Author Topic: Valve Spring Compressor??? What are you guys using???  (Read 10005 times)
Ryan 550k
« on: April 30, 2009, 05:24:23 PM »
I'm having a mechanic buddy of mine change the valve seals on my cb550.  The cylinder head and cover is off the bike already, this is one of the few remaining things I'm needing to do before I throw the engine back together.  What are you guys using to compress the valve springs in order to change the seals???  Someone several months ago suggested a compressor from Harbor Freight but it's not available anymore.
Wow, this post is wordy huh? ;D
« Last Edit: April 30, 2009, 09:53:58 PM by R550 »
Offline Alan F.
Offline OldSchool_IsCool
  • Really feeling like an
Re: Valve Spring Compressor??? What are you guys using???
« Reply #2 on: April 30, 2009, 06:34:49 PM »
I ended up using a hefty C-clamp with a U-shaped metal band to give me access to the retainers.  Worked pretty well!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline fmctm1sw
« Reply #3 on: April 30, 2009, 06:57:47 PM »
I use something like that too.  I bought this at sears but it will only work on my intake (or is it exhaust?) side on my 350F.
http://www.sears.com/shc/s/p_10153_12605_00947627000P?keyword=valve+spring
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Big Jay
    • CBRzone
« Reply #4 on: May 01, 2009, 12:12:12 AM »
Offline kvallelunga
« Reply #5 on: May 01, 2009, 05:24:58 AM »
+1 on the Sears unit. It worked flawlessly on all the heads/valves I've ever needed.
Kevin V.
78 CB750 F Supersport
81 Yamaha Chappy
Offline buffalogt750
« Reply #6 on: May 01, 2009, 05:43:58 AM »
I changed the valve seals on my '76 550K with the head on the bike. Remove valve cover and spark plugs. Insert a piece of rope through the spark plug hole while piston is down, leave some rope hanging out for removal later. Turn engine slowly to push rope up to hold valves in place. If you put a socket on the retainer and rap it once or twice with a hammer, the split locks will fall out. Make sure you cover the engine to keep them from falling in. Remove spring and change your seal. Do both valves on that cylinder. On reassembly, I use a socket with a space ground out of the bottom to access the split locks and a notch ground in the top of it for prying down on with a prybar or long screwdriver (notch is to keep prybar in place on top of socket). Put a short wood block like a 2x4 under the top frame rail to pry against and pry down on the socket on top of the retainer to compress the spring and install split locks. Put a little grease on the valve to help hold them in place while you release the pressure on the retainer. Turn the engine backwards a little and pull the rope out. Tap the top of the valve stems to make sure the split locks are seated well. Now do the other cylinders. The springs are not very difficult to compress and if your head gasket is not leaking, why pull the head. Again, be sure to keep the engine covered to prevent split locks from falling in.
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: May 01, 2009, 06:38:23 AM »
Uh... I don't think us garage monkeys have that kind of money Jay.
Offline Big Jay
    • CBRzone
« Reply #8 on: May 01, 2009, 08:47:33 AM »
The title of the thread is "What do you guys use"  ;D
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #9 on: May 01, 2009, 09:49:55 AM »
http://www.machinemart.co.uk/shop/product/details/cht459-hd-valve-spring-compressor
This is what I used, perfect for the job, I have seen it on Ebay in the US I think the the seller was called 'sportingforless'
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Ryan 550k
« Reply #10 on: May 01, 2009, 10:22:31 AM »
So just out of convenience at this point I'm gonna try this first.  There's a Harbor Freight pretty close to my place.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92900
If it doesn't work I'll probably check out the Sears option that fmctm1sw mentioned, thanks man.
Down the line it sure would be nice to have that Sporting for less compressor.  That looks very nice indeed!
Thanks guys, you've been a heck of a lotta help.  Hope everyone is well :D
« Last Edit: May 01, 2009, 10:27:20 AM by R550 »
« Reply #11 on: May 01, 2009, 10:43:06 AM »
R550,
I got a compressor like that from Sears.  I couldn't get the fingers deep enough into the spring wells to work.  Luckily I had the C-clap style handy.  I suggest while you are at HF, get and 8" or 10" C-clamp and maybe a cheap socket to cut so you have a Plan B.
Sure.
Is it hard?
Offline mark
« Reply #12 on: May 01, 2009, 10:59:34 AM »
It works pretty well as a drill press too.
I also have the c-clamp type but it's way too big for most m/c stuff.
F you mark...... F you.
Offline lordmoonpie
    • Moonpie
« Reply #13 on: May 01, 2009, 12:12:10 PM »
I use a Sykes Pickavant one - £20 form Halfords in the UK and it's so far worked on everything from my 50cc ducati classic (valves the size of a dime) to those on a 1098 Ducati....not bad for the money and I adapted it for getting the forks apart on my XV750 too where you have to push the fork tops down to get at the retaining circlip.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Ryan 550k
« Reply #14 on: May 03, 2009, 09:55:39 AM »
Old School you were totally on the money.  The Compressor I picked up from Harbor Freight didn't work for the exact reason you mentioned.  I'll be going the C-clamp route today.  Wish me luck! :-\
« Reply #15 on: May 03, 2009, 01:34:58 PM »
Luck!  ;D
Sure.
Is it hard?
Ryan 550k
« Reply #16 on: May 04, 2009, 11:34:13 AM »
You know, before doing something that I've never attempted, like changing valve seals, I'm convinced it's gonna be really difficult.  It wasn't......was super, super easy!  Using a big C-clamp was def the way to go.  Had my buddy show me how to do the first one and I was off and running.  Anyway, thanks guys.
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #17 on: August 11, 2012, 06:38:24 PM »
Here's my ghetto valve compression tool setup using an 8" C-clamp, a spring clamp and a wood block. I used another smaller C-clamp to keep the spring clamp opened wide enough to allow for access around the stem to reach for the clips. Hope this helps. Real easy set up/removal  8)
« Reply #18 on: August 11, 2012, 09:32:04 PM »
+2 on the drill press, just make a tool to fit the valve coolar and spacer below the valve head...
Offline Dimitri13
  • 1974 CB550K
« Reply #19 on: August 12, 2012, 12:52:13 AM »
$5 valve spring compressor.
Offline minimo
« Reply #20 on: August 12, 2012, 03:20:28 AM »
Dimitri13, that's sweet! What is that exactly? I see internal threads.
Offline Dimitri13
  • 1974 CB550K
« Reply #21 on: August 12, 2012, 03:56:56 AM »
I'm not exactly sure what it was, just something I had laying around that fit perfectly. Just cut a window in it to fit the needlenose pliers in. The threads aren't used, it's just pushing down on the retainer.
The arms on my c-clamp were long enough to fit on both sides.
« Reply #22 on: August 12, 2012, 08:00:56 AM »
 He used a pipe coupler...
Offline minimo
« Reply #23 on: August 12, 2012, 10:12:13 AM »
Aha! Good eye, 754. I'm gonna Try that B-)
« Reply #24 on: August 12, 2012, 10:56:14 AM »
 What I dont like is using that on the SWIVEL end;
 I used to make a rectangle piece with a notch in it..like a long U. Then I put it in the lathe and cut a taper into the open end.. it centers it on the collar. Then you take a C-clamp, mount it screwside down in a drillpress. Now find the centre of the stationary pad, and  grind a small flat, then drill and tap thru...say 1/4 NC or 5/16 NC Drill and countersink the bottom of the U and mount to the stationary pad
