February 07, 2024, 03:55:32 AM by newday777 »
« Reply #19 on: February 07, 2024, 03:58:44 AM »
Lash
The fork legs look great, nice work on them.
No holes in the frame?
What's the status on the motor?
Offline lash
« Reply #20 on: February 07, 2024, 05:01:55 AM »
So far frame looks good. Had to grind off some welds on the front tubes, I think were at one point attachments for maybe highway pegs. Going to take a while before paint!
Engine is in better shape than I expected but some parts are not usable. The cam and towers are in great shape but the rocker arms are trash as are the valves. The cylinders could probably have been reused but there are too many missing fins so I will replace it.
« Last Edit: February 07, 2024, 01:15:11 PM by lash »
« Reply #21 on: February 07, 2024, 10:52:59 AM »
Glad to hear the frame is still good;can you get it registered ?
Offline lash
« Reply #22 on: February 07, 2024, 01:17:00 PM »
Shouldn’t be a problem to get it registered, just have to have the right paperwork. I’ve done at least 5 so far.
« Reply #23 on: February 07, 2024, 06:04:37 PM »
 8)  thumbs-up !
Offline lash
« Reply #24 on: February 10, 2024, 01:13:42 PM »
Frame stripped and primed. Have to wait for warmer weather to paint .
Engine cases ready for paint also.
