Author Topic: Engine Pulls Hard up to 5.5k RPM Then Not So Much  (Read 6317 times)
Online PeWe
Re: Engine Pulls Hard up to 5.5k RPM Then Not So Much
« Reply #75 on: June 18, 2024, 09:47:14 PM »
I have tried the Yamiya advancer springs on my K2. I could not get F to line up with case mark at Idle. Yamiya springs did not help.
TEC points. 300 advancer.
F was a little advanced, around 1-2mm at idle.
I had to cut the stock springs that fixed it, F lined up with case mark.
It has Dyna-S now
(As my K6 that also has cut springs.)
Offline Finnigan
« Reply #76 on: June 18, 2024, 10:52:38 PM »
Thanks for letting me know!  Any additional info on how you cut the springs?  Picture even?
Offline willbird
« Reply #77 on: June 19, 2024, 08:24:34 AM »
It has Dyna-S now
It sucks that somebody has not just made a spring kit, people would buy a lot of them.
Offline johno
« Reply #78 on: June 20, 2024, 01:33:48 AM »
Hi Finny
Re Springs...I just cut one of the end hooks off with snips and then with a pair of pointy nosed pliers bend the next coil up to 90 degrees to replace the previous loop.  :)
Offline Finnigan
« Reply #79 on: June 20, 2024, 08:32:21 AM »
Hi Finny
Makes sense, thanks for the info
Offline Finnigan
« Reply #80 on: June 20, 2024, 02:47:32 PM »
cut the end of both springs and bent the last loop 90, stiffened the system up quite a bit and was much more snappy.  The RPM for full advance didn't change much if any and I still need to position the F mark for 1/4 and 2/3 to the left of the timing mark to land in the middle of the full advance zone.
Noted that before the spring mod, 2/3 were a different distance from the timing mark than 1/4 to get in the fully advance section.  maybe I need to take ANOTHER loop out of the spring to make them pull harder?
Going to look around for some options when my Yamiya order comes in, maybe I can experiment with different sizes and strengths.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #81 on: June 20, 2024, 04:19:56 PM »
What main jets are you running?
Online newday777
« Reply #82 on: June 20, 2024, 08:17:54 PM »
Did you continue to use the 4into1 advancer with the cut springs?
Offline Finnigan
« Reply #83 on: June 20, 2024, 09:17:13 PM »
Just switched from 120s to 115s
Offline Finnigan
« Reply #84 on: June 20, 2024, 09:18:41 PM »
As in 4into1.com?  I am using the stock Honda advancer with the cut springs, its the 323 stamped version.
Online scottly
« Reply #85 on: June 20, 2024, 09:24:55 PM »
323?
« Reply #86 on: June 20, 2024, 09:27:24 PM »
If the 1-4 side reaches full advance, but the 2-3 side doesn't, I have most often found that the whole points plate itself was sitting a little bit "low" in the mounts, because the plate was slightly undersized. This happens with non-OEM timing plates, most often the Daiichi or FEW brands of plates. Raising the whole plate upward usually solves it nicely, if clumsy to do: I use some old feeler gages to shim the plate upward (in the lower mounts) while tightening the screws.
If the marks are 'jittery' or jumping around, that is due to the points shaft being bent. This favors having the 2-3 side not being able to reach full advance, too, but with the 'jumpy' timing witnessing the problem being in the points shaft and the advancer thus not being at right-angle to the points plate.
PS: the -323- advancers are for the CB350F engines, not the 750. The total advance angle is different between them.
« Reply #87 on: June 20, 2024, 09:42:03 PM »
The springs has nothing to do with total advance.. The springs return the timing to the initial timing (usually the F mark) as they can overcome the centrifugal forces of the higher rpms…  stronger springs will only delay the advance like already posted.. the range (in crankshaft degrees) of  the advancer is fixed (unless modified)..  #6 in the manual and as already posted the strobe light can verify the fixed advance range and explains what is ideal and what to do if it is not..
If Yoshimura is recommending +3 degrees advanced (ignition timing) your strobe should be blinking out in front of the 26.5 degree mark at higher rpms…not any where in between them..
Stronger than stock springs are good for more radical engines with longer duration camshafts that cannot be satisfactorily tuned to idle smooth at lower rpms… the stronger springs prevent a fluctuating timing condition at idle rpm..  where the idle rpm may be high enough the weak springs may be allowing the advancer to advance the timing from the static( F mark) to a greater advance and then back to the initial timing as the engine idles rough from the long duration camshaft..Some call it “scattering” which can easily be verified with your timing light..it will look like the timing mark is moving around at an idle instead of stationary blinking and stopping the timing mark exactly in the same place..
Do you have a family member or friend that has carburetor and mechanical distributors experience to lend you a hand..?
Offline Finnigan
« Reply #88 on: June 20, 2024, 10:41:14 PM »
Image of spark advancers in your book (appendix G-2) shows a K4 advancer with the 323 stamp.  What am I missing?
Offline Oddjob
« Reply #90 on: June 21, 2024, 10:03:31 AM »
323 is the model number of the 500-4 not the 350-4.
Online scottly
« Reply #91 on: June 22, 2024, 06:56:00 PM »
The 350-400 uses a 333 advancer. Finnigan, please post a pic of the T and F marks on your 323 advancer.
Regardless of which unit you are using, it should still travel from the F to the full advance marks at RPM, and back to the F mark at idle.
« Reply #92 on: June 23, 2024, 08:44:09 PM »
The -323- advancers were used on a select few of the 750s during the US gasoline shortage in 1975, notably 750K4 and 750K5 bikes (that's one reason why that -323- version appears as the 3rd advancer in that picture). Their advance springs were softer than those found on the 350F, though, to achieve full advance by 2000-2200 RPM instead of 2500+ RPM, and the compression was lower in those engines as well, due to a +1mm height difference in the cylinders (and heads). Honda was advertising 50 MPG fuel economy at the time (at 55 MPH) and these were some of the 'tweaks' they used to get there. But, the top end of those bikes was about 90-92 MPH on average, so the practice disappeared quietly and quickly, and in the shop where I was then (Littleton Honda) we were issued {n} number of spark advancers to recall the bikes and change them. I only saw 1 actually get recalled and changed, but the performance difference was both immediate and noticeable.
In the 350F engines the springs are stronger and the full advance occurs nearer to 3000 RPM, but the full advance angle of the advancer is less (I think it is 3 or 5 degrees less, something like that).
To obtain similar MPG results with the stock 750 advancer we would set the idle timing at the "T" marks instead of the "F" marks, and change the float bowl levels in the carbs to the 26mm of the post-K1 era bikes. Interestingly, the bikes idled better and did get better MPG, but the upper-end performance was noticeably less. It was OK for touring, though, since you couldn't run much more than 65 MPH anyway, lest the gendarmes get pissed.
Since today it's harder to get a 'proper' advancer for these engines, I have [several times] altered the -323 advancer by grinding the notched back side of the weights at an angle (wider toward the baseplate) and then bent the 'stop' ears (and/or thinned them) to get the extra few degrees of advance angle out of them. They have a natural advantage today over the regular advancers in that slowing the spark advance curve is needed with today's gasolines because they burn so slowly compared to the 1970s fuels: with normal advancers I cut off 1-2 turns form the springs to slow the advance, but with the -323- advancer the springs seem to be just about right, provided the weights can swing further to get the same full-advance angle.
But on the whole, the -323- advancer used today in a 750 will make for a seriously sluggish performance (although the sparkplugs may stay cleaner loner).
Offline Finnigan
« Reply #93 on: June 26, 2024, 12:54:52 PM »
Good progress today,
Last week I scored a K1 advancer on eBay for 20$, it arrived and after cleaning and lube the springs felt a little soft - decided to go with the Yamiya ones (needed or not, educated guess based on feel).  I also replaced my stock points shaft with a NOS even though I bent the old one into shape with a soft hammer and dial indicator per HM's book and online instructions.  Since the poor stock hardware had turned to cheese with all the adjusting I went and got stock length Allen bolts to make things easier for future adjustment.
It took about 5 minutes to get the F mark on and no adjustment was needed after, both points fell on the static 'F' and between the lines at full advance and it seems as though its coming on at the same RPM as the old one (I'm aware these advancers could foul plugs with loose springs?).
I'd consider THIS issue resolved....running out of things to fix :)
As a side note: without touching the carbs at all the bike now idles at 800RPM where before I couldn't get it lower than 1100.  Time for a test ride :)
Thanks for all the help and comments!
Offline Finnigan
« Reply #94 on: June 26, 2024, 03:06:53 PM »
Be aware that Deltarider will demand a video of the engine idling at 800. He seems to think it’s not possible for a sohc to idle smoothly under 1000 revs. I could get my 500 down to 600 rpm when I restored it in the late 70-80, a fact he refuses to accept, saying that he refuses to accept most facts 😀😀😀
5-600 seems crazy, must be a 750 whisperer :)
After 3 test rides I think I found the sweet spot where the power comes on around 6.5, letting the engine cool before I pull the plugs again.
I think this motor still has more to give, every time I dive into an 'issue' it turns into a lesson or 'a ha!" moment.
When I get new rear shocks I'd love to drive it on a 100+ mile trip up the coast and fingers crossed a dyno tune someday.
Offline Finnigan
« Reply #95 on: June 26, 2024, 03:18:45 PM »
We only have his word it's running at all, or even that he has one ;)
Trouble uploading, hope it works this time
Offline Old Scrambler
« Reply #96 on: June 26, 2024, 05:50:58 PM »
Nice.....just observing that with those tires and your 'larger' motor, you could change the rear sprocket down to 43-45 and be comfortable at current highway speeds.......which would also move the rear wheel back and give you some slack in the chain. Have Fun
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Gusto mo titi ko?
    • project
« Reply #97 on: June 26, 2024, 06:27:22 PM »
Looks great, congrats! Vroommmm~
Offline Finnigan
« Reply #98 on: June 26, 2024, 07:49:06 PM »
Very good eye, the tires are leftover from a couple years ago I had them so I put them on (struggled with the huge sidewall and non flex of the rubber) and I've regretted it ever since.  They feel like basketballs on the freeway and despite going to softer rear and gold emulators + progressive springs up front it hasn't helped much.  Performance tires or vintage correct Dunlops are in the works.
Based on an old Yoshi article I have in Choppers Magazine the closest upgrades from Yoshi demo bike to mine had 18/48 which I decided to run.  I should really go to a 17 but waiting until the tires materialize.
Online PeWe
« Reply #99 on: June 27, 2024, 02:57:07 AM »
About idle rpm.
I prefer 1200-1300rpm, adjusted when hot after at least 30min ride.  Stock as well as modified engine.
Much easier to ride. Take offs and less abrupt throttle off.
Higher compression is trickier for smooth take off at too low rpm.
Easier to keep it idling when cold too.
I can set idle on my K6 970ccc + 125-75 cam to 1000rpm. It will be a pig at take offs due to the compression and too responsive flat slide carbs.
Oil flow a good reason for higher idle.
Check when engine is really hot a very warm day. Risk that oil warning lamp will flicker if idle is low.
