Author Topic: Questions regarding the best years for the Honda CB550  (Read 36517 times)
Offline Johnny-5
« on: June 10, 2009, 08:02:12 PM »
Im in the market and have found a few but not sure which years are the better years to go with or if that even makes a difference? One is a 1973, second is a 1976 and the third is a 1985. Any feedback would be greatly appreciated.
Thanks,
Johnny
Offline jreich
Re: Questions regarding the best years for the Honda CB550
« Reply #1 on: June 10, 2009, 08:07:36 PM »
Short answer: '76
Offline Johnny-5
« Reply #2 on: June 10, 2009, 08:09:37 PM »
Thanks for the response.....If you dont mind me asking why is that the best year? Also what would be the next best?
Total Newbie here!
Offline Laminar
  • Retsam
« Reply #3 on: June 10, 2009, 08:22:23 PM »
If I'm not mistaken, Honda didn't make a 550 in '85. The CB550 was made between 1974 and 1978 and the Nighthawk 550 was made in 1983-1984 (1984 was only in Canada).
The CB550 and the Nighthawk 550 (if that's what the '85 really is) are very different bikes. The CB550 has the classic looks and feel. The Nighthawk is much more modern and low-maintenance. It has a hydraulic clutch, shaft drive, hydraulic valve tappets, electronic ignition, plastic non-adjustible floats, etc. The Nighthawk weighs just a few more pounds than the CB550, but it has quite a bit more power (65hp vs. 50hp), and a higher stance, longer fork tubes, and different handlebars for more of a cruiser-like appearance.
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #4 on: June 10, 2009, 08:25:24 PM »
I thought the 550 was closer to 40 hp stock.
I definetly prefer the 1974 paint scheme.
1974 CB550
Forever West
Offline Johnny-5
« Reply #5 on: June 10, 2009, 08:30:32 PM »
Im sure you are right. This guy must have posted it wrong as he stated it to be a 1985 CB550.
If was going to go with a Cafe Racer style Im assuming I may be better off with the 70's CB than correct? Now which years are better?
Offline edbikerii
    • Gallery
« Reply #6 on: June 10, 2009, 08:31:58 PM »
85?  Wasn't that a 700 Nighthawk or something?  I'd love to own one of them.  DOHC makes more power than our SOHCs.  Unfortunately, they just don't look like "classics", as they don't have the chrome and such that our older SOHC bikes have.
Personally, I think the 77 and 78 K models are the best years for the CB550.
The later F models are similar to the prior model years with the exception of the beautiful 4->1 exhaust from the factory, and the kickstart arm and footpeg changes that the 4->1 exhaust required.
Through re-jetting and cleaning my carbs, I really learned to appreciate the more refined carburetors on the 77-78 K models.
Otherwise, aftermarket support seems to have been better for the earlier years.  Seat covers are available from Travelcade, but you have to order them directly from Saddlemen, because, for some reason, none of the catalog shops (JCWhitney, Dennis Kirk, etc.) seem to list the seat covers for the 77 or 78 K (they are slightly different both from each other and the earlier models).  These seat covers are EXCELLENT and will last many years - much longer than an OEM replacement seat, if you can even find an OEM seat anymore.
Side covers are nearly impossible to find for the 77 and 78 K models, so make sure you get them with your purchase or are prepared to go hunting for them.  I think Meier still makes them for the earlier models and the F models.
The clutch mechanism was refined and improved over the years, with 77 and 78 having the least problems and requiring the least "fiddling".
Engine refinements reached their pinnacle in the 77 models with the much-improved rocker arm shaft design.
77-78 K models also incorporated an automatic fast-idle cam that raises the idle when the choke is engaged, so no more fiddling with the throttle stop screw was required.
Enjoy!
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline Johnny-5
« Reply #7 on: June 10, 2009, 08:32:38 PM »
Im going to repaint the entire bike so the paint scheme isnt an issue for me.
Offline Johnny-5
« Reply #8 on: June 10, 2009, 08:35:57 PM »
This is a picture of the bike the guy sent me....not the greatest but looks pretty clean. Could you guys tell me by looking at the picture what model this is?
Offline Laminar
  • Retsam
« Reply #9 on: June 10, 2009, 08:47:44 PM »
There was a Nighthawk 700 in '85, along with a 650. There was a 750 in Canada and at some point the Nighthawk line was reduced to just the 750.
The Wikipedia article lists 50 brake horsepower for the CB550, it would be more like 40 at the rear wheel.
The pictured bike appears to have dual overhead cams, but the side covers don't look like the Nighthawk 550's. The tank doesn't look like any Nighthawk, and the rims look like Comstars.
I wouldn't bother with that bike - with all of the spray paint, stickers, and hacked-up work, and other stupid **** done to it, it'd be a nightmare to make presentable again, and you'd be in a lot of trouble if something mechanical was wrong - who knows what parts were used where.
Offline Laminar
  • Retsam
« Reply #10 on: June 10, 2009, 08:51:15 PM »
For reference:
'85 Nighthawk 650:
'85 Nighthawk 700s:
If I'm wrong about it being a DOHC, it could almost be a pre-Nighthawk 650, like this '82:
Offline Johnny-5
« Reply #11 on: June 10, 2009, 09:07:21 PM »
You do have a point. Ill probably pass on this and see what other 70's CB's I can find. Thanks for your advice.
Offline Johnny-5
« Reply #12 on: June 11, 2009, 08:06:24 AM »
FTR, I am enjoying my 76 550k despite my carb and ignition issues so far. My Dad had a Nighthawk 700s a few years back, and that thing absolutely ripped! I loved that bike. It would drag your butt off the seat if you weren't careful, and it still got 45 mpg when babied. The maintenance was much easier/less frequent too. Not to mention it would cruise all day at 70-80; something the 70's 550's won't do.
Things I am not fond of with my 550 are: frequent maintenance schedule (seems like something needs tweaked every few hundred miles) pretty much a 60mph and under bike (you can forget passing in tight spaces above 60), kinda unrefined, doesn't like to corner at speeds with out a little head shake, weak brakes, and shocks that remind me of, well... just about any 70's era bike, and the tranny is only a 5 speed. I don't know of any 70's 6 speeds out there, but I always want to grab one more gear.
Things I really like about the 550 are: Fuel economy, tons of fun in the 30-50 mph range, will start every time, even when only on 2 cylinders  ;D ;D ;D, relatively easy to work on, parts are pretty cheap, not enough power or brakes to go through a set of tires every season :P and great vintage looks compared to many other same era Jap bikes.
All that said, my next bike will definitely be an 80's 'Hawk. Better suspenders, 6 gears, hydraulics, better seating position, more power, less work...
Meanwhile, my buddy is trying to coax me into buying his old shovel head.  :D Right...
Paul
Thanks Paul that was great info.....Are these really 60 and under bikes? If thats the case Im going to have to tweek the motor out which I really didnt want to do. :(
Offline IHWillys
« Reply #13 on: June 11, 2009, 08:14:40 AM »
...I don't know of any 70's 6 speeds out there...
Just to fill in a bit of knowledge, hehe.  RDs have a 6-speed transmission.
Ken
Offline crazypj
  • I'm brill, me
« Reply #14 on: June 11, 2009, 08:36:21 AM »
Wouldn't touch the 85 CB550 unless it has full service history (yes, there was one)
 similar motor to the 700 but smaller.
 If you don't change the oil at regular intervals it will mess up the hydraulic tappets (same as 700/750's do)
I've also done a few 750 DOHC/Nighthawk motors where big ends failed because of 'dirty' oil (stuff the early 550 wouldn't care about)
PJ
Offline Johnny-5
« Reply #15 on: June 11, 2009, 08:37:26 AM »
I was looking around on line and started to do a search for 85 Nighthawks 550's and stumbled upon this picture......Looking at the motor and the side covers and tank it looks pretty similiar to the picture I posted before.
If that is the case is this a good bike to convert into a Cafe Racer?
« Last Edit: June 11, 2009, 08:39:32 AM by Johnny-5 »
Offline Johnny-5
« Reply #16 on: June 11, 2009, 08:41:17 AM »
PJ
PJ,
So there was a CB550 in 85 too? So basically its more of a headache to own one? This guy has no history on the bike and its been sitting for about a year. He's not even sure if it runs.
Offline bistromath
« Reply #17 on: June 11, 2009, 09:45:56 AM »
Just two add my two cents, my stock '75 550F will cruise at 75 all day long, and I've got the sore butt to prove it.
'75 CB550F
Offline zoo mob
« Reply #18 on: June 11, 2009, 10:26:20 AM »
If I'm not mistaken, cb360t's also have 6-speed transmissions.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline Popwood
« Reply #19 on: June 11, 2009, 10:39:58 AM »
+1 on that bistromath. And they are just so darn pretty. Great proportions, great style. Maybe I'm lucky or don't know any better but I don't my '75 needs that much upkeep at all. And what there is I enjoy a lot.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
« Reply #20 on: June 11, 2009, 01:09:20 PM »
Yes, yes.  All the stock 550s will do this and more routinely. (assumes the mechanic can keep the bike in good tune).
I speculate it's those modified 550s that can't keep up.  ;D
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #21 on: June 11, 2009, 01:39:44 PM »
My 74 CB550 will run 90/95 all day long as long as I can keep gas in it.  As for high speed handling, no problems when everything is up to snuff.  Know to see if I can get a nice 4 into 4 for it.  It even rides better two-up then my Goldwing at the moment, I need to rebuild the shocks and forks.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Laminar
  • Retsam
« Reply #22 on: June 11, 2009, 04:51:28 PM »
Really? Everything I've seen said the Nighthawk 550 was offered in the US in '83, and only in Canada in '84. Got a source?
Offline Laminar
  • Retsam
« Reply #23 on: June 11, 2009, 04:52:34 PM »
The 700cc Nighthawks are fantastic bikes, and if I'm not mistaken, actually faster than the later Nighthawk 750.
Offline Laminar
  • Retsam
« Reply #24 on: June 11, 2009, 04:54:51 PM »
The tank in your picture looks nothing like the Nighthawk 550's tank. The Nighthawk's tank radically slopes out from the coils and back in towards the top - the tank in your pictured bike goes straight down.
It's not a good bike to convert to a Cafe - the lines are all wrong. It'd make a great bobber/chopper because of the tall, sloping tank and extremely long forks, but it doesn't really have the same shape as a Cafe.
