Author Topic: Metal/Tank Guru's Help!!!  (Read 851 times)
Offline socalsupermoto
    • Socal Supermoto
« on: March 03, 2010, 12:39:12 PM »
my tank was gummed up bad, so I did this:
http://www.chopcult.com/forum/showthread.php?t=2208
now the tank is super clean, but develops pinholes that turn my tank into a gas sprinkler. 4 times so far. wife is not so happy about this. I've patched so far with jb weld, any other suggestions? any kind of sealant from the inside of the tank?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Metal/Tank Guru's Help!!!
« Reply #1 on: March 03, 2010, 12:48:10 PM »
Dam! I thought this was going to be about music ;)
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Offline Toxic
« Reply #2 on: March 03, 2010, 12:50:31 PM »
Short of welding all the pin holes, your best bet is to use a liner.
Do a search for Por15 or Caswell plating have a good one.
I have used Kreem several times with good results but alot of people don't like it.
Whatever you use it's all in the prep and following the directions to the letter.
The longer you let the liner cure the better, give it a week and then re-coat if need be.
Gary
Offline jtsmith
« Reply #3 on: March 03, 2010, 01:06:08 PM »
I have heard great things about Por15 as well.
1975 CB750K
    • Socal Supermoto
« Reply #4 on: March 03, 2010, 01:23:59 PM »
thanks guys. I'll look up por15 and just follow the instructions. thanks!
Offline Warthog1959
« Reply #5 on: March 03, 2010, 02:04:21 PM »
http://www.caswellplating.com/aids/epoxygas.htm
I have just done my tank in this. It is great, but the liquids do need to be stored in a warmish environment before use or else it is difficult to swill around the tank. Make sure you drain the tank of all residue. 1 kit is enough to give the tank 2 coats. It is like rock hard glass inside my tank now. It is available in the US and the UK. Instructions are available on this web site. Discovered it in Cafe Racer Magazine. It is good for fibreglass tanks also.
Offline Toxic
« Reply #6 on: March 03, 2010, 02:07:52 PM »
Follow the instructions to the letter as just about everyone that I know that has had an issue with any sort of tank liner has either taken a short cut or failed in following the directions.
Big tip for ya:  Make sure when you tackle the job allow yourself lots of time.  It is time consuming.
