Author Topic: am I an idiot??  (Read 4940 times)
ateamsam
am I an idiot??
« on: August 07, 2009, 02:43:27 PM »
Hey guys!
I'm new at all things mechanical so I bought a Clymers repair manual so I can work on my 1974 CB550.  I started to do a tune-up but have gotten stuck on the valve adjustment portion.  I know i'm probably screwing this up so I need you guys to tell me where I'm screwing up.
After removing the tappets and turing the crankshaft the #4 cylinder was at TDC.  I know this because the rocker arm could be wiggled side-to-side).  Anyways, here is where my confusion sets in;  Where am I supposed to put the feeler gauge??  I loosened the locknut and placed the feeler gauge between it and the rocker arm.  Is that right?  I ask this because there is a considerable gap between the stem below the rocker arm and what ever that stem attaches too.  If anyone can explain how I am supposed to do this or can provide some detailed pictures that would be awesome.
newbie,
Sam
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #1 on: August 07, 2009, 03:14:03 PM »
You put the feeler gauge in the tiny gap between the bottom of the tappet and the top of the valve stem.  This is very difficult to do if you don't have angled feelers.  With a flashlight, look closely at the rocker as you move it up and down.  The space at the bottom, between the part that moves and the part that doesn't move, is what you're measuring.
Offline Triffecpa
Re: am I an idiot??
« Reply #2 on: August 07, 2009, 03:14:30 PM »
Sam
the locknut holds the adjuster screw in place.  When you loosen the lock nut, you can now screw the adjuster screw down or back it back up.  The feeler gauge goes between the bottom of the adjuster screw and the top of the valve that it rides on.
It's a major pain on most SOHC Hondas to fit the feeler gauge between the adjuster screw and the valve stem and then tighten or loosen the adjuster screw and then use your third hand to retighten the lock nut.
Good luck.
Tracy
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
Re: am I an idiot??
« Reply #3 on: August 07, 2009, 03:18:55 PM »
I just bent my feelers a little at the tips! Maybe a 1/4 or so at the ends. You know, when my wife asks me, "am I am idiot?" I usually say yes! Which is followed by some obscenities that I wont repeat here.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #4 on: August 07, 2009, 03:22:19 PM »
Does a third leg count?
ateamsam
Re: am I an idiot??
« Reply #5 on: August 07, 2009, 03:27:10 PM »
I've looked for pictures and can't seem to find any.  Does anyone have any detailed pics?
Offline JS550
  • IAFF local 1307
Re: am I an idiot??
« Reply #6 on: August 07, 2009, 03:30:42 PM »
I know your not asking for a detailed pic of someones third leg?!! :o
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #7 on: August 07, 2009, 03:38:20 PM »
 ;D ;D ;D ;D
Where's that spit-take emoticon when you need it!?
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #8 on: August 07, 2009, 03:43:19 PM »
I don't have any detailed pics, but a description should work.  The adjusting screw that you you turn after you've loosened the lock-nut is the part of the valve rocker that actually makes contact with the valve stem.  It's essentially just a screw.  The gap at the bottom of this screw is where you need to insert the feeler gauges.  Just follow it from the top down to the bottom and you'll see what you're trying to measure.
Offline 333
  • Time for change
Re: am I an idiot??
« Reply #9 on: August 07, 2009, 04:06:56 PM »
As I see it, your problem stems from the Clymer.  The Honda manual has plenty of pictures to actually see what you need to do on the bike you actually have.  Clymer's usually cover several models, and sometimes even use pictures from totally different bikes.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
ateamsam
Re: am I an idiot??
« Reply #10 on: August 07, 2009, 05:13:57 PM »
Okay, since Clymer sucks and I suck at visualizing written text, I've taken a photo for you guys to help.  Which should I be measuring?
Offline scunny
  • don't call me expert
Re: am I an idiot??
« Reply #11 on: August 07, 2009, 05:24:00 PM »
that slotted bolt is the adjuster, you measure between that and the top of the valve stem( which lies under that adjuster) the top nut is a lock nut
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: am I an idiot??
« Reply #12 on: August 07, 2009, 05:40:35 PM »
i usually start with #1 at TDC, confirming by making sure both rockers can wiggle a bit.
searching for a dr350se
Offline JS550
  • IAFF local 1307
Re: am I an idiot??
« Reply #13 on: August 07, 2009, 05:58:28 PM »
You might want to see if you can find someone to give you a hand? Not to sound like a douche, but you can really make you bike run sh!tty or even cause serious damage. If you have never set valves before on any type of vehicle consider getting together with someone who has. If for anything to watch & make sure you get it right. You might even find someone on here thats close to you.
jim
Offline Bill/BentON Racing
    • BentON Racing
Re: am I an idiot??
« Reply #14 on: August 07, 2009, 08:42:08 PM »
Good idea if anyone lives near you,don't forget to adjust cam chain first.Bill
BentON Racing Website
BentON Racing Facebook
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #15 on: August 07, 2009, 09:02:35 PM »
The second picture is where you measure.  It's really hard to actually see the gap, but you can get a feeler gauge into it.
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
Re: am I an idiot??
« Reply #16 on: August 07, 2009, 09:04:20 PM »
jim
And don't get distracted by hot chicks while you do this. I got some bent valves because I got VERY distracted.
She was worth it though 8)
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
ateamsam
Re: am I an idiot??
« Reply #17 on: August 07, 2009, 10:34:30 PM »
Gordon, thanks for letting me know which picture was right.  Not sure if I'll have time to tackle it tomorrow but its nice to see that a picture helps remove some of the guess work.
And Jim ... you're not a douche.   Asking for someone to help is probably the right thing to do.  Thanks for looking out for the bike ;)
Offline Gordon
  • 750K1, 550K2
Re: am I an idiot??
« Reply #18 on: August 07, 2009, 10:46:04 PM »
Yep, pictures always help. :)  The tappet adjuster is just a screw, so what you're measuring is the tiny gap between the bottom tip of that screw and the top of the valve stem.
Offline Frankenkit
  • Industrial Strength
Re: am I an idiot??
« Reply #19 on: August 08, 2009, 07:04:36 AM »
I second the help.  I bent a couple valves this way. :(
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: am I an idiot??
« Reply #20 on: August 08, 2009, 07:55:02 AM »
It helps to have a tappet adjuster that is made specifically for the task.
It will take you a while to get the procedure down right because whenever you tighten down the nut to secure the clearance, the screw will want to tighten more on you. It will take you a while to get a feel for tightening down the screw so far to allow for some further gap closing when you tighten the nut down.
Offline the technological J
  • deliciouso!
Re: am I an idiot??
« Reply #21 on: August 08, 2009, 08:07:42 AM »
how do u guys feel about running 4 instead of 2 and 3 (hundredths of a mm i think) on intake and exaust... i think ive seen some discussions about this on here and even on thoughts of the honda man.... i have a 550 by the way... anybody do this is there any differences that it makes?
94 ST1100..Gone
72 750 K2 Stay tuned!
    • BentON Racing
Re: am I an idiot??
« Reply #22 on: August 08, 2009, 08:12:34 AM »
Scunny,is that you having fun with that rear tire,light em up!!,if so stay over there  ;D ;D ;D ;D ;D,Bill
Offline Frankenkit
Re: am I an idiot??
« Reply #23 on: August 08, 2009, 09:02:18 AM »
I think that's mostly for the 750F and 650.  Could be wrong, though.  If I read my info right, for those two models, Honda decided (in their infinite wisdom) to narrow the clearance thereby somehow keeping the oil cleaner (?) to lengthen the time between oil changes to match or beat the competition... because hondas are supposed to be low-maintenance, right?  Unfortunately that meant 650s would be notorious for burning valves.
SO....
slappy valves are happy valves.
1973 CL350- Lola?
Stuff for sale
Re: am I an idiot??
« Reply #24 on: August 08, 2009, 09:05:54 AM »
Hondaman said you could go to 0.003 and 0.004 on the K models and no damage would be done if I remember right.
ateamsam
Re: am I an idiot??
« Reply #25 on: August 08, 2009, 03:46:23 PM »
O.K. so here is where I am at in the adjustments.  I am able to fit the .002 feeler gauge completely between tappet and the stem (on the rear first cylinder), so I begin to rotate the adjustment screw clockwise to tighten it so the .003 does not fit.  Here is the problem I run into ... I check to see if the feeler gauge can go through and it can, but only partially, as if part of the tappet is making contact with the stem so I am unable to glide the feeler gauge completely through.  Is that normal?  Here is the kicker, I am still able to fit the .003 gauge as well.  Am I doing something wrong or is this thing screwed up?
ateamsam
Re: am I an idiot??
« Reply #26 on: August 09, 2009, 03:06:55 PM »
Any thoughts on my last post?
Offline punch455
Re: am I an idiot??
« Reply #27 on: August 09, 2009, 03:22:39 PM »
You said you can't get the feeler gauge through, and then you said you CAN get it through.  Which one is it?  .002 should fit all the way through.  .003 shouldn't.  The point at which the adjustment screw touches the valve is fairly small.  You're not going to have an issue with the feeler gauge going halfway in.  If you have the .003 gauge and it feels like it stops, that's exactly what it should do. Good luck!
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
ateamsam
Re: am I an idiot??
« Reply #28 on: August 09, 2009, 04:23:31 PM »
It seems to me that I can only get the .002 feeler gauge partially through and not all the way.  Its as if part of the tappet is making contact and obstructing anything from passing completely through but allowing stuff to half-way slide in.  Is that possible??
Offline punch455
Re: am I an idiot??
« Reply #29 on: August 09, 2009, 05:06:11 PM »
 It sounds like you have the adjustment too tight.  The gauge either slides in or it doesn't.  But to make sure, remove the adjustment screw and inspect the bottom surface where it makes contact with the valve.
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Re: am I an idiot??
« Reply #30 on: August 09, 2009, 07:05:47 PM »
There's a guy here on the forum, maybe in the for sale section, who sells the slightly bent and pointy feeler gauges designed for this application. I bought a set and couldn't be happier. Oh and made in the US of A. He also sells plug gauges, battery acid testers, and feelers for the points. I bought everything he had. It was very reasonable. You should be able to search for it and get the right tools.
