Author Topic: What did you do to your bike today ?  (Read 3757991 times)
MarcinMMz and 4 Guests are viewing this topic.
Offline ChrisP.
  • Hold my drink and watch this...
« Reply #17700 on: June 03, 2014, 02:25:07 AM »
Finally took time off from riding with all the recent rain we had lately to install some different bars.
Sent from my iPad using Tapatalk
Chris P
1973 Honda CB750K3
Offline ChrisP.
« Reply #17701 on: June 03, 2014, 02:28:49 AM »
Chris P
Chris P
1973 Honda CB750K3
« Reply #17702 on: June 03, 2014, 03:19:26 AM »
I replaced the roof on my shop - where all the work is done.  Does it count?
Looks like a nice property you have Prokop,  grape vines in the back?  Hard to tell...Larry
Yes, Larry, I grow grapes to make wine.  Reds for me and some whites for my wife.  It was a project to keep me occupied when I was out of work.
Offline nccb
  • 1974 CB750 Four
« Reply #17703 on: June 03, 2014, 03:50:07 AM »
SOHC4 rally at 70CB750's house?  He'll supply all the booze  8)
« Reply #17704 on: June 03, 2014, 03:56:51 AM »
If you bring Pimpzilla  ;D
« Reply #17705 on: June 03, 2014, 05:42:20 AM »
Looks good Chris.   Consider modifying that exhaust mount, instead of going up to the shock, have it mount to the rear peg instead.  Never did like that mount that Kerker supplied.
Offline ChrisP.
« Reply #17706 on: June 03, 2014, 05:49:55 AM »
That is next on the list. I was trying to remove the baffle one day and noticed it was pretty stuck. I heard that after removing the muffler, I could take a bat and knock out the baffle in reverse. Long story to a short statement. The muffler doesn't want to come off and looks like I could do without the supporting strap all together; I don't think it will fall off.
Chris P
Chris P
1973 Honda CB750K3
« Reply #17707 on: June 03, 2014, 06:23:21 AM »
It may not fall off but still good to have support to keep it from bouncing when hitting a bump.
« Reply #17708 on: June 03, 2014, 06:42:48 AM »
I would think the muffler would work itself off.
And if you don't support the muffler, the whole leverage of the exhaust will be working flanges and studs in the head up and down and that is not a good thing.
Offline ChrisP.
« Reply #17709 on: June 03, 2014, 06:49:10 AM »
Great point.
Chris P
Chris P
1973 Honda CB750K3
Offline ChrisP.
« Reply #17710 on: June 03, 2014, 05:08:52 PM »
Knocked out the Kerker bracket mod this afternoon
Chris P
Chris P
1973 Honda CB750K3
Offline mcswny
« Reply #17711 on: June 03, 2014, 05:35:03 PM »
Chris P
Looks so much better!!!!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
« Reply #17712 on: June 03, 2014, 06:10:32 PM »
Chris P
+1.  Good job.
Offline ChrisP.
« Reply #17713 on: June 03, 2014, 06:26:35 PM »
Chris P
+1.  Good job.
Thanks! it does look a lot better and only took about 10 mins to bend up and about an hour for the paint to dry.
Chris P
Chris P
1973 Honda CB750K3
« Reply #17714 on: June 03, 2014, 07:12:03 PM »
Chris P
+1.  Good job.
Chris P
It looks like you mounted it to your swingarm....
Offline ChrisP.
« Reply #17715 on: June 03, 2014, 07:13:38 PM »
Chris P
+1.  Good job.
Chris P
Is that bad?
Chris P
Chris P
1973 Honda CB750K3
« Reply #17716 on: June 03, 2014, 07:16:10 PM »
u
Chris P
+1.  Good job.
Chris P
Is that bad?
Chris P
Only if you don't want your exhaust studs to strip out or crack your head....
Offline ChrisP.
« Reply #17717 on: June 03, 2014, 07:17:36 PM »
u
Chris P
+1.  Good job.
Chris P
Is that bad?
Chris P
Just messing with ya'
Here's a better pick of the bracket mounted to the peg.
Chris P
Chris P
1973 Honda CB750K3
« Reply #17718 on: June 03, 2014, 07:20:17 PM »
Yeah...the rear peg is the preferred place...
Just couldn't see that strip well enough in the first pic.  Much cleaner than hanging from the top shock mount.
Nice work.
Offline MoMo
  • Ride like you're invisible
« Reply #17719 on: June 03, 2014, 07:33:42 PM »
"A bottle of reds, a bottle of whites, it all depends on your mood tonight"  BJ ;)
Offline MoMo
« Reply #17720 on: June 03, 2014, 07:43:46 PM »
Did something I have not done since late fall
Well?
Hit post instead of preview.  I actually worked on a motorcycle for the first time this year and probably since Nov. of last :-[ :-[
I got the miniWang(also known has Honda GL500I Silverwing) running and ready to sell.  It had been sitting winterized since I got my golf cart(also known as Pacific Coast).  Valves, cam chain, carb sync, fluids changed, washed and waxed-ready to go to the next user(also known as forum member McWilliams570).
I was(and still am to some extent) burnt out from working on motorcycles, plus I need to get my fixer-upper house into decent, liveable condition.  Strange thing that at 67 I do not have the energy I once had ??? ???....Larry
Offline edwardmorris
  • Youngish
« Reply #17721 on: June 03, 2014, 08:39:35 PM »
Today, after many meticulous hours, I'm finally done sanding the valve train cover with the first grit. Every nook and cranny I could physically reach with my fingers and styrofoam blocks are sanded. Only place I can't seem to get into is those letters that read "OHC 750...". Should I plastic brush dremel these?
Offline Vicman
« Reply #17722 on: June 04, 2014, 03:19:36 PM »
Noticed my clutch cable isn't working too well on a lunch run.
Hopefully it's the cable and not the clutch going.
Fluent in three languages, English, sarcasm, and profanity.
Offline Jerry E.
« Reply #17723 on: June 04, 2014, 09:08:58 PM »
Installed new Webster oil gauge adapter/gauge. Mounted new right handlebar controls/cables, and hooked up the throttle cables to the carbs. Also, hand my welder do some work on my custom oil tank-if the pressure test is good, I should be ready to mount the tank and hook up the oil lines. Re-polished the oil tank with my friends heavy duty buffer-love that thing. Shiny, shiny.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #17724 on: June 05, 2014, 07:28:01 AM »
Post-rebuild flogging, DONE!  8)
run video
http://youtu.be/fgwpRdmVSjA
« Last Edit: June 05, 2014, 08:50:03 AM by flybox1 »
