Author Topic: Hydraulic clutch conversion for the mono shock dragbike. Will it work??  (Read 6246 times)
Offline dragracer
  • CB750F Dragbike
I've decided to try something a little different fir the clutch set up on the mono shock dragbike. I saw something on a SOHC group post on Facebook regarding the use of a universal type hydraulic clutch kit on a 750. While the poster wasn't detailed on his installation there were a few pictures that graphically showed the basics.  Mind you i have not searched our forum yet to see if   someone here has already done the conversion. I searched Ebay and Amazon for a complete kit and found one for less than  $50. It included the handlebar mounted clutch master cylinder, a slave unit with fittings and a plastic covered braided steel hydraulic line. There was also a matching brake master cylinder.  Both had adjustable positions for the levers along with appropriate switches. I grabbed a stock clutch cover to see how the slave cylinder could be positioned to pull the stock Honda lever on the cover.  The slave unit is threaded on the end with the pull rod which is also threaded for a ball type clevis. The clevis slipped right into place of the cable end perfected but the thread diameter of the slave unit was small than the opening on the clutch cover housing. I decided to try putting a stock adjuster from an old cable onto the slave unit and i was pleasantly surprised that the thread pitch was the same, allowing the identical adjustments we'd utilize with a stock cable. Wow!!! At the moment i have not put the cover on an engine with the full stock clutch and springs inside. I  plan to mock everything up when i get time and add fluid to the system to do a bench test. My main concern is will the little slave cylinder have sufficient pulling capacity to move the stock lever with heavy duty clutch springs. To be on the safe side, i researched Amazon for a slave cylinder that has a larger piston. This one is 14mm. I bought a larger one for $25 that has a 19mm piston. I'll swap the bigger one as I'm setting everything up and hope for the best. My main purpose here is to reduce lever effort and eliminate moving parts. My brother is having some issues with the current lever so I'm trying to make itveasuer for him without compromising the use of the heavier clutch springs.  I'll let you know how it goes
Re: Hydraulic clutch conversion for the mono shock dragbike. Will it work??
« Reply #1 on: September 19, 2024, 10:18:13 PM »
There are posts here regarding hydraulic clutch conversions, Frank. ;)
Offline dragracer
  • CB750F Dragbike
« Reply #3 on: September 19, 2024, 10:24:31 PM »
I figured it had already been done at some point. I'll probably delete my post then since likely won't be contributing anything to help the group. I should have searched first. 😅🤣
Offline dusterdude
« Reply #4 on: September 19, 2024, 11:36:35 PM »
Keep posting frank,we are interested
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #5 on: September 20, 2024, 04:01:21 AM »
Oh don't delete it! It can be helpful to anyone thinking of doing it to their bike, besides you are using a pull slave without major modifications to the original clutch cover working design as apposed to the push slave of the link. I'm interested in this style to be able to make clutch adjustments as necessary.
« Reply #6 on: September 20, 2024, 09:51:54 AM »
Hasn't Godfrey's Garage done one or two hydraulic clutches, seem to recall photos... Maybe reach out to Mark...if he has experience with them he could be of help guiding you if you encounter an issue he has overcame with one...
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #7 on: September 20, 2024, 01:51:52 PM »
TLR has a hydraulic clutch and when it comes to launching a bike it's absolutely useless compared to a cable operated clutch. If hydraulic clutch was better I think guys at Speedway GP would have one as they are the second hardest launching motorcycle racers I can think of. No feedback at all at the lever.
Offline Leino
  • Not much of an
« Reply #8 on: September 20, 2024, 02:07:01 PM »
My opinion, yours may be different  ;D
« Reply #9 on: September 20, 2024, 04:33:39 PM »
Haven't you gone the 1/4 mile a couple of times? I can't remember. ;)
Offline dragracer
  • CB750F Dragbike
« Reply #10 on: September 20, 2024, 09:53:38 PM »
90% of the weekend warriors that drag race modern bikes are factory equipped with hydraulic clutches. They even use them with mallet magnet releases off  a button and a 2 step. Many are set up with Gen 2 MTC multistage clutches. I'm not certain this style slave systems will release quick enough but i want to give it a shot since it requires no machining thus far and it was cheap. Nothing ventured, nothing gained. I'll report back as this progresses. Its not a must do project at the moment so I'll pick at it when nothing else is important. I'm hopefully it will work as intended.
« Reply #11 on: September 21, 2024, 08:28:13 AM »
I’m betting your the guy that’ll definitely get her (hydraulic clutch) dialed in…
Offline Leino
  • Not much of an
« Reply #12 on: September 21, 2024, 08:49:09 AM »
You are absolutely right, I'm oldskool  ;D
To me a modern bike is not early 80's  ;D
Offline Leino
  • Not much of an
« Reply #13 on: September 21, 2024, 08:50:04 AM »
I tried it a couple of times without much success but yes, you have a good memory  ;D
Offline dragracer
  • CB750F Dragbike
« Reply #14 on: October 02, 2024, 12:44:59 AM »
I've been trying it for years and I'm still not worth a damn at the sport!!!
« Reply #15 on: October 02, 2024, 03:09:57 PM »
When I look at somebody drag racing a bike I look to see how comfortable ( which is a product of experience) on that bike. Frank.....you look like you've been riding that F since you were 10 years old. You look loose but ready to pounce. I used to see that in Stetson.....you could tell he has thrown a leg over his bike a million times. ;) ;)
Offline spotty
« Reply #16 on: October 02, 2024, 07:27:55 PM »
ive got all the same parts to do mine, but i'm using a vmax m/c. i shall be following along to see how it goes. good luck
i blame Terry
« Reply #17 on: October 03, 2024, 07:51:45 AM »
Frank is just a little modest
« Reply #18 on: October 03, 2024, 11:45:12 PM »
Ha, ha, ha.... ;) ;)
I am still in the 80's as modern bikes.
When I saw the beautiful CB1100F -83 with round headlight and no fairing, a newer bike, almost modern. ;) ;)
Maybe the real "modern" bikes have fuel injection and well working brakes, ABS. No wires at all, "throttle by wire" means no wire... Same with clutch.
Next step, ride modes.....
Offline MisterKnife
« Reply #19 on: October 04, 2024, 08:14:52 AM »
I'm using a hayabusa master clutch and a slave cylinder for my CB550, works like a charm!
« Reply #20 on: October 04, 2024, 06:13:48 PM »
I'd love to have a hydraulic clutch on my bike....I need a lot of spring for my engine. It's getting hard to work the older I get.
Offline dragracer
  • CB750F Dragbike
« Reply #21 on: October 05, 2024, 11:11:58 PM »
The one potential draw back for me as a dragracer is the release speed, and full engagement of the clutch. I'm still trying to utilize the stock cover with components as factory designed. Basically I'm only  eliminating the stock mechanical clutch lever and cable. Using the pull type slave cylinder in this kit,  there could be a mechanical disadvantage versus a slave cylinder pushing directly against the lifter plate. I'm also trying to make this as simple as possible without having one off components by utilization of an easily attainable kit from either Amazon or ebay. I may get lucky and it works out perfectly for me and other home mechanics interested in an easier clutch lever pull when using medium to heavy duty springs for larger than stock engines.
Offline dragracer
  • CB750F Dragbike
« Reply #22 on: October 05, 2024, 11:22:41 PM »
I think i mentioned this in my opening post, but the kit has adjustable levers. This can become an important factor for me when racing because i can taylor my lever release position with the actual initial clutch engagement/movement of the  bike to help with rider reaction times.  There's no advantage to having that lever against the bars if the release point is at the end of travel.
« Reply #23 on: October 06, 2024, 12:59:57 AM »
My K6 has the harder Barnett springs. Middle number -66-. Slips with -56-.
Dog leg style lever helped. The finger torturing clutch. Teflon spray in cable.
Much nicer feel for brake too. Nicer shape/profile.
My K2 got also a set. Vintagecb750 has.
Here stock clutch lever under to show  the difference.
« Last Edit: October 06, 2024, 01:04:25 AM by PeWe »
« Reply #24 on: October 06, 2024, 06:17:25 PM »
 I'm thinking I accidentally put valve springs in the late clutch in my Rat Race bike. L0L! Dang they're hard on an old worn out hand.
