You described retentioning the cam change perfectly Kit, I warm the bike up first then off with the points cover and slacken the tensioner bolt but not all the way so it falls off as I'm sure the Honda Gods would put some sort of rebuild curse on me and the whole thing would fall to bits.
One thing I did learn early on is don't ever turn the motor using the wee nut in the middle--use the big sucker, I have found just one of my sockets that fits it perfectly.
The books says remove plugs to help turn the motor over but as that is a PITA on my bike it doesn't happen.
The book does say rotate the motor in a clockwise direction which I understand but then it says to tighten the tensioner nut as you rotate?
I think that's only for octopuses who own 650's! try it on your own....impossible springs to mind.
I don't torque wrench the cam adjuster nut just tighten without stripping is good as I know I will have to do it again in a few months time, have fun........
