Author Topic: any ideas on on restoring or refinishing the controls that are on the handlebar?  (Read 8460 times)
Offline jamesv220820
 i have a cb350f and im basically redoing the handlebars and everything thats on them and i was wondering becuase the controls look like they were originally painted black but im not sure since it is an old bike i was wondering if you guys just sand them down then take some steel wool to them or paint them or whatever you do to make them look new?
also the kill/run switch is all faded is there some type of red plastic paint i can get at hobby lobby to make that lookin new as day?
thanks for all the help
-james
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline greenjeans
  • 1972 CB750K2
I'm currently in the process of doing mine.   Tedious to say the least, but a good project that will definitely make a difference in looks.
I used EZ off oven cleaner to get the old annodizing off.  At first I was going to polish them, but decided to go back to the original black.
Krylon makes a spray paint formulated especially for Plastic - available everywhere.
Since the controls are aluminum, I lightly bead blasted them before spraying them with an etching primer (also in a spray can) and followed with black.
Haven't got to filling in the tiny tiny lettering with orange just yet... that should be interesting.
The lettering is easy. Dab some paint on and gently wipe it off. That is how it was made originally.
Offline nippon
    • Classic Cycle City
Hi,
you should disassembling your controls completeley. Be careful with the small springs, washers and balls, don't loose them.
Otherwise your switch will not work anymore. Do the whole disassembling in a bowl. Make pics. Removing the kill switch is tricky but not impossible,...You have to cut the two cables. Be careful, under the kill switch is a very small ball , spring and tin. Then sand your controls and take a good primer. Sand it again (wet) and do your paint job. Do the lettering as BobbyR wrote. BTW, I put some new shrink tube on the cables. Use a magnet to put the kill switch on that it stands up like a mushroom,...easy to paint now.
I did mine 1 1/2 year ago,...the paint holds up perfeclty.
nippon
« Last Edit: March 11, 2009, 02:53:43 PM by nippon »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
...or have them re-anodized black.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Toxic
that's about the nicest job I have ever seen on rebuilding switches.
WHALEMAN
Has anyone ever sucessfully had them powdercoated? Dan
Offline nippon
I guess, if you powdercoat them, the small gaps of the letters will be totally closed.
nippon
Hi,
nippon
wow what type of paint did you use?
Offline markb
  • When I finish my current project I might be a
Nice job nippon!  Anyone know if they're similar to the CB750?  I've got a nice set from a '72 but I need to replace the red kill switch knob with the black one from my faded '70 controls.  What cables do you have to cut and what do you do then?
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline fmctm1sw
+1.  Took my turn signal switch apart this weekend.  One very small ball, 2 springs, and a strip of metal that makes contact with the actual turn signal contacts.  Cleaned and lubed it up and it makes all the difference in the world (that is, after I crawled all over the floor looking for them)...  No more mushy feeling on right turns!
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mark
Next time I'm at the sporting goods store, I'm going to try to remember a bottle of this stuff:
"Aluminum BlackĀ® Metal Finish
Used by gunsmiths to blacken aluminum parts. Restores scratched and marred areas quickly. Fast-acting liquid is easy-to-apply with no dimensional change. Color will vary from deep gray to black depending on alloy. ALUMINUM BLACK is also excellent for blackening name plates, plaques, trophies and other engraved items.
...... couldn't hurt to try.
F you mark...... F you.
Offline Really?
I tried that easy off, didn't work.  I just sanded and spray painted flat black, looked fine to me.
There is a thread somewhere buried in here where they did powder coat it.
I think Mr. Breeze replaced his with some chrome ones for a Yamaha.  He even posted where he got them and how to wire them.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline hapakev
  • Your Standard
Wow Nippon, excellent work!!  You mention cutting the "two cables," do you solder them upon reassembly?
Smoking Jack
1978 CB750F(ish)
Offline nippon
@hapakev ,
yes, you have to do this. You have to cut the cables because the contact plate will not go through the hole of the top half
of the switch.
nippon
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
I feel a "Rebuild Your Handlebar Controls" FAQ coming on.
Got any more pictures nippon?
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline nippon
I think so, but i have to take a look at.
If not, I have another two switches to do and then I will make step by step pictures and I write a 'how to' from the ground.
Of course, in order to get a 100% stock look, you could take a mate black and a mate red color.
I removed the scratches with a Dremel first. Sanding. Primer, paint, mate clearcoat.
If you like playing with small parts and small springs,....then everybody can do it.
nippon.
« Last Edit: March 12, 2009, 01:10:29 AM by nippon »
Offline 77honda
Nippon, what paint did you use to paint the red kill switch toggle. I have mine apart and have bead blasted the housing reading for primer.
The kill switch button is faded, I was looking for a new one but impossible to find. Your restoration is fantastic, greta work.
Mike
CB750 K7
Mike
i just finished doing mine my was extremely faded so i did 3 coats of krylon plastic paint (red), then 2 coats of clear coat ill take pictures but they look great
i'm, doing mine right now heres the progress
sorry the pics arent great little camera suck upclose
Mike
here you go mike i didnt feel like searching for balls and springs so i just did a really good tape job
love this paint no sanding required and when the clear coat is on top it is really smooth and strong
ps sorry about my disgusting hand
Offline Duke McDukiedook
  • Space Force 6 Star General
Nice guys, you are inspiring me to the point of almost wanting to work on mine.
Ehh, maybe not, it's getting warm this weekend.
Offline 77honda
Thanks James, you switch looks great, All I have to do is find a store that sells krylon plastic paint here in Australia.
Mike
CB750 K7
Offline mark
Apply magic smelly potion to bare aluminum...... aluminum turns black.
Further testing required.
hmm interesting  how strong is that stuff , can you take your fingernail to it and it won't scratch off? because i didnt like how mine turned out it kinda looked plasticky and not like metal
« Last Edit: March 15, 2009, 09:05:11 AM by jamesv220820 »
