Author Topic: can this boat sink?  (Read 12249 times)
MötleyRöx
Re: can this boat sink?
« Reply #25 on: December 17, 2009, 05:12:33 PM »
Like having a bilge pump, and having a bilge pump that will do the work are two different questions.
But you knew that.   ;)
« Reply #26 on: December 17, 2009, 05:17:15 PM »
I traveled in a 20 foot aluminum open boat with 6 meter waves crashing over the side for 3 hours with 2 bilge pumps going flat out for the whole trip home, the pumps were able to remove close to the same amount of water as was coming over the side even though, when we finally got home there was probably 50 gallons of water still being pumped out of the boat it didn't sink.
MötleyRöx
« Reply #27 on: December 17, 2009, 05:18:48 PM »
dammit... the question is not about the bilge pump... its LIKE having the pressure of a bilge pump!
Offline vanillagorilla
  • When did I become a
    • The ole Facebook Profile...
« Reply #28 on: December 17, 2009, 05:19:17 PM »
But what about the splashes that don't make it out of the boat??? Theres no way that ALL the water gets out of the boat! Eventually all the little drops that don't make it out will sink the boat!!!
Wonder how heavy you're typical flat bottom boat would have to weigh to force the water out and over the hull... Someone smarter than me figure it out.  ???
Markcb750
« Reply #29 on: December 17, 2009, 05:20:38 PM »
Hedley Lamarr:
My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives.
Taggart:
Gal-darnit, Mr. Lamarr, you use your tongue prettier than a 20-dollar whore.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #30 on: December 17, 2009, 05:22:03 PM »
If you are traveling backwards at 101% the speed of light, are you moving forward at 2997924.58 meters per second?
No.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #31 on: December 17, 2009, 05:23:46 PM »
I wonder what the boats characteristics would have to be?
« Reply #32 on: December 17, 2009, 05:24:29 PM »
That was not the question..
Offline racerx95
« Reply #33 on: December 17, 2009, 05:27:15 PM »
If you turn your headlights on while driving faster than the speed of light,what will happen?will the light be going twice as fast, or will it kind of just bleed off the sides?  kind of like water.
« Reply #34 on: December 17, 2009, 05:29:11 PM »
 ;D...i like the way you think.....and i will also like to see the answers... ;D
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #35 on: December 17, 2009, 05:29:14 PM »
It's relative.
No.
MötleyRöx
« Reply #36 on: December 17, 2009, 05:29:54 PM »
Neither was anything relating to a bilge pump!
  • Like a well oiled
    • Undead Asphalt
« Reply #37 on: December 17, 2009, 05:31:51 PM »
I think if you're traveling at the speed of light, what your headlights are doing is the least of your worries.
« Reply #38 on: December 17, 2009, 05:33:22 PM »
You must come from another planet....it was used as an example......got it now.... ???
The point was that if the water is pumped out in any way similar to the amount coming in it won't sink....
« Last Edit: December 17, 2009, 05:35:08 PM by retro rocket »
MötleyRöx
« Reply #39 on: December 17, 2009, 05:37:30 PM »
Very specific question... Mr. interplanetary traveler.
Your example, while illustrative, does not answer the question posed.
Do you get it now?
  • Like a well oiled
    • Undead Asphalt
« Reply #40 on: December 17, 2009, 05:39:58 PM »
GIRL FIGHT!!!
« Reply #41 on: December 17, 2009, 05:41:35 PM »
I don't generally argue with people that just don't get it but it was an EXAMPLE of water displacement......put down the joint and get over it. Go to google and type in example....its not that hard.......did i type it slow enough for you..... ::)
Move on mate ....your the only one not getting it....
« Reply #42 on: December 17, 2009, 05:42:37 PM »
IC i find most of your posts amusing but sometimes they really piss me off....got anything constructive to add....
  • Like a well oiled
    • Undead Asphalt
« Reply #43 on: December 17, 2009, 05:42:57 PM »
maybe this fits better.
 :D :D :D :D :D :D
my threads are fun.
Markcb750
« Reply #44 on: December 17, 2009, 05:44:42 PM »
Are you at warp, or have you entered hyperspace?
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #45 on: December 17, 2009, 05:45:24 PM »
if you poke a hole in a boat and the water squirts over the side, will it sink?
I don't think I fully understand the question...
Is the hole poked in the bottom of the boat?  And you're asking, if the water comes up through the hole, will the boat still float or sink?
He's asking if the hole was poked in the bottom of the boat, and that water had enough pressure to be shot outside the boat, would it sink....
Don't ruin it with the obvious, Soi :)
I had my explanation typed up, but I deleted it so as not to ruin the fun for everyone else.  I'll just state my conclusion.  And this should leave many of you scratching your heads...
The boat sinks.  And believe it or not, the way the problem is stated, it sinks even if there wasn't a hole.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #46 on: December 17, 2009, 05:46:09 PM »
Exactly.
No.
  • Like a well oiled
    • Undead Asphalt
« Reply #47 on: December 17, 2009, 05:46:25 PM »
I think if the boat is shallow and weighted down enough, and the hole is close enough to the side for it to make it's way into the lake, it will float for some time.
 but water never all leaves in a stream, some is cast off and lands on the inside of the boat.
after time it should sink.
Offline Gordon
  • 750K1, 550K2
« Reply #48 on: December 17, 2009, 05:47:50 PM »
Sounds more to me like somebody isn't getting any. ;)
  • Like a well oiled
    • Undead Asphalt
« Reply #49 on: December 17, 2009, 05:48:09 PM »
cause eventually it'll rot or rust and sink?
              edited for retarded typing.^^
« Last Edit: December 17, 2009, 05:49:47 PM by Industrial Cafe »
