Author Topic: What size chain for a 78 CB750K?  (Read 2091 times)
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
« on: August 29, 2005, 08:57:09 PM »
hey all you red headed step child lovin hippies out there.....im included.....what size chain do we use? I have to order one tomarrow, but i am not sure what size chain this is, or where to look for this info. Do all 78's use the same size chain? If so, would someone kindly please post it for me? if not, tell me where to find the info. thanks guys.
Gold sparkle is the place you outta be.
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: What size chain for a 78 CB750K?
« Reply #1 on: August 29, 2005, 09:20:19 PM »
The `78 750K came standard with a 630 chain 88 links long and 15 tooth front and 41 tooth rear sprockets.
There are also conversions to a 530 series & chain sprockets available
« Last Edit: August 29, 2005, 09:25:43 PM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: August 29, 2005, 09:25:36 PM »
What he said :D
You will have to cut old one off. Before you remove it......
.....attach new chain to old one and pull it through front sprocket and back.
eldar
« Reply #3 on: August 31, 2005, 02:03:08 PM »
Just so you know, the 78K came with an O-ring chain. At least my owners manual said it came with one. It does not matter which one you get but there is a clearance thing that the older bikes need to worry about. I use a standard and with proper lube and clean, it will work fine but maybe not last quite as long.
Offline 78_SaltLick
  • Honda 1974 550
« Reply #4 on: August 31, 2005, 03:06:25 PM »
What he said :D
How come you have to cut it off?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #5 on: August 31, 2005, 03:22:57 PM »
When the shop in CA I stopped at to pick up my throttle cables looked at the chain, they were unable to locate a joint for removal. They cut it off. Perhaps it had been replaced with a one piece chain before I got my hands on it.
mylittleho
« Reply #6 on: September 01, 2005, 06:54:44 AM »
I thought I read somewhere that the OEM chains didn't have a removeable link and HAD to be cut off...
