Author Topic: Finally off to the printer!  (Read 2409 times)
« on: March 04, 2025, 09:40:46 PM »
...whew...
I finally wrapped up the 500/550 book (again) and sent it to the printer today for the pilot copy. The first attempt was a disaster after the PDF converting service dropped the photo resolution down so far that the pictures looked like something from an old 1950s newspaper copy, but using colored dots instead of shades of grey dots :(  Most of those interior pictures were useless, and all of the indicating arrows that followed the text just disappeared (but the covers were nice and clear...?). That was 3 weeks ago. I should get the first proof copy late next week, along with the final pricing.
A thousand thanks to all of you who sent me pix for the 500 and 550! I'll post the reference along with the other book in the Site Supporter's section: a portion of the sales from this one will also go toward these forums, like has My CB750 book. They are, after all, in support of SOHC4.com/net!
Re: Finally off to the printer!
« Reply #1 on: March 05, 2025, 01:49:16 AM »
Congratulations Mark. Hoping that the pictures turn out well this time without any problems 🙏
Offline Alan F.
« Reply #2 on: March 05, 2025, 08:18:31 AM »
Offline jakec
« Reply #3 on: March 05, 2025, 08:41:21 AM »
are you laying out the book yourself? are you using indesign? you should be able to control what's exported and the loss rate (should be none for a print book). I know it's not your first book, just wondering.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
« Reply #4 on: March 05, 2025, 09:33:52 AM »
Yep, myself: the problems the first time came up from conversion errors between the 3 stages. I wrote it in Word (primarily for its picture-handling abilities and fully-embedded fonts) and then stripped all the edits (because the file got so big that Word couldn't save it) to keep the cohesion. Using other editors doesn't make it simple to stay on topic around an object (like a picture) because of the way those software's authors store things. For example, some of them separate the object (drawing, photo, block item) from the text, losing control of how a topic might be blocked onto a page: it just lets the words run off to wherever they will fit. I find that unacceptable when writing manuals (which I did for automation engineering for decades) that are intended to teach someone who knows naught about the topic at hand how to understand that topic. If Word has always done just one thing well, it is that it lets you control where the object is relative to the text for it. (Although I do wish Microsoft would leave well enough alone and stop having programmers who don't write actual sentences and paragraphs be the ones who control the layout of the toolbars...).
Then Adobe's Photoshop lets picture editing hit a high note. The only real troubles show up when the final script is being converted to (this week's version of) PDF files, which are essentially a collection of pages of pixels. The resolution arguments that ensue between the different formats (text, font, photos, drawings, etc.) is where the troubles erupt because not all programs see the page you're using in the same way, and it causes distortions in both page layouts and photo & drawing linearities. It gets really messy, probably like running politics in a governing body? Everything becomes an argument whether it needs to be, or not.
Offline jakec
« Reply #5 on: March 05, 2025, 10:44:52 AM »
When you export to pdf the documents should retain their editability and all text should be "smart" as well as images retain ability to resize and move around. "photoshop pdf" is another thing altogether, I'm not really a fan of photoshop.
I don't know what people usually use for books, I've used indesign a lot but I think it's mainly used for magazines, although I have personally made documents in it that are 80-100 pages, mostly images. Does word imbed the images instead of linking them? That's probably why the file becomes too large.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #6 on: March 05, 2025, 04:47:23 PM »
In Word (which is somewhat unique when compared to other editors - it makes me miss Wordstar...whose keystroke commands Microsoft stole in 1990 and embedded into Word...) the photo images are located by supplying the text coordinates, character archetype and the line format of the 0,0 dot location of the image. In opposition, Wordstar would map the location of the image's 0,0 point and then store the picture in a separate part of the file (at the end, with a sequence number, before the file-end buffer). Wordstar at first didn't save the original picture (or object) size if you trimmed it, at the end it did, though. In Word it saves the image as its full size until you "compress" it and shear it, which then sets the size to whatever you trimmed it to be and ejects the rest of the pixels of the image to shrink the file. This has to be done before 'flattening' it, which then applies any paste-on editing done to the pictures by appending the (x,y) and (object definition) of, in the case of this book, the arrows in the pictures that point out things. The printer hates those...mostly because different flavors of .PDF handle them differently, and Word has used some 8 different methods since the first Windows-on-DOS days, so the final consolidation becomes problematic. That's what I learned since 2 weeks ago...
The original definition of "PDF" in the 1970s world of computing was "Pixel Data Format", defining how dot-matrix printers hit paper with pins (which came directly from the old color TV onscreen painting methods), until ADOBE came along with their "Portable Document Format" term. I remember when there was a battle headed to court over the "PDF" usage and definitions, but this was in the economic death spirals of the 1980s when Microsoft - made when Gates stole cP/M from the public domain, added a serial port handler and floppy-disc manager to it and renamed it "Disk Operating System" and sold it to IBM (which is 100% illegal to do, BTW) - stepped in with tons of $$ and forced it into their control. That's how one company, Microsoft, nearly destroyed the usefulness of the PC until (strangely enough) Europe came to its rescue with Linux. Which I use, and am far happier with. I like running virtual Windows in Linux, which stops all the hardware-stealing corruptive crap that Windows does: it runs faster, with less stalling and crashing, inside Linux than it does on any of my other 21 computers.
Offline beemerbum
« Reply #7 on: March 05, 2025, 05:01:23 PM »
Makes me wish I had 500 or 550. Just stuck with three beautiful 750's. Congrats on the book. Wishing you abundant sales
« Reply #8 on: March 05, 2025, 06:57:26 PM »
Thanks, Beemer!
I don't think there are as many 500/550 riders out there or in the forums, but the revenues will help keep this cool place running!
Offline Aceon
  • 1977 CB750K
« Reply #9 on: March 05, 2025, 07:08:29 PM »
Congrats on the next book! Just wanted to take the opportunity to thank you personally for the writing the CB750 version! It's been an invaluable resource in my engine rebuilds and I constantly reference it. I really don't know if I would've attempted it without such clear instructions. Thanks Mark!
« Reply #10 on: March 05, 2025, 07:52:56 PM »
Thanks, Beemer!
There might not be but I for one of those people that don't have a 500/550 will buy the book to have on hand and peruse through just incase I get enough room to get one to put together or refresh at some point in time. I have often thought it would be fun to have one because of the power to weight ratio.
« Reply #11 on: March 05, 2025, 08:40:45 PM »
Thanks, Beemer!
They are fun to ride, and smooth as silk when tuned up. :) There's also a lot of "hidden" power in the 500/550, for reasons cited in the book, and which can be...adjusted in the rider's favor...so long as local (emissions) laws don't forbid it. I think everyone who's tried to hotrod the timing per that collection someone made called "The thoughts of Hondaman" (who did, that, BTW?) that doesn't contain the whole story of what is needed has sent me emails asking why the engine hangs in high idle, or got harder to start, or had a bigger 'flat spot', etc., so it's long been on my mind to try to put out the whole story of how that happens with this design (and what to do about fixing it). The 500/550 engines all lack sufficient spark angle, all due to emissions laws of the era (just like the cars of then).
The engines of the 400F and 350F are much the same design as the 550 but for some minor differences on the primary shafts and in the gearboxes, so I think it will help with those bikes, too. But, unlike Chilton, I am not callous enough to those differences (especially carburetors!) to say the book will cover all 3 types like theirs pretends to do. They do look very similar when taken apart for rebuilds, while the later-version 400F has the superior carbs for high RPM power between the first-year and the later ones. Maybe I'll take some pix when I get to do my long-languishing CB350F in the shed: I think I have finally found all the parts for it except the throttle cables. They are pretty ratty on it, now. Then maybe I could make a 1/4"-thick book that says things like "per My CB500/550 Book page (xxx)" when it comes to those thing that are the same? It would be fun to try. :)
« Reply #12 on: March 06, 2025, 03:51:01 AM »
Yes they are fun.
I remember in 1977 going up to the track at Loudon(Bryer Motorsports park then) to watch some of our guys from the shop racing in the AAMRR races. In one of the races there was someone on a hopped up 550 that was eating the 750s for lunch because of it's better handling. This was prior to the 650 so he had aftermarket engine parts and fine tuning that made the difference.
« Reply #13 on: March 06, 2025, 06:45:26 AM »
Good to hear the book is really close.
« Reply #14 on: March 06, 2025, 06:04:54 PM »
Glad it helped!
« Reply #15 on: March 06, 2025, 06:15:44 PM »
Yes they are fun.
I have seen the CB500 kick 2 "built" 750s in a full roadrace, circa 1972, on a 3/4 mile dogbone-shaped asphalt track (loose asphalt here and there). That bike had a cam and it ran with the stock airbox, no air filter, and a hose attached to the intake of the airbox that was routed back forward into the area below the carbs, behind the engine. That guy could hit [what sounded like] 12K RPM on the longer straights, and it was geared into the basement. His idea was (correctly) that the air behind the engine was at higher pressure than anywhere else on the bike, and it had time to cool off in that long, circuitous trip back to the carb mouths. He ran 022/a carbs with his own jetting and float depth recipes and a full roadrace fairing (with lousy paint). I only met him once, nice guy, but he never showed up in our circuits again. His pickup truck had Illinois plates (we were in southern IL), too. Smart guy. I asked him if he had modified his spark curve and he answered something like , "Oh, yeah...", but didn't mention details. The power is there, but it takes quite a bit more work to get it than from the 750.
« Reply #16 on: March 06, 2025, 07:25:10 PM »
Yes they are fun.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #17 on: March 08, 2025, 06:28:25 PM »
Congrats, Mark.
I'm sure it'll fly off the shelf.
Best wishes!
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #18 on: March 08, 2025, 07:23:21 PM »
Congrats, Mark.
Best wishes!
How are you doing after that crash?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #19 on: March 10, 2025, 03:04:45 AM »
I'm excited for this!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline drodg33
« Reply #20 on: March 11, 2025, 07:18:53 AM »
I am really excited to have this and cannot wait to purchase one.  I own a 72 CB500 and a 73 CB350F so the book will come in handy.   Looking forward to this.
« Reply #21 on: March 11, 2025, 11:54:18 AM »
I also have a 73 CB350F! Coolest bike Honda imported to the USA, IMHO (did you know Honda made a CB250F of it in Japan - all 17 BHP of it?). While I'm tempted to make another book while I rebuild it, I don't think it would sell very much as there aren't a lot of them around. Maybe if I had a 400F (but there's 2 types of those) it might make more sense? Maybe if I made it a smaller book it wouldn't be so expensive: the grease-resistant pages and covers are pricey.
« Reply #22 on: March 11, 2025, 01:05:04 PM »
Congrats to you, Mark. I don’t have a 500/550 at the moment but something tells me I’ll still want the book! Cheers, J.
P.S. my ‘78 550K was my first “big” Honda motorcycle. It came after my 1970 Triumph T100S (500 twin, single carb) and I was blown away. The only thing I changed was the bars. My wife wanted higher bars of her 400F, so I swapped them. Both fabulous machines. Always on a Honda since.
« Last Edit: March 11, 2025, 01:08:07 PM by BenelliSEI »
« Reply #23 on: March 11, 2025, 06:29:40 PM »
Wow, you had a '78!? I've only ever seen 1 in real life myself, so they are like rocking horse poop to me. They are (with OEM pipes) faster than the "F" model of that year due to the larger volume of the pipes, but needed the needles lifted a notch to make the midrange stronger - IF your local emissions gendarmes let you do it.
« Reply #24 on: March 11, 2025, 08:04:18 PM »
It was part of a trio. I painted my wife’s 1977 cb400F to match the 1978 550K and 750K.
« Last Edit: March 11, 2025, 08:07:00 PM by BenelliSEI »
