Author Topic: Frame mod cb 750  (Read 84911 times)
Re: Frame mod cb 750
« Reply #300 on: September 28, 2021, 05:03:33 PM »
 I did the Gordon's kit on one bike. It came in very handy after I bent a valve.
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
« Reply #301 on: September 28, 2021, 05:11:44 PM »
I did this on my 750. I will make a set of drawings for the parts and cuts if there is enough interest.
This was done by eye as I worked out how to do it.
Made sawsall cuts on about 45Deg then cut the vertical mid supports half way.
Made (4) 3 1/2 inch long solid bars from 1inch barstock.  Ground cordial flat to clear weld inside tube frames.
Cut two 3" pieces of 3/16 x 1 "U" channel.
Clamped it all together and drilled thru to bolt together with saddle washers as shown in pics. the center support is drilled and tapped for M6 screws.
« Last Edit: September 28, 2021, 05:15:21 PM by markmyodb »
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
« Reply #302 on: September 29, 2021, 02:19:35 AM »
Good job mate, that should work fine. I make something similar, but on top of the threaded slug inside the tubes to keep it rigid, I use a tight fitting sleeve on the outside of the tubes, and I reckon it's as rigid as the frame was before cutting it, and of course with only 1mm cuts, everything can be easily welded back together if the current owner wants to make it 100% original. ;D
« Reply #303 on: September 29, 2021, 03:09:15 AM »
It is a pity that some pure stock people see this as a value issue.
Both my CB750 have Franks kit and I do not want to be without it.
I have had frequent use of that upgrade.
Pulling engine for a cam change or head gasket replacement, silly!!
Honda made a mistake, frame kit correct it. ;D
« Reply #304 on: September 29, 2021, 10:25:22 AM »
 I have more kits in the works.,  just keep getting sidetracked. Should be soon
« Reply #305 on: September 29, 2021, 03:49:52 PM »
 I'm going to look at a drag bike that had a frame mod with the tubes curved up as in the cb750A except fits within a stock k tank. Not sure about coils though, it may have run a magneto. If I buy it or not I'll try to get a pic.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #306 on: September 29, 2021, 07:11:43 PM »
I put an A tunnel into an F tank, and put onto an A frame.
« Reply #307 on: September 29, 2021, 07:57:42 PM »
 That's impressive.
« Reply #308 on: September 30, 2021, 02:34:39 AM »
 That's impressive.
Let's face it Don, the "A" is just a very impressive bike! (and I'm not just saying that because I want to sell mine......) ;D
T500 Wednesday 25 Aug 2021 by Terry Prendergast, on Flickr
Offline disco
« Reply #309 on: September 30, 2021, 03:19:56 AM »
I have 2 x Frank’s kits and also 2 x Gordon kits. Both are extremely worth it in my opinion. Makes doing maintenance easy as PeWe has said. They also give me peace of mind and they look professional.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Mochacho916
« Reply #310 on: August 19, 2025, 04:03:42 PM »
I will have more soon, spent a full day on them last week, another day I should have 7 or 8 sets ready..
Stilll making these?
« Reply #311 on: August 19, 2025, 04:09:29 PM »
Frank passed away almost 4 years ago. :'(
« Reply #312 on: August 19, 2025, 04:42:17 PM »
Man 4 years have flown by......
