Author Topic: drilled my cb550 rotor. PICS inside.  (Read 16384 times)
Offline Soos
Re: drilled my cb550 rotor. PICS inside.
« Reply #25 on: October 25, 2008, 12:12:46 PM »
+1 on the holes not being able to reduce the stopping power.
I have at least 2X the holes in my disks and they still amaze me at times for the stopping power compared to what the stocker single disk did.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline goon 1492
  • Sucka Repellant
« Reply #26 on: October 27, 2008, 06:57:15 AM »
I got one of mine done, this one is for the right side that will go on the shelf until I get the rest of the parts to do the dual setup. I also would reccomend making sure you spend the money on good drill bits to do this job with. I had TI coated but they only worked for about 4 holes, bought a cobalt bit, went slow with slow speed, plenty of oil and volia! I am going to do the left side rotor starting this week, I also with the help of the moderators have a pdf file of what I showed in the last page in the FAQ's (brakes). Use them if you can and I clame no responsibility for your actions :P :-*
Offline Flying J
« Reply #27 on: October 27, 2008, 07:46:13 AM »
I like those rtors better. They have a lot more braking surface to work with.
Offline silver fox
« Reply #28 on: October 28, 2008, 03:25:26 AM »
Hi you lot,
does anyone have a pattern for a 400/4 rotor that they would send me?????
Many thanks
SF
JRK5892
« Reply #29 on: January 10, 2009, 12:07:21 PM »
question.. why such the uniformed pattern? what if i was to do a design in them like a name or something like that? down side to that?
Offline Steve F
« Reply #30 on: January 10, 2009, 12:18:42 PM »
Balancing won't be possible or would be very difficult.
« Reply #31 on: January 10, 2009, 12:31:11 PM »
l8r
I remember reading one time a scientific disertation on why drilling holes, many holes, has little if any effect on braking. It has to do with some mysterious physics of braking. Its not as obvious as one might think. I've never run across such a discussion since. Wish someone would.
Offline Joksa
« Reply #32 on: January 12, 2009, 05:23:33 AM »
Even though form should always follow function, I can't wait to see how my new "bacon slicer" rotors will look installed.
Offline Freaky1
« Reply #33 on: January 12, 2009, 08:57:06 AM »
Hey, is there some one that can upload a pdf for me, I made three drill pattern versions of the 750 rotor, because I was a goon and forgot that this one is for a 550, guess that's what I get for only getting to look here on break at work and moving too fast, well I started from scratch and made up three patterns and wanted to share. Here is a jpeg of it if I can get someones email who can upload it I would glagly send it to ya. thanks for any help maybe it can go in the faq.
I'd like to use the lower right one for my 750F project, where is the file posted to download?
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline goon 1492
  • Sucka Repellant
« Reply #34 on: January 13, 2009, 06:37:13 AM »
Pm me your email address and I can send the file to you. ;)
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #35 on: January 13, 2009, 08:47:38 AM »
Hi you lot,
Many thanks
SF
I second that...getting ready to drill my rotors on my 400F.
Would really appreciate it.
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #36 on: January 13, 2009, 08:59:27 AM »
We have a pattern for the 750 in the tech library on the main site. I'd like to add patterns for other models if anyone has them and can email them to me (or Glenn)
Cheers
Steve
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline goon 1492
  • Sucka Repellant
« Reply #37 on: January 13, 2009, 09:39:59 AM »
speaking of that I do have four versions of what I sent you on the annubis cycle out of business thread, they are separated onto four different pdf's for easier printing and I can send them to you. I do also have a spiral pattern that is the most favored sized for the 550 and I am waiting for sizes for the 400 rotor and I can make a pattern for them too. ;) If that's ok Steve cb500f I will get them all sent to you and you can delete the original one I sent to you and replace them with the new separate versions for all to share.
    • TVAM
« Reply #38 on: January 13, 2009, 09:50:23 AM »
That'd be great.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Hopper
CB350F drilling disc using old BMW disc for guide
« Reply #39 on: December 27, 2010, 01:54:07 AM »
Our lad just drilled his CB350F disc, using an old BMW Airhead disc as a drill guide.
Clamped the BMW disc on top of the Honda disc with two G-clamps, then drilled two holes opposite each other, did away with the clamps and used two 6mm bolts to hold the two discs firmly together while drilling the other 120 or so holes.
Came up looking a treat, as you can see. Used a countersinking bit to do the chamfers.
The BMW disc is exactly the same diameter as the CB350F's so holes were perfectly located regarding both inner and outer edges of the disc.
BMW disc was the same on R75 through to R100 models, 1970s and most of the 80s and were factory drilled.
« Last Edit: December 27, 2010, 01:57:07 AM by Hopper »
Offline jjc
  • How do I get this bike to go forward?
« Reply #40 on: August 30, 2023, 10:13:39 AM »
I have a 550 disc i started to drill ( 25% done, 75% half way drilled.
I have had nothing but trouble and am looking for someone to finish it or buy another drill disc
Yes I have a drill press & yes I used lub. I've destroyed 2 carbide drills.
If anyone can help me let me know.
The holes are 3/8"
J.C.
1976 550CB, 82' Honda 110T, 2000' Buell X3, 96' Yamaha 350XT, 16' Honda 450X, 2014 BMW R9T, 2003 BMW KGT,
2016 BMW 800GSA
