Author Topic: What did you do to your bike today ?  (Read 3755341 times)
« Reply #11050 on: July 02, 2012, 06:15:50 PM »
Fired that sum#$%* up for the first time since the rebuild  ;D
Offline Tews19
  • I am no
« Reply #11051 on: July 02, 2012, 06:20:18 PM »
Got the chain, after waiting a month, waiting on sprockets and swing arm bushings.
Hopefully have it all this week and have it back on the road by the weekend.
Where did you order your materials from? I ordered my sprockets from The Shop in Milwaukee Friday a few weeks ago, got it on Wednesday the following week.
1970 Honda CB750 survivor.
« Reply #11052 on: July 02, 2012, 06:23:35 PM »
And....??!!  Success?
maduncle
« Reply #11053 on: July 03, 2012, 01:02:24 AM »
Hmm - got a website for your source of sprockets?
« Reply #11054 on: July 03, 2012, 02:13:06 AM »
Redid my front end. Swapped out the rim and tire. Brought the tire to the shop where I KNOW they cut the tire. They said they didnt. They also said they would take blame for it if they mounted it but there is no way to tell. They also said the wheel is good. That the cuts should wear down and since tube tire not much to worry. After bout 15 miles of riding the cut looks bigger. Is this tire shot?
How would they have cut the tire like that mate? A "Tubed" tire is much more dangerous than a tubeless tire, as they can "blow out" (think of a balloon bursting) without any warning if they develop a bulge caused by air pressure against the weakest part. (that cut, for instance)
A tubed tire will allow the air to escape without an explosion, and without the tire disintegrating beneath you. That's a beautiful K1 you've got there, my advice (for what it's worth) would be to replace that tire before anything bad happens. Cheers, Terry. ;D
Offline Tews19
  • I am no
« Reply #11055 on: July 03, 2012, 02:56:31 AM »
I'm pretty sure they get them from parts unlimited. I would have had it a day earlier but I was unable to make it to the shop.
I think replacing the tire is the best thing to do. 116 total. Will have it done tonight.
« Last Edit: July 03, 2012, 03:01:04 AM by Tews19 »
Offline WhyNot2
  • I'm finally an
« Reply #11056 on: July 03, 2012, 04:42:09 AM »
The chain is a Diamond Sport chain.
http://kscdirect.com/item/DIA%2BXMC-1548-M-102P/DIAMOND%2BCHAIN%2BCOMPANY_-%250A
The sprockets are coming from Z1.
http://www.z1enterprises.com/catalog.aspx?pid=HPMP0
And the bronze sa bushings are coming from forum member Bob from CBX Performance.
http://forums.sohc4.net/index.php?topic=107716.0;topicseen
« Last Edit: July 03, 2012, 09:44:24 AM by budlite282 »
Offline Christoffer.Martensson
« Reply #11057 on: July 03, 2012, 05:51:23 AM »
Re painted the covers
« Last Edit: July 03, 2012, 05:55:45 AM by Christoffer.Martensson »
« Reply #11058 on: July 03, 2012, 09:14:23 AM »
Oh yeah  ;D  Ran it on the centerstand a few times. Sounds sweet. I have a few more things to do before it hits the road though. Posted a link in another thread about firing it up.
Offline stevenwr
« Reply #11059 on: July 04, 2012, 11:59:50 AM »
I just replaced my original 34 year old brake lines on my CB550k. I picked up the lines from slingshot-cycles, stock replacement lines along with the metal tube from the caliper.
I have front brakes again! ;D
Offline Mcwilliams570
« Reply #11060 on: July 04, 2012, 12:08:36 PM »
Hope to get it down to the dmv next week and then ride it. Just knocking out the never ending punch list . Dont know if anyone goes through this but am scared shi@less wondering about what bolt I didnt tighten :)
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #11061 on: July 04, 2012, 01:07:35 PM »
Matt
Having left many untightened over the years, I'm going thru the paranoia. Just got to sit down and methodically go to each fastener. Don't put the cotter in the axle until it is torqued to 50+ft lbs. The cotter is your visual cue its been done.  I safety wire it to the frame so i can pull it without laying it down.
Offline marknpb
« Reply #11062 on: July 04, 2012, 01:39:17 PM »
My guess would be, if it had a label wrapped around it like this one, they didn't have enough common sense to cut it off from the inside, but rather, used the razor blade to cut the label off from the tread side.
1974 CB750
too nice to cafe, going to make it nice and ride it,
looking for second frame with title to cafe out
maduncle
« Reply #11063 on: July 04, 2012, 02:37:47 PM »
Good call.
I was wondering how the tyre got cut, but you have found the answer.
Offline Radam
  • taco racer
« Reply #11064 on: July 04, 2012, 03:06:54 PM »
I borrowed a pair of needle nose pliers from work that are small enough to get the circlip out of my forks. I've just about got enough parts cleaned up enough to get some paint.
« Reply #11065 on: July 04, 2012, 05:44:50 PM »
Good call.
Yeah, good bit of sleuthing!
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #11066 on: July 04, 2012, 06:38:26 PM »
Fixed my cracked right side cover with some Gorilla Glue and rubber bands, then threw it on for a ride.
Offline jgary
    • Catholic Nature Cards
« Reply #11067 on: July 04, 2012, 06:59:21 PM »
Took my K6 out for a little spin, pulled the head off of the K2.
J.
1972 CB 750
1976 CB 750
Offline marknpb
« Reply #11068 on: July 04, 2012, 07:03:20 PM »
Not really, I worked in auto parts for 16 years and I've seen too many guys do this to car tires and bike tires, right in front of me! (Once on my own bike tire, which I declined to purchase...good thing I was buying that tire from that shop, I could walk away!)
Good call.
1974 CB750
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11069 on: July 04, 2012, 08:28:33 PM »
Adjusted valves. Cleaned and adjusted carbs, replaced plugs, picked up a new filter. Any recomendations of oil type? 2 quarts right?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Really?
« Reply #11070 on: July 04, 2012, 08:50:19 PM »
Cleaned her up a bit and aired the tires. May ride it to work tomorrow.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #11071 on: July 04, 2012, 09:52:20 PM »
 Well between dodging firecracker and trying to stay/be cool I cut to fit the trailer hitch ,ready for weld on 5th ,Me n welder,but ready fo.
Ride to live Live for Jesus
1977 750 F2
Offline 750K
« Reply #11072 on: July 05, 2012, 01:10:28 AM »
Did an oil change on the cb750, switched over to Rotella T 15-40. Pulled appart the kz1000 carbs and started cleaning them, boiled them for an hour in simple green on the bbq. Man did they come out clean, carb cleaner and compressed air after that. Fired up the xr250, been awhile since it I started it up.
77 Cb750, 78 Kz1000
« Reply #11073 on: July 05, 2012, 03:47:45 AM »
Not the kind of BBQ I enjoyed on the Fourth!
« Reply #11074 on: July 05, 2012, 07:04:55 AM »
Matt
Good idea on safety wiring it t the frame...Thanks
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
