Andy...
Thanks for the suggestion. I figure at this point the original bolt is shot, so cutting a slot doesn't sound too bad. Are replacements easy enough to come by? You say, look for the 17mm version?
Here's some more questions... I will likely repaint most or all of the frame. What would be the correct black color and finish to use? Is there a reasonably easy 'factory look' paint that people use on the CB frames?
Also, what online site are people using for either OEM or NOS replacement parts (other than eBay)?
Thanks again, Scott
