Author Topic: Andys CB810 K2 -updated 14 Oct 2024 - missing link!  (Read 129026 times)
Re: Andys CB810 K2 -updated 29 Oct: new harness routing questions
« Reply #350 on: October 31, 2023, 02:48:22 AM »
Thanks Per for the detailed info very much appreciated. I already have a pretty good crimping tool so just need to source the connectors.
Cheers
Andy
« Reply #351 on: October 31, 2023, 03:19:53 AM »
Here ya go Andy, lots of connectors to choose from. They have whole kits if you so desire too.
https://www.vintageconnections.com/collections/all
« Reply #352 on: November 02, 2023, 05:41:49 AM »
Thanks Stu!
« Reply #353 on: November 02, 2023, 05:44:19 AM »
Thanks Stu!
Re: Andys CB810 K2 -updated 14 Oct 2024 - missing link!
« Reply #354 on: October 14, 2024, 01:12:06 PM »
Update from last year re: new harness. So far all has gone well and 600 miles later the new harness/new battery/new rectifier is doing just fine with no more electrical meltdowns.
So this weekend I took the K2 out for a Fall ride to CT to see the New England Motorcycle museum - weather was perfect 70F, breezy and blue skies. I had been hearing a weird intermittent metal on metal noise the past few weeks while riding to work (via highway) - sounded like it was coming from under the tank somewhere but couldnt quite pinpoint it and decided it would become apparent the more I rode it  8).....so I set off on this 3-4 hr ride and got about 20 min into it when I felt a clunk/jolt coming from the left side. It was that same noise you when you leave the sidestand down and it hits something when riding so I thought maybe that had been it....continued a mile down the road and i had a 50-60 mph section where I would the bike up to see if I could hear any metal noise and then when I came to the firsts top light it happened again...clunk/jolt....ok not good and time to turn around and head home. I limped home carefully fearing something catastrophic - after all this is the cursed K2 (alternator failures/engine bearing failures/engine head leaks/harness melting at the rectifier etc etc...)....
Got home put the bike on center stand and spun the wheel...quickly discovering the problem....I was missing a link in the chain....it was hanging on by one pin  :( see pics below....
Lucky for me I had a spare X-chain sitting in the shelf and installed that without too much drama and after rivet the link took it for a 14 mile test look - no weird metal-noise, no clunk/jolt...all good! I changed the oil just for good measure (it was due) and found no metal shavings  ;D. So....minor drama this time with the cursed K2 and hopefully the list of failures is getting smaller!
cheers
Andy
Online BenelliSEI
« Reply #355 on: October 14, 2024, 01:33:56 PM »
Nice catch! That could have ended badly…..
Offline denward17
« Reply #356 on: October 14, 2024, 01:34:13 PM »
Wow!
Was that a clip on type master, or the riveted master that came loose?
« Reply #357 on: October 14, 2024, 01:43:02 PM »
Wow!
Good question its been many years since the chain was installed (bike not ridden much in last 10 years due to all the issues) but I would typically buy a rivet style chain.
Offline Alan F.
« Reply #358 on: October 14, 2024, 03:43:30 PM »
Yes, good catch.
« Reply #359 on: October 14, 2024, 04:49:52 PM »
Glad you found it quickly and had a spare on hand to make it a quick repair. Are you going to change out the sprockets too, or did you at the same time?
« Reply #360 on: October 14, 2024, 04:52:30 PM »
Yes at some point Ill change the sprockets but bike will be parked for winter in about 2 weeks as weather has changed here in Boston.
« Reply #361 on: October 14, 2024, 04:54:02 PM »
Look at it this way brother.....it used to be massive oil leaks. ;D
« Reply #362 on: October 14, 2024, 04:59:43 PM »
So true!! Its getting progressively better  ;D ;D ;D
« Reply #363 on: October 14, 2024, 08:00:23 PM »
Boy, that was close!
A parting chain often ruins the crankcases(!). I only know of one instance where a guy's masterlink unclipped and lost the cover link like yours and he just came to a stop, unharmed.
« Reply #364 on: October 15, 2024, 03:43:03 PM »
LMAO
That was close Andy
« Reply #365 on: October 15, 2024, 08:49:43 PM »
That chain is a strong one.
My K6 has one, 28.000 km later no sign to give up.
I replaced a chain I killed at 25.000 km due to Ultima Chain Wax. That chain was a little bit stronger, but chains and sprockets needs lubrication.
Loss of good lube affected the x-rings. It went quick after that.
I should have continued to use Motorex chain lube strong spray as I did before and after.
My K6 has broken chain twice. At a burnt out attempt 1980, new Tsubaki chain. Engine stock
On Autobahn when gearing down 2 steps followed by WAT to catch up speed after slow going trucks. 836cc and ca 75-80whp.
Chain snapped. It had stretch much  and I had not adjusted it at last stop. "Next stop" was not a good plan. DID 50HDS o-ring chain.
Rolled to a parking lot beside road and waited for oil. No oil. Got lift by a biker to nearby town Kassel to buy a new chain.
Today's x-chains does not stretch much or at all.
« Last Edit: October 16, 2024, 10:06:10 AM by PeWe »
