Author Topic: Turnsignal state On or Off?  (Read 1348 times)
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« on: October 18, 2007, 09:29:37 AM »
I have a 78 cb780k and ever since I bought it this spring the front right turn signal is constantly on.  The others are off.
They will all flash, but the front right is always on when not flashing.  What it the correct pattern for them?
Offline Steve F
Re: Turnsignal state On or Off?
« Reply #1 on: October 18, 2007, 09:33:37 AM »
I'm guessing that the left front "running light" is burned out.  You should have the running lights on BOTH of the front lights on all the time.
Offline Bodi
« Reply #2 on: October 18, 2007, 09:36:36 AM »
The front signals should have dual filament bulbs, with the less-bright filament on all the time except when flashing (they might also go off with high beams on). You may just have a 1/2 burnt out bulb on the left.
With the standard flasher, I can't think of a way the actual flasher filament in the bulb could stay on when not signalling then flash with the signal selected.
Offline tinyrobot
    • ChiVinMoto
« Reply #3 on: October 18, 2007, 11:07:33 AM »
so the fronts should have "running lights" on at all times but not the rears?  If thats, true then as you guys stated above it must just the bulb in the front left is out.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #4 on: October 18, 2007, 01:07:07 PM »
Yup ;D  two small philips screws are all that hold you back from success ;D
