Author Topic: Air screw to reduce decel popping?  (Read 6221 times)
Offline Bigmant
« on: January 02, 2025, 12:34:08 AM »
Hey gang!
Air screw question here. I’ve got a 4 into 1 exhaust and pods. The bike has great power and is synced well. But under power on deceleration, there is quite a bit of popping I’d like to see if I can clean up. This is possible with the air screw correct?
According to this picture that should be the case, so unscrewing it an 1/8th of a turn at a time should hopefully help right?
« Last Edit: January 02, 2025, 07:14:16 AM by Bigmant »
‘73 CB750 K3 Owned by my father and now me
Build post: http://forums.sohc4.net/index.php/topic,190516.msg2216419.html#msg2216419
Offline M 750K6
Re: Idle screw to reduce decel popping?
« Reply #1 on: January 02, 2025, 01:52:29 AM »
Deceleration popping is usually a lean symptom. Needs richening up, so screw it in a little. There is some debate on whether idle screw in or out richens the carb. I am finding it behaves like an air screw, out for leaner, in foor richer.
There's a sticky at the top of this forum section, for help on running pods. Put me off ever trying!
Online newday777
« Reply #2 on: January 02, 2025, 02:24:50 AM »
Hey gang!
Idle screw question here. I’ve got a 4 into 1 exhaust and pods. The bike has great power and is synced well. But under power on deceleration, there is quite a bit of popping I’d like to see if I can clean up. This is possible with the idle screw correct?
The Idle Screw?? Don't you mean the air mixture screw??
The idle screw only adjusts the idle rpm(the big single screw)
The 4 small pilot mixture screws (on each individual carb) adjust idle air mixture (or idle fuel mixture on PD carbs) depending on what bike you are working on???(you didn't say)
« Reply #3 on: January 02, 2025, 03:45:56 AM »
Which bike and carbs?
My CB750 K6 with 836, stock carbs  plus pods with 4-1 had the air screws opened 1/2 turn from closed.
Pilot jets stock 40.
Offline Bigmant
« Reply #4 on: January 02, 2025, 07:15:23 AM »
Hey gang!
You’re right! Words mean things! Air mixture screw, not idle screw. I also changed the original post so it’s not confusing. Bike is in my signature!
Offline Bigmant
« Reply #5 on: January 02, 2025, 07:23:25 AM »
Bike in my signature, but similar to your setup minus the 836. Id have to go back and see what I ran for the pilot jets, but if I open the air screw MORE, theoretically that should make me run leaner and help clean up the unburnt fuel detonating in the pipes on decel right?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: Air screw to reduce decel popping?
« Reply #6 on: January 02, 2025, 07:28:42 AM »
An exhaust leak especially around the collars will cause popping on deceleration.  Fresh oxygen sucked in will let any unburned fuel ignite and pop!
Is the popping coming from the intake or exhaust?
Intake popping could be caused by advanced timing  or the advance mechanism not retracting.
I don't believe the air screws have anything to do with popping.
« Last Edit: January 02, 2025, 07:35:32 AM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #7 on: January 02, 2025, 07:43:27 AM »
+1...I have experienced this.  Does your exhaust have a baffle? If no, I would add one.
Offline Bigmant
« Reply #8 on: January 02, 2025, 08:35:58 AM »
I can double check all the collars, but I’m fairly sure they’re fine. And no baffle on this old girl!
Offline Bigmant
« Reply #9 on: January 02, 2025, 08:40:08 AM »
Hmm not sure how you’d hear if it’s intake or exhaust while riding. As for the timing, I have electronic timing instead of the points, so I think we can rule that out.
As for the air screws, my thought process is that if you add more air at idle and lean out the mixture, when you close the throttle bodies after being at 1/2 throttle or so, it will help cleanup the rich mixture that is still in the exhaust. Somewhat how the picture above describes. I could be wrong though!
« Reply #10 on: January 02, 2025, 10:20:34 AM »
Easy to test. Bring a screwdriver with you when riding to change the air screws. If the air screws are opened 1 turn. Test 1/2 for next ride.
Adjust during the ride if not better.
I have done many rides with a screwdriver adjusting air screws or fuel screws depending on which bike (carbs).
I have had banging on decel if giving heavy throttle direct followed by throttle roll off.
This thanks to carbs with acc pump with possible too long stroke making it worse.
« Last Edit: January 02, 2025, 10:58:05 AM by PeWe »
Offline Bigmant
« Reply #11 on: January 02, 2025, 12:17:40 PM »
Agreed, easy enough to do! I plan on it. My question was more, which way makes more sense for the screw? Out to lean out the mixture going through the exhaust or in to make it more rich?
« Reply #12 on: January 02, 2025, 02:02:20 PM »
On the CB750 with roundtop carbs, out is richer.
The popping happens often with pod filters. If you can determine WHICH cylinder(s) it is, often done by starting with fresh sparkplugs and riding for about 5 miles or so while inducing the situation, then you can tinker with that cylinder.
Also: on the 750 with very hard intake rubber hoses, it will leak air past the slide, right at the nozzle of the carb. This will also cause popping, and requires a better seal. That often entails new hoses. Don't get hoses from 4into1 is my advice: they don't fit, don't seal, and won't give you back your $$, either ;)
Offline Bigmant
« Reply #13 on: January 02, 2025, 03:45:11 PM »
Thanks Hondaman! So out is richer, interesting. And I’ll make sure the boots are tight. I think they’re from 4into1 from 2 years ago or so… sorry!
« Reply #14 on: January 02, 2025, 07:24:49 PM »
Check 'em close for leaks: we've seen several builds with those here recently that didn't seal for beans. ;)
Offline Bigmant
« Reply #15 on: January 02, 2025, 07:46:15 PM »
Do you have a brand or a link to ones you prefer?
Offline M 750K6
« Reply #16 on: January 03, 2025, 01:22:51 AM »
Deceleration popping is something regularly encountered with replacement exhausts on Harleys. It is the exhaust causing the bike to run LEAN, not rich. Just like an air leak is leaning the exhaust mix. The exhaust has enough air to ignite unburnt fuel in the pipes.
I hear Hondaman regarding slow mix screw in for lean, out for rich. Respect to you for your knowledge here, but my experience has been out = lean on the pre-PD / roundtop carbs. Just like an air screw. Do what I did, experiment with small adjustments both ways and see what works.
Online newday777
« Reply #17 on: January 03, 2025, 02:58:00 AM »
Genuine Honda or from Yamiya is what he recommends. Aftermarket are junk.
South Sound Honda usually has the best price
#8 & #9
https://www.southsoundhonda.com/--xpartsstream#/Honda_Powersports/CB750KA_(76)_750_FOUR%2c_JPN%2c_VIN%23_CB750-2540001_TO_CB750-2575894/CYLINDER_HEAD/b3d05c73-22e7-4620-b018-132301d96b6e/58a86ed9-04d7-422c-b0e8-d2356946658a/y
« Reply #18 on: January 03, 2025, 06:46:27 AM »
+1 Yamiya for the source
Offline Bigmant
« Reply #19 on: January 03, 2025, 07:20:39 AM »
M, so would you suggest going more in and therefore more rich to see if that has any effect on the popping?
Offline M 750K6
« Reply #20 on: January 03, 2025, 08:46:49 AM »
Hi, yes, i would. At deceleration, you are on no throttle. So, you are correct that the combustion is from the carb's idle circuit, assuming no significant leaks. My experience with deceleration popping on Harleys was curing them by richening the mixture. I was sceptical, as it seemed counter-intuitive to allow more fuel in. The advice I was given by multiple sources was clear, though. When I followed it, it worked.
As to whether screwing in or out is the right way, I found a fraction out reduced sooty plugs on 2 of mine, having previously tried a fraction in, which only made them sootier. So, my experience with my roundtop 750K6 carbs, the screw works llike an air screw, where out=leaner. But, advice on here, particularly from Hondaman (who no argument, is clearly very experienced, helpful and expert), suggests the screw is not an air screw, but works more like a fuel screw (I.e. the opposite way, or out=richer). The UK SOHC forum takes the view the same as my experience,  the screw works like an air screw and out=lean, in=rich. Confusing, so I would suggest you try 1/8th in from current and see how you go, knowing I may be wrong and if not improved then try 1/8th out from current. Luckily, it very easy to experiment 👍.
« Reply #21 on: January 03, 2025, 09:13:14 AM »
  So, to sum it up, the answer is a definite maybe, one or the other unless it's either the intake or exhaust leaking.
  The copper washers can also be leaking air if the exhaust flanges have been off, and they weren't replaced.
« Reply #22 on: January 03, 2025, 10:45:58 AM »
Absolutely!
There's also the pipe length, if too short, and the equalness (or not) of the intake filtration action.
And if the float bowls in the carbs are all the same depth.
And if the fuel is flowing properly into all 4 carbs, especially in the 2-hose-feed versions.
And...
« Reply #23 on: January 03, 2025, 01:21:47 PM »
 Sorry if this is a thread Hijack Bigmant,
As a plumber that spent considerable time chasing air bubbles out of hydronic heat systems, I am still astonished at the action of the "two hose" petcocks. First, one hose flows, then the other flows. I observed this with both clear tube and also inline filters which I know are problematic. A couple years ago I've posted video of a no flow situation through an inline filter on a one hose petcock. I could blow air into the mostly full tank, but nothing flowed back out.
« Last Edit: February 11, 2025, 11:13:41 AM by Don R »
Offline Bigmant
« Reply #24 on: January 03, 2025, 03:14:03 PM »
As a plumber that spent considerable time chasing air bubbles out of hydronic heat systems, I am still astonished at the action of the "two hose" petcocks. First, one hose flows, then the other flows. I observed this with both clear tube and also inline filters which I know are problematic. A couple years ago I've posted video of a no flow situation through a one hose petcock. I could blow air into the mostly full tank but nothing flowed back out.
Not a hi jack at all! The technology behind carbs NEVER ceases to amaze. Some guys much smarter than us were some brilliant folks to make it all work!
