Author Topic: CB500 Transmission Noise  (Read 1350 times)
Offline jaytee-nz
« on: February 25, 2026, 03:22:27 PM »
Just took my recently finished 1972 CB500 for a test ride and there is a problem.
There is a constant "whine" coming from the transmission (or at least in that area) in all five gears. However, it only occurs under load. As soon as I back the throttle off, the noise / whine goes away. I don't believe its chain related as the chain is new and the sprockets are in good condition.
When I assembled, the engine I checked the gearbox bearings and they spun nicely without any growling noises. The gears looked in nice condition with no excessive wear (that I could see anyhow).
Before I remove and strip the engine, does anyone have any suggestions as to what the cause of the noise is?
Also, the clutch works fine but the gear changes are a little sticky (up and down). Don't think this is the issue, but thought I would add this just in case.
Re: CB500 Transmission Noise
« Reply #1 on: February 25, 2026, 10:55:22 PM »
is it loud and obviously not normal,they all will whine somewhat,if its bad it may just be a bearing?
« Reply #2 on: February 25, 2026, 11:04:20 PM »
Primary shaft bearing? Never seen bad ones but anything is possible
Offline jaytee-nz
« Reply #3 on: February 25, 2026, 11:05:49 PM »
Yeah, it is quite loud Dave - definitely more than normal. I'm picking a bearing too.
Offline jaytee-nz
« Reply #4 on: February 25, 2026, 11:07:42 PM »
Thanks Bryan. That bearing did go through my mind, especially as it's only making a noise under load. As soon as you button off, it stops.
« Reply #5 on: February 26, 2026, 09:20:04 AM »
I'd guess the primary gear's bearing, too.
Was there a big "burr" on the "C" transmission shifting fork, and did you grind it away? I've seen those make a high-pitched noise when pulling a load (but on very high-mileage engines, like 40k+ miles' untouched inside).
« Reply #6 on: February 26, 2026, 01:59:33 PM »
Before tearing into anything have you checked drive chain/sprockets alignment? If the rear axle has shifted you can get some real chain whine….
Offline jaytee-nz
« Reply #7 on: February 26, 2026, 03:16:39 PM »
It definitely sounds a like a bearing issue. A friend of a friend who knows these engines very well said that shaft bearing behind the clutch basket is a known "whiner" if worn.
I'm about to remove the engine and perform surgery so I'll come back with the results.
Offline jaytee-nz
« Reply #8 on: February 26, 2026, 03:18:23 PM »
Yep, did that Benelli when I fitted the new chain (I hoped it was a chain issue but it wasn't).
Offline jaytee-nz
« Reply #9 on: February 26, 2026, 08:51:37 PM »
So it looks like Bryan gets the prize. Both primary shaft bearings are in bad shape with one worse than the other.
I vaguely recall looking at the worst one during reassembly thinking it was maybe suspect, but stupidly thought "she'll be right" as we say in NZ !
The worst one is just a common 6205 bearing but the other larger one has some oddball numbers on it. I'll visit my local bearing supplier on Monday and see what they can do.
I've checked and double checked all the transmission bearings and they are fine.
Thanks to everyone for helping out.
Offline M 750K6
« Reply #10 on: February 27, 2026, 02:24:20 PM »
Well done for letting us know the outcome. How many miles on the bike?
« Reply #11 on: February 27, 2026, 02:49:53 PM »
Thats the first set of those bearings going bad i have heard of, was the bike stood for a long time doing nothing?
« Reply #12 on: February 27, 2026, 03:12:48 PM »
I have seen a CB550 (similar arrangement) with those bearings bad when the owner ran some very-high detergent motor oil in it and rode mostly interstates and freeways to his work. He mentioned how he "...noticed foam on the dipstick..." when he checked the oil when he got to work several days, because he had also noticed a "...small power drop..." after hitting freeway speeds with a cold engine, then it would slow down a little as it warmed up (lost some power). He blamed the carbs: I suggested he stop using that oil, but he didn't. This is an important thing, especially with today's oils that are low (or void) of zinc and contain high amounts of detergents. Make sure your oil is low-detergent and add some ZDDP for long, happy results. ;)
Offline jonda500
« Reply #13 on: February 27, 2026, 04:46:28 PM »
I had to replace a bearing in my 400-4 - I suspect I actually caused it to go bad by accidentally leaving a paint brush bristle caught inside it...  my mechanics teacher used to say "cleanliness is next to godliness" when working inside engines.
John
A starter clutch thread:
« Reply #14 on: February 27, 2026, 06:19:05 PM »
John
A string from a frayed set of coveralls can do the same thing.
I won't tell how I know this...
Offline jaytee-nz
« Reply #15 on: February 27, 2026, 07:31:40 PM »
Unknown I'm afraid as it came with no speedo.
Generally, the engine was very clean inside and doesn't look like it's done high miles.
Offline jaytee-nz
« Reply #16 on: February 27, 2026, 07:36:48 PM »
I don't know what oil has been run it previously, but I used genuine dinosaur 20w50 oil. Having said that it's only done about 5 miles with this oil, due to the problem.
Offline jaytee-nz
« Reply #17 on: February 27, 2026, 07:38:24 PM »
Unknown as it came with no speedo.
« Reply #18 on: February 28, 2026, 07:54:00 AM »
If its clean i would def suspect standing for a while empty and corrosion in the bearing races
Offline jaytee-nz
« Reply #19 on: March 13, 2026, 07:52:08 PM »
Ok, so I decided to replace the roller bearings on the two transmission shafts as well as I didn't fancy pulling it all apart again because I replaced the wrong bearing!
However, when re-assembling the countershaft, I have ended up with a spare thrust washer. I've checked and rechecked the parts book and everything is assembled as per the diagram. My suspicion is that the PO may have added it for some reason (it was a bit clunky to change the gears).
Additionally, the left over washer looks home made as the center hole is not circular - see pic attached.
My question is, is the parts diagram correct or is there another washer, and if so, where does it go ?
« Reply #20 on: March 13, 2026, 09:05:04 PM »
Dont remember seeing one like that, there are "splined" washers that slid on the shaft between some gears and it is recommended to change the circlips plus they need to go the correct way round
Offline jaytee-nz
« Reply #21 on: March 13, 2026, 10:34:38 PM »
Thanks Bryan. Which way round is correct for the circlips?
« Reply #22 on: March 13, 2026, 10:56:46 PM »
The side with the sharp edge faces away from the gear it locates on the shaft.
http://forums.sohc4.net/index.php?topic=86429.0
« Last Edit: March 13, 2026, 10:58:56 PM by scottly »
Offline jaytee-nz
« Reply #23 on: March 14, 2026, 12:01:02 AM »
Great, thanks Scottly.
« Reply #24 on: March 14, 2026, 10:48:20 AM »
He got there first, there is a bulletin about it, if not on this forum its on the uk forum, as are all the bulletins
