Author Topic: plug caps  (Read 3197 times)
Offline hymodyne
plug caps
« on: June 24, 2005, 08:21:17 PM »
while replacing my coils a few days ago, I noticed that the plug caps for cylinders 2 and 3 have longer shafts than those that are on 1 and 4. can someone give me ngk part  numbers for these two different size caps, so I can order the correct ones? I found some on ebay, but there are eight different types offered, ranging in size and shape.
hym
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: plug caps
« Reply #1 on: June 24, 2005, 10:26:26 PM »
I believe they are supposed to be different sizes. mine are. Makes the center ones line up straight and the side ones out the side.
eldar
Re: plug caps
« Reply #2 on: June 25, 2005, 11:15:16 AM »
#2 and 3 are straight and 1 and 4 are a 90 degree bend. You can go to www.partsnmore.com and get new caps. Caps seem to be getting expensive lately. Maybe someone knows a cheaper place.
Cincycaddy
Re: plug caps
« Reply #3 on: March 27, 2006, 02:15:36 PM »
I know this is old, but partsnmore.com is out of stock on the right angle ones, anyone got another source?
On second thought as I read more, the NGK ones are 5kohm, on my cb750k5, I can go without the resistive caps?  And if so, anyone have a link/source for caps and wire?  I think I'm getting lost here looking for specific wire sets/caps.  Guess this is pretty generic cut to fit solid core wires?
Chris.
« Last Edit: March 27, 2006, 02:20:33 PM by Cincycaddy »
endobendo
Re: plug caps
« Reply #4 on: March 27, 2006, 03:35:45 PM »
I'm running Dyna 7mm supression wires with non-resistor caps, Dyna coils and Dyna S ignition.  I also use non-resistor D8EA plugs.  I talked to the techs at Dyna and they said this configuration was fine.  My understanding is that the resistor configuration is mainly to limit radio interference.  It is required to have resistors in Canada and maybe some other countries, but not in the US.  I had one fouled plug in 3 years which I'm not getting exited about.  It sticks in my mind that you use resistor caps you should not use resistor plugs also.  Maybe others can comment on this...
I wonder what it sounds like when I pass people listening to thier Ipods with FM transmitter while at 7000 RPM? :o
Cincycaddy
Re: plug caps
« Reply #5 on: March 28, 2006, 11:24:18 AM »
Cool, I'll look into the dyna coils as well, as I just learned today that the honda wires and coils are all one piece, NOOB still learning, and getting sticker shock at the Honda parts counter $237 for the coils, wires and plug caps OUCH
Offline hcritz
Re: plug caps
« Reply #6 on: March 28, 2006, 11:27:48 AM »
Hey Cincy...
Saw a post here where somone drilled out the old wires from the coil and put in new wires...
Mine are old and don't like getting wet...may give that a try before I shell out that much for coils!
eldar
Re: plug caps
« Reply #7 on: March 28, 2006, 11:29:40 AM »
oem is pricy at honda. atleast they still support our bikes some. most others barely support anything 10 years old.
No do not use resistor plugs AND caps. You will get a much weaker spark.
You can also get coils for a cb900 which use replaceable wires. It is a relatively common mod.
Offline cben750f0
Re: plug caps
« Reply #8 on: March 28, 2006, 11:32:39 AM »
i usd coils form a  vf1000.. they point down, i had trouble with the screw in part of the cb900 coils hitting the inside of my tank when i was trying to fit is.... here is a pic of the coils..peace
eldar
Re: plug caps
« Reply #9 on: March 28, 2006, 11:37:42 AM »
yeah I think there is some modification needed ;D
Offline dusterdude
Re: plug caps
« Reply #10 on: March 28, 2006, 11:39:02 AM »
honda dealer can get the caps.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cben750f0
Re: plug caps
« Reply #11 on: March 28, 2006, 11:42:00 AM »
i couldnt even get them to clear when i cut the mount down, thats why i am useing the VF coils... they are only 3ohm though, so work well with the dyna S..peace
Offline hcritz
Re: plug caps
« Reply #12 on: March 28, 2006, 12:00:41 PM »
Hey Guys...
Has anyone tried an automotive type coil???
The GM coilpacks fire two plugs...and if I remember correctly...are about 1 ohm...
Not sure they would fit...and never considered using one with points...but might be worth a try to see.
I think I have a new one stuck in the parts drawer.
Re: plug caps
« Reply #13 on: March 28, 2006, 12:46:43 PM »
What?  You actually want to hear all those curse words and derogatory remarks?
Could explain why some of the cage drivers are so agressive toward us innocent motorcylists... ::)
eldar
Re: plug caps
« Reply #14 on: March 28, 2006, 12:57:34 PM »
I think they are agressive to anyone in front or even AROUND them! See thats when you need to stuff a small rocket under the rear fender, you can hit that thing when they get too close!!!--------------------------------------------------->>>>>>>>>>>>>>>>>>> cloud of smoke!!!
Offline dusterdude
Re: plug caps
« Reply #15 on: March 28, 2006, 01:32:40 PM »
dayum!!!
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline hcritz
Re: plug caps
« Reply #16 on: March 28, 2006, 01:38:54 PM »
Hey Guys...
Agressive is better than the oblivious 20 year old college coeds with a cell phone and a mascara brush...driving 60 with their knees down the turn lane in their BMW...trying to get to their tanning bed appointment!
Life in a college town!!!
eldar
Re: plug caps
« Reply #17 on: March 28, 2006, 01:56:48 PM »
now I am scared cause I live in a college town!!!! We have 3 relatively large ones! one has over 12000 students!!
Cincycaddy
Re: plug caps
« Reply #18 on: March 28, 2006, 02:01:12 PM »
I already avoid probably 2 accidents in my miata each week on my daily commute, hopefully the straight pipes on the bike will help overcome the stupid drivers around here.
Chris.
Offline hcritz
Re: plug caps
« Reply #19 on: March 28, 2006, 02:06:00 PM »
Nah...between the cell phone and the stereo....they can't hear a nuclear explosion!
Women must have a mascara gene that men don't...If I tried to drive with a sharp pointed brush that close to my eye...the first bump...I'd be blind!<G>
eldar
Re: plug caps
« Reply #20 on: March 28, 2006, 02:18:40 PM »
HA HA HA!!!!! :D
Mascara gene! Does that go with their shopping gene?
Offline crazypj
  • I'm brill, me
Re: plug caps
« Reply #21 on: March 28, 2006, 05:51:52 PM »
Is anyone having problems with CB750/900 dohc coils on SOHC points system? When I was at Honda UK they told us not to use those coils on points ignion bikes as they would burn out. The points bikes have power to the coils while points are closed, CDI bikes have about 4 amp draw on coil but they are only switched on for a few milliseconds
Just wondering
PJ
