Author Topic: exaust wrap ?'s  (Read 4908 times)
Offline the technological J
  • deliciouso!
exaust wrap ?'s
« on: July 20, 2009, 02:05:40 PM »
im checking out some exaust wrap have been for a while any opinions on what a good price is and how much i will need?
i found some black wrap(the color im looking for) 2 inches thick by 50 ft long for 50 bucks at the store down the road.   what is gonna look better on her the 2 inch thick stuff or the 1in?  was are the possible benifits of this stuff(other than covering up my uggo rusty pipes).... thanks
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Laminar
  • Retsam
Re: exaust wrap ?'s
« Reply #1 on: July 20, 2009, 02:20:41 PM »
I just finished wrapping the pipes on my 550. (Well, I'm not really finished since I'll have to redo the right pipes due to running out of length...).
50 feet of two-inch-wide wrap was a couple feet short of doing my custom four-into-two pipes. Fifty feet would be plenty if you were just doing four headers.
I did it purely for looks. I can't comment on the wrap's ability to increase power or retain heat, as I've measured neither. I believe the point is to keep exhaust gasses hot which improves scavenging. In an application this small, I doubt the performance difference would be very measurable.
To apply the wrap - I dipped a few feet of the wrap in a bowl of water, and tightly wrapped it all the way down, overlapping approximately 1/4" each time. I then installed the header on the bike right away and ran the bike for a few minutes to burn off all of the water still in the wrap. It wasn't too hard, it just took time.
There are a few common concerns with exhaust wrap (I have no comments on their validity):
- The headers will run hotter and will be more prone to cracking
- The wrap will retain moisture from rain and make the pipes rust
- The wrap will absorb spilled flammable chemicals and pose a fire hazard
The biggest pro for me is that the wrap covered up ugly pipes.
I got 50 ft of 2 inch wide wrap AND six stainless steel zip ties (useless on the small diameter header pipes) for $26.50 shipped from this eBay seller.
Hope this helps.
Offline pee wee
Re: exaust wrap ?'s
« Reply #2 on: July 20, 2009, 03:22:02 PM »
go to jegs.com or summitracing.com buy there brand, either one. it comes in black and some other colors .there stainless fasteners might be cheaper too.
 good luck
Offline manjisann
Re: exaust wrap ?'s
« Reply #3 on: July 20, 2009, 09:59:05 PM »
I wrapped my pipes on my bike, but ended up having a nasty oil leak onto them. The upside was my bike was stealth, whenever the light turned green I dissappeared in a cloud of smoke. That was my only real complaint.
Brandon
1980 CB650 Custom
Offline honda750k
Re: exaust wrap ?'s
« Reply #4 on: July 20, 2009, 10:09:00 PM »
Of those 3 concerns, the first is false,  but the part about retaining moisture and making pipes rust is 100% true if you do not ride the bike daily.  also the heat wrap is not suitable on titanium pipes, which will disintigrate pretty much with heat wrap.
The last point, about absorbing flammable liquids(such as oil or gasoline) is 100% true, and you need to be careful of this. I know someone who spilled oil on his heat wrap once and melted a body panel on his bike when it caught fire not too long after he started the bike.
When you do heat wrapping, you need to have HALF the wrap, not just 1/4" overlap if you want to get the optimal insulating effect from it. 2" is the best widh for motorcycle headers, and you'll need more than 50' to do a full exhaust correctl. I've used very near 50' on the headers alone on one particular honda once. to do head t muffler, you need about 75' of the 2" wrap with a 50% overlap all the way to the muffler if you want it to insulate welll.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline ev0lve
Re: exaust wrap ?'s
« Reply #5 on: July 21, 2009, 06:48:30 AM »
From any research I could do the benefits on a street bike are exactly nothing other than to cover up your rusty/dinged headers.  ;D I suspect it will help destroy the pipes a bit faster but probably not so fast that you would really notice. No one I can find with a bike seems to know for sure.
If the pipes are reasonable aesthetically I think I'd just zing them with the wire wheel and spray them black. And I might have gone tan in retrospect now  ;D
50ft should get you just about here -
Offline Laminar
  • Retsam
Re: exaust wrap ?'s
« Reply #6 on: July 21, 2009, 06:56:44 AM »
The part about running hotter or the part about being prone to cracking?
From the distributor where I got my wrap:
Our wrap has a premium weave and is very easy to install. When installing, generally 1/4" overlap is recommended.
Offline honda750k
Re: exaust wrap ?'s
« Reply #7 on: July 21, 2009, 08:11:20 AM »
On the heat issue, both the hader runnning hotter and the head cracking claims are false.
Offline Laminar
  • Retsam
Re: exaust wrap ?'s
« Reply #8 on: July 21, 2009, 08:19:46 AM »
Two situations:
1. You go outside in a t-shirt when it's 30 degrees out.
2. You go outside in a thick winter coat when it's 30 degrees out.
In both cases, you have the same amount of internal heat. Is your skin the same temperature in both cases?
  • deliciouso!
Re: exaust wrap ?'s
« Reply #9 on: July 21, 2009, 12:41:34 PM »
should i clean up the exhuast and spray on some high temp paint before wraping them?
94 ST1100..Gone
Offline Laminar
  • Retsam
Re: exaust wrap ?'s
« Reply #10 on: July 21, 2009, 12:48:00 PM »
Some recommend it to protect against rust. I don't think it'd be a bad idea, as long as the high-temp paint is cured correctly.
« Last Edit: August 28, 2009, 07:05:54 PM by Laminar »
Offline socalenduro
Re: exaust wrap ?'s
« Reply #11 on: October 01, 2009, 04:29:48 PM »
cured correctly? go on....
i have high temp engine paint rated to 300 degrees... is that high enough?
Offline Gorms
  • Barkeep! Give me a beer and a
Re: exaust wrap ?'s
« Reply #12 on: October 01, 2009, 04:33:59 PM »
300 is not high enough.  You need the 1200-1500 paint.
Offline Laminar
  • Retsam
Re: exaust wrap ?'s
« Reply #13 on: October 01, 2009, 04:46:59 PM »
Read the instructions on the can. Oftentimes, spraying the headers isn't enough, the paint needs to be baked (like in an oven) to cure it properly.
Offline Aaron Richard
  • 1975 CB550 cafe
    • shop
Re: exaust wrap ?'s
« Reply #14 on: October 01, 2009, 04:48:39 PM »
I used 2in" on mine. looks good, keeps the heat away from you while riding. ...and covers up #$%*ty pipes ;D
There is a guy I bought off of ebay that had great deals on the stuff. I'll see if I can find the link to him. you will pay top dollar at a store like auto zone..
Offline Gorms
Re: exaust wrap ?'s
« Reply #16 on: October 01, 2009, 04:55:57 PM »
Shiznits75,
What color did you paint your tank and seat?  Looks great.
  • 1975 CB550 cafe
    • shop
Re: exaust wrap ?'s
« Reply #18 on: October 01, 2009, 05:05:47 PM »
it is black night metallic with urethane clear
Shiznits75,
