Author Topic: Questions about polishing aluminum  (Read 8477 times)
72cafe
« on: December 10, 2005, 12:09:15 AM »
so i am going to polish up the bits on my cafe project like a sweet spinner rim. but, i don't have the foggiest idea on how to do it. does anyone know of a good place to get some info and/or want to take the time to splain to me the in's and out's???
i know i need to get a dremel, but thats all i know. educate me!!!!
Offline 78 k550
Re: Questions about polishing aluminum
« Reply #1 on: December 10, 2005, 01:16:18 AM »
to Polish rims that are stock they are chrome. If you have some aftermarket rims and their aluminum I would use Mothers mag & aluminum cleaner. It works real good. If your cleaning up cases and fork tubes and thing's like that. Mothers works great also. I'll take some pics in the morning of a fork tube I polished last week and haven't got to the other so I can give you am A, B comparison. Here is a side cover i did also. Not to much justice on the pic, indoors and dull lighting. I'll shoot the forks tomorrow. I used a 400 grit then 600, then 800, then 1200, then 1500. Wet sanded on all grits, then rubbing compound, then polish. You can see the reflection
Paul
« Last Edit: December 10, 2005, 01:20:03 AM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
theunrulychef
« Reply #2 on: December 10, 2005, 06:20:02 AM »
If your rims are clearcoated, you'll need to remove that first with scotch bright pads & some laquer thinner.  Then, like paul said, step up your grits.  I would add a tip I learned that's worked pretty well for me.  Sand each grit in one direction (horizontal or lateral) as best you can.  Then on the next grit, sand in the perpendicular direction until you see no traces of the previous grit.  Alternate back & forth until you get to 1500 or 2000.  On that final sanding, use more of a swirling motion.  Then when you're done buffing with mothers, it should shine better than chrome.
I've also found that you can skip alot of the sanding for many parts if you have access to a few toos: Blast cabinet, hard & soft wire wheels, and a few polishing wheels.  Blast off any paint & grime.  Use some 400 paper or the hard wire wheel to clean up any casting defects or large scratches.  Use the soft wire wheel to smooth it out.  Then polish using the polishing wheels stepping from brown to white tripoli.  Finally, buff it out by hand with some mothers.  This doesn't work well for finned or oddly shaped parts, but it works wonders on pieces with alot of flat surface.
I'll also skip the polish altogether on some parts that won't really be seen & are finned like crazy. I've got one of those damned black F2 motors, so piece by piece, the paint is coming off.  When I did my oil pan, I just blasted it & put it on the soft wire wheel.  Looks fine for how often I'll be seeing it.  Same thing goes for the "oil cooler" between the block & the oil filter housing.  This creates more of a brushed appearance.
If you're planning on using a dremel tool, I'd imagine you need to get your hands on some tripoli (brown & white), but since I haven't gone that route, I wouldn't be the guy to answer about that.
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #3 on: December 10, 2005, 06:29:31 AM »
Yep... What he said... Anyone can do this, but it's alot of work. I first started thinking about aluminum polishing 1 year ago. My Kawasaki ZRX has
black powder coated rims. I wanted them shiney. Today they shine like chrome. I started sanding. You just progressively move to finer sand paper.  The end result is great, but this is way too much work. I spent quit some time browsing the local Ace hardware store. I was trying different pads and wheels, looking for a way to take the labor out.
After I have those rims done, I finally hit upon something. "Scotchbrite"  You can find various scotchbrite wheels. Fit this up to a power drill, or even better an air grinder tool, driven by compressed air, this will give far more RPM than can be achieved with a hand drill. The scotchbright will actually remove small imperfections without laborous manual sanding and still leave the aluminum in excellent condition for the higher grade sanding. You can actually get an excellent shine just by doing the scotchbrite then apply the mothers and buffing. To really get the mirror grade shine there is no replacement for 1000 to 1500 grit sanding.  Also.. I use WD-40 as a lubricant while sanding.
There is one more tool you need for those parts with tiny recesses and lot of curved surfaces. An electric dremel tool. I found this to be "THE MOST TIME SAVING ALUMINUM POLISHING TOOL" I love this thing... Using only two end attachments I can take a perfectly nasty aluminum part
and turn it into very shiney aluminum in two steps.
Step 1...  Go over piece with tiny scotchbrite type wheel.
Step 2..   Now apply mothers to area and hit area with a tiny felt pad wheel.
Step 2.. Take a clean cotton rag and rub off all the black...
It will shine, shine, shine.
A simple 3 step process that will reveal mirror like shine and I've never touched a piece of sandpaper.
Pic...
You can see I've polished the outer edges of the instrument light cluster and the upper portions of the handlebar controls.
I think I'm going after the upper triple tree. It appears to be aluminum. I'm not sure if the bottom part is.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
72cafe
« Reply #4 on: December 10, 2005, 08:44:12 AM »
Bodain
what kind of tank is that? do they it 750s?
Offline DiscoEd
  • Keeping it surreal!
    • My personal gallery is at:
« Reply #5 on: December 10, 2005, 10:53:30 AM »
Bodain, can you please post some pics of these Scotchbrite wheels? I saw something in the autoparts store that I think is similar to what you're talking about but it looked way too coarse for the job.
There is one more tool you need for those parts with tiny recesses and lot of curved surfaces. An electric dremel tool. I found this to be "THE MOST TIME SAVING ALUMINUM POLISHING TOOL" I love this thing... Using only two end attachments I can take a perfectly nasty aluminum part and turn it into very shiney aluminum in two steps.
What two attachments are you using? Those little white felt wheels? How many of them do you go through? It seems like the one that I have fly apart rather quickly.
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
2003 Suzuki Volusia Intruder
http://gallery.sohc4.net/main.php?g2_itemId=1954
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #6 on: December 10, 2005, 10:54:29 AM »
in addtion to the methods described above, i've also had good luck using a good jewler's rouge with a no-stitch cloth on my 8" bench grinder/buffer. i was getting some pretty nice results sanding as described above (blasting first where neccesary), then hitting the surface with a brown tripoli and a stitched wheel, then moving up to the true rouge.
THEN, i bought this polish found here: http://www.englishcustompolishing.com/usca/products.html, and holy #$%*, does this stuff work well. it won't make a turd shine without first putting some elbow grease into it, but it did totally transform several pieces i thought i was done with. i'm rebuilding a cb550 from the frame up, and polishing and powdercoating everything. i'm using the 'metal restorer' and 'showmans blend', and this thing is looking nice.
i'll get pictures next time i'm down at my shop.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #7 on: December 10, 2005, 02:25:54 PM »
Have used Mothers for years, but a friend told me to try Mothers billet polish. Did the side covers on my 74 550 this afternoon and used regular Mothers on the 75 550 last summer. The billet is much better. Costs twice as much ($13) but is well worth it.
Fonda Honda
Offline DiscoEd
« Reply #8 on: December 10, 2005, 05:40:26 PM »
I did some experimenting today. On my CB550 the PO had taken to much of the aluminium with a wire wheel or something like that and left it in a fairly sad state. I took off one of my cylinder head side covers and set out to put some shine on it.
I first hit it with some 320 grit wet and dry sand paper. The next size i had handy was 800 (wished I had some 400 and 600). I then went to 1000 and 2000. You know it still looked fairly hideous. I could see though that it did take many of the major scratches and pitting out.
Next I went to the autoparts store and didn't have enough cash to buy the mothers billet, so I bought some stuff called "Blue Magic" metal polish. $4.51 vs. $13.89(for the Mother's billet). Anyway, I then whipped out my cheap chinese motor tool and put on one of the only two small felt pads that I had. I applied a small dab of the Blue Magic paste and selected a speed that would not sling the paste all over or make it get too hot.
Man! I gotta tell you in about two minutes the thing started looking mirror like. I don't know if the Mother's billet polish is better than this "Blue Magic" stuff or not but at least I know that my bike is really going to look great when I get done polishing it all up.
I honestly feel that by next spring I'm going to have a 31 year old bike will rival (or turn more heads than) the appearance of my brother's 1 year old "show room" Vulcan Drifter.
Maybe Santa will bring me some of that Mother's polish and I can compare the results and post my findings. I tried to take some comparison photo's of the part I worked on today but it's too difficult to see the contrast in the picture due to the flash lighting.
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
Offline CB750R
  • 77 CB750F
« Reply #9 on: December 10, 2005, 06:19:46 PM »
look up Caswell plating, they have an extensive array of polishing materials information and compounds, I bought there aluminum kit and have been very impressed.  I don't have any great pics to show because I'm mid polish but I'm redoing the polish on my D&D pipe, and I've polished the valve cover and its by far the most thourogh way I've found to polish.  It is a very labour intensive process to get aluminum to come out mirror like but man is it worth it!!!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #10 on: December 10, 2005, 10:52:22 PM »
The results are kind of Cool when your done.
theunrulychef
« Reply #11 on: December 11, 2005, 07:19:49 AM »
Damn, seaweb11, that's a nice engine.  Is that a K8?  Looks like a good combination of polishing & aluminum paint.  Don't mean to derail the thread, but if you started off with a black engine, I'd love any tips on getting the paint out of the head fins.  I've got pretty much every other piece that I can pull off all shined up & I'm just waiting for the rebuild to polish the block & head assemblies.  Also, did you clear coat the valve cover, or is it bare aluminum?
I'll have to get a hold of some of those air grinder scotch brite pads.  We used to use them to clean off gasket surfaces when I worked at a Ford shop.  I'd forgotten about those.
Jim Shea
« Reply #12 on: December 11, 2005, 07:27:47 AM »
What is the exact name of the Mothers polish referred to? It is not a popular brand here in the UK, hopefully it is available.
Offline DiscoEd
« Reply #13 on: December 11, 2005, 07:38:08 AM »
Mother's BILLET METAL POLISH
Go about half way down the page....
http://www.mothers.com/products/productcatalog/wheelprod.html
-DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
Objectionableone
« Reply #14 on: December 11, 2005, 01:29:07 PM »
Here is a good article on polishing from the Vintage Japenese Motorcycle Club.
http://www.vjmc.org/techtips/darkness.htm
Offline 78 k550
« Reply #15 on: December 11, 2005, 03:59:47 PM »
Here are the fork tubes I'm working on now.
Paul
« Last Edit: December 11, 2005, 04:01:18 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: December 11, 2005, 04:31:00 PM »
Nice! Are you planning to clear coat them when you're done, or leave them just polished?
« Reply #17 on: December 11, 2005, 04:52:07 PM »
Clearcoats don't stick very well to highly polished surfaces.  While I really like the high polish, aluminum needs frequent repolishing to maintain that apearance.
It will be dull in 6 mos to a year unless you keep it polished and waxed bi-monthly.
Clear coats onmirror surfaces will come off in sheets as the surface is so smooth, there is nothing to keep it from lifting off!
I'm pretty sure that's why Honda left the aluminum in a "brushed" appearance under the clearcoat.  The "brush" scratches make little handles for the clear coat to grab onto.
Offline Bodain
« Reply #18 on: December 11, 2005, 05:13:45 PM »
Here is my standard polishing tools. The only thing missing ultra fine wet and dry sandpaper.
Using nothing but the shown two attachments for the dremel. I get results like these.
Clutch... No sand paper ever touched this clutch cover.
Front Fork again using only the dremel tool
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline DiscoEd
« Reply #19 on: December 11, 2005, 05:30:08 PM »
Bodain,
Thanks for posting the pics. Now I have an idea what the scotchbrite wheel looks like.
Very nice work by the way! :)
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
Offline 78 k550
« Reply #20 on: December 11, 2005, 06:03:30 PM »
Bob,
 I'm just leaving them polished.
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
mylittleho
« Reply #21 on: December 12, 2005, 08:59:00 AM »
Its expensive but google ZOOP SEAL. it is a coating for billet wheels and polished aluminum that leaves a protective coating on the aluminum that lasts for 6 months..
mylittleho
« Reply #22 on: December 12, 2005, 09:16:32 AM »
Also try www.finishingforums.com
Ok nevermind that website doesn't seem to be around anymore..
also try WWW.CASWELLPLATING.COM they have a polishing forum.
« Last Edit: December 12, 2005, 09:21:06 AM by mylittleho »
Offline paulages
  • 1976 cb735
« Reply #23 on: December 12, 2005, 11:56:58 AM »
where have you found the scotchbrite wheels? i've never been able to find them on a wheel. sure is a pain in the ass to do by hand...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline dusterdude
« Reply #24 on: December 12, 2005, 12:22:06 PM »
paul,any good paint supply store will have them,they are available in 2 different styles.one is called roloc and uses a twist motion to attach to its anvil and the other is called hookit which uses a velcro attaching setup,of course this uses its own anvil setup too,also these names are 3m products
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
