Author Topic: Float Bowl Gasket Frustration  (Read 3188 times)
Steve B
« on: September 06, 2006, 03:12:24 PM »
Is there a good trick to keep them in place as you manoeuvre the bowl back into place?
Or, do we just put 'em on top and hope they stay there?
Mine always move and it seems to take many attempts to get it right (and I've done it more than just a few times...)   ???
kaysystems
Re: Float Bowl Gasket Frustration
« Reply #1 on: September 06, 2006, 03:18:16 PM »
You can stick 'em on the bowl with a little vasseline
David
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: September 06, 2006, 03:22:22 PM »
Same issue a few weeks back.
I put a smidgen of grease off the grease gun on my finger and put a very tiny amount on the bastards.
It kind of let them stick to the carb as you put the 2 pieces together.
Thought of vaseline, but couldn't find any and I also thought it might react badly with the rubber.
Get it right the 1st or 2nd time or they then become slippery all over ::)
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3 on: September 06, 2006, 04:15:23 PM »
Not a job to be done when you're feeling frustrated, for sure. Otherwise the darn things end up being hurled into the darkest recesses of the shop. Don't ask.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline chrislib
« Reply #4 on: September 06, 2006, 04:21:24 PM »
Chapstik works well, and the gaskets won`t stick if ya ever have to take it down again.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
« Reply #5 on: September 06, 2006, 06:27:28 PM »
I use a simple glue stick you can buy at any Supermarket. It is made for paper but it has enough hold to keep them in place, and allow them to seat on themselves when installed.
Steve B
« Reply #6 on: September 06, 2006, 07:21:28 PM »
Thank you. My wife is now suggesting KY?   :o
Offline nickjtc
« Reply #7 on: September 06, 2006, 07:31:45 PM »
Bit too runny?
1977 Suzuki GS750
ScottB
« Reply #8 on: March 22, 2007, 05:50:13 PM »
After reading this thread I tried the Vaseline idea... not a good one.  My carbs are leaking so I am in the process of taking the bowls off and on every other day.  On the second time of reinstalling the gaskets I noticed that they had stretched out and will no longer fit into the grooves of the bowl.  Anyone have concise measurements for me so I can try and find them locally?
Offline hymodyne
« Reply #9 on: March 22, 2007, 06:01:10 PM »
after a thorough cleaning of the groove for the gasket ring, I've taken a really, really, small daub of super glue in the four corners of the bowl. I  usually apply it with a sewing needle.
hym
ScottB
« Reply #10 on: March 23, 2007, 02:03:43 PM »
I found these gaskets on Ebay from Sirius.  $17.95 with the "buy it now" but they should prevent having to use any sort of adheasive.
 http://cgi.ebay.com/ebaymotors/HONDA-CB350-F-CB400-F-CB500F-CB400F-FLOAT-BOWL-GASKETS_W0QQitemZ280096022755QQcategoryZ35597QQrdZ1QQcmdZViewItem
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: March 23, 2007, 03:25:39 PM »
This is a common problem with aftermarket float bowl o-rings, they absorb gas and expand.  Let them sit out overnight or use a hair dryer on them for a while and they should shrink back to normal size.
I've had good success with using short strips of scotch tape to hold the o-rings in place.  Put a strip near each corner with most of the tape hanging outside the bowl.  Tighten down the bowl screws part-way, so they're holding the o-ring, but not too tight.  Then pull out the strips of tape and tighten the screws the rest of the way.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #12 on: March 23, 2007, 03:30:57 PM »
wish my wife was suggesting KY...and not the state... :P
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
ScottB
« Reply #13 on: March 24, 2007, 10:00:38 AM »
Gordon - Thanks for the heads up and the tape idea.  Looks like I will have an extra set of gaskets.
