Author Topic: 1977 cb750f2 (915cc)  (Read 276473 times)
Re: 1977 cb750f2 (915cc)Kerker
« Reply #775 on: May 20, 2012, 01:22:35 PM »
I'm curious too about which pipe wins the shoot-out. Thanks in advance for testing too, truth be known, seat of the pants can mislead...
I don't mean this to sound bad, but in the early seventies when there were so many pipes available I don't remember Kerker being thought of as top of the heap. Maybe I'll eat my words & that's great. Pick a pipe that you're happy with and if you can test like you will, perfect. Getting the jetting spot on completes the package and you'll have that.
Recently someone (MikeR maybe) mentioned there would be a magazine test of available CB750 pipes. I'm always interested in this stuff. I recall "in the day"both Yosh and Action Fours having pipes that delivered more power than stock, so many others actually performed poorer than OEM.
I looked forever for a Yoshimura and ended up modifying a Kerker for my racebike. I think I'm in a good place with it too.
Offline tweakin
  • tear down
« Reply #776 on: May 20, 2012, 02:24:20 PM »
bwaller, I agree that "seat of the pants" is just that, only the dyno time can tell.  If the Yamiya was a true Yosh pipe it might be different.  One thing I have learned in all my builds is that a ton goes into pipe performance, just because a pipe looks similar you can have a HP swing of over 10HP with pipes made by different manufactures (because of build, bends, diameter and design).  No experience on cb's yet but I have done a ton of dyno testing on Harleys where this is the case.  I to look forward to the cb exhaust shoot out.  Limited pipe choices for cb's is a bit disappointing but I have to work with what is available.
Hope to have a couple runs with the Kerker soon and then I will know for sure, but the bike seems to run stronger and never lifted the front wheel as easy like it does now with the Kerker.  I only wish the dyno I use had an accurate torque reading and not just HP.
Offline KJ790
« Reply #777 on: May 20, 2012, 06:19:36 PM »
I'm curious to see how the Kerker looks on the dyno as well. As for the torque curve, that is easy to calculate from the HP curve since HP=(torque*RPM)/5252.
Offline Doctor_D
« Reply #778 on: May 20, 2012, 07:22:06 PM »
That's not the issue.  It's that the coil trigger lead on Tige's bike is so tightly wrapped into his harness, that we can't get solid rpm's on the run.  Even if we could, for some unknown reason the coil wire sensor is hit and miss with Dyna 2000's. For example, it worked perfectly on Branden's CB750, but has only worked about half the time on my bike.
The other option we have, the inductive plug-wire sensor doesn't seem to like good plug wires.  This results in our rpm-based readings skipping around a bit.
Oddly, old wires and points = perfect rpm logging.  I have a few ideas I'm gong to try this week to see if we can improve on the situation.  In any case, Tower will be making some updates to the dyno this summer should solve some of the little headaches we have with it.
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #779 on: May 20, 2012, 07:36:56 PM »
Tweak,
Back to you. Not much progress today  >:(  At this point it slows considerably due to all the unknowns. Thanks to you, Branden, Steve, and others for making it easier!
I did manage to get the Dyna2000 timed at the 37.5o mark for starters. Wasn't too bad an ordeal ONCE YOU UNDERSTAND WHAT THA HELL THEY MEAN  ;) Look back, it's a piece of cake. Pre-set it for curve 4 based on Dyna's recommendation for SOHC4 without high compression. 10.5 is higher than 9.0 or 9.2 but it's not 12.5 either. Thoughts on this? Rev limit at 10K for now. Dyno will show me the best power spot.
Think I got that rear master mount finally installed correctly too. As you know going by the parts books exploded views is usually good enough unless it's exploded too much. lol.
Of course I just had to jump on the other bike and search for 1/8" hose connectors. lmao. You'd think a guy'd learn from others but your link doesn't work now. Hey, at least I got a little riding in. Mr Brown will be bringing them to me in a few days. At this point I ask - where did you find the rubber caps? I took a look at the throttle cables with the CR carbs in place. Damn good thing I gotta take them off for the install of those connectors. I did learn on this. I will install the cables on the carbs BEFORE installing the carbs this next time. The return will go on but the pull will not. Stock cables look like a really tight and short fit and may not fit under the front tank mounts as they did with the stock carbs. We'll see.
Kerker - looks like my baffle that Dynoman sent is 2", not your 2.5". Looks like your's is recessed more than my 2". Mine has a helluvalot bigger opening than that nice toned quiet original. It'll have to do for the price for just a friggen baffle! Hey, what's a half inch! The ex never complained. Wait, she ALWAYS complained so 1/2" didn't matter. I know our exhausts and mounts are different but take a look at mine. No way was I going to strap that big ass hanger from the top shock mount on my bike. I took the hanger and chopped it up and shaped the cuts and made some bends. It's attached behind my rear foot peg. Don't ask me why I did the 2 piece?? That's been a number of years back. It stays in place very well.
« Last Edit: May 20, 2012, 07:41:54 PM by Jerry Rxman Griffin »
Offline tweakin
  • tear down
« Reply #780 on: May 20, 2012, 07:51:25 PM »
Jerry, here are the caps I am using for the synch ports added to the carb boots.
http://www.bikebandit.com/search?q=1046965
And here are the retaining clips
http://www.bikebandit.com/search?q=1030534
Yes, I always install the throttle cables with the carbs loose, then install the carbs.  Much easier IMO.  I had my timing set at 37 degrees but scaled it back to around 32 degrees and am happy with the performance.  Next time I hit the dyno I might play around with it a bit.
I like your exhaust hanger, but I don't think it will work for my build since I went with the custom rear sets.  I am thinking of having a custom billet hanger made up.
Sounds like you are getting close, wish I was closer so I could bring over a few beers for the initial start up. ;D
Offline tweakin
  • tear down
« Reply #781 on: May 20, 2012, 07:54:49 PM »
Thanks for the explanation David.  I think the dyno at Twineline works fine, especially with you and Tower helping with the tune.  Not super worried about the torque figure but suspect it might go up with the exhaust change.
Offline tweakin
  • tear down
Re: 1977 cb750f2 (915)
« Reply #782 on: June 15, 2012, 06:26:15 PM »
I decided to take out both Fs this afternoon and do a bit of comparison on the two with the different engines.  The bikes feel completely different for obvious reasons.  The 915 just wants to go and go, MUCH faster acceleration and power and the more aggressive riding position makes me feel like I am on a racer.  The 836 is an amazing all around bike.  Super comfortable and plenty of power when needed.
click on pics to make bigger
I have to say I F'n loves these bike and all cb's, its like they touch my soul...
« Last Edit: June 15, 2012, 06:28:04 PM by tweakin »
Re: 1977 cb750f2 (915) photo update
« Reply #783 on: June 15, 2012, 06:36:32 PM »
Beautiful shots Tige, ignore my request for more info in the other thread....its all here.... ;D ;)
I know you love both bikes just the way they are but if it were me i would slip the "big" engine into the red bike, i just love that bike, its overall balance is just perfect.... ;)
Offline brandEn
« Reply #784 on: June 15, 2012, 07:41:14 PM »
Great pics. I think Retro is on to something.... 915 in the monkey trainer. Lego CB's.... nice.
« Reply #785 on: June 15, 2012, 08:04:50 PM »
F'n A bro. We need one more F added to a picture now. A burnt orange colored F would make a good contrast  ;)
« Reply #786 on: June 15, 2012, 11:59:33 PM »
Outstanding Tige! These builds are such an inspiration! Agree with Jerry you need a sunrise orange one in there ;)
The builds are great, bikes look good and...the run very very well. You hit all three! And you even make comstars look good! Agree the red bike is really something. The tail piece is very cool. If you ever sell the red bike put me first in line please!
thanks for sharing
Andy
« Last Edit: June 16, 2012, 12:02:46 AM by andy750 »
« Reply #787 on: June 16, 2012, 12:50:26 AM »
Tige, there is a third option, build another 915 motor. Maybe sell the 836 motor...
Or build another bike, putting the 836 in that new bike, with that bike's motor being built up as a 915 to swap into your burgandy bike.
Both bikes are great...
My 78 CX500 has those same Comstars with the black plastic caps at the rim. It was a one year only thing for the CX as the 79 had the wheels without the black plastic covers.
Then the next year they did the ugly reverse Comstars. Those look OK if you polish the rims and the flat edges of the stamped spokes. Seen a few sets of Comstars powder coated or nicely painted in colors like bronze, gold, and a set in yellow with the flat edge painted black rather than being polished. Yellow bikes need a decent amount of polished aluminum, steel, or chrome on the bike to look best,
I've also seen the reverse Comstar spokes stripped and polished to a high sheen before protecting with a urethane clear coat.Those took a lot of time to do and looked really good.
Offline tweakin
  • tear down
« Reply #788 on: June 16, 2012, 06:00:53 AM »
Thanks for the complements guys, it is funny how much you guys like my quick 1978f3 build.
I actually really like it too and it will probably get most of the saddle time but it will never get the 915 engine or any other 915 engine. :D   I built the 78 to be a "sport touring" bike that is comfortable and good for longer rides.  The 915 engine would totally defeat the purpose of the build, I can only get 95 miles on a tank....  Also the 78 has many upgraded parts but not nearly as many as my 77 that was built to compliment the 915 engine.
My 836 in the 78 is no slouch.  DP JE 836 pistons, heavy duty studs and chains, all new bearings, APE F2 head with SS valves, Ti retainers and mild porting, and CR29 carbs.  It will go!
Offline tweakin
  • tear down
« Reply #789 on: June 16, 2012, 06:04:06 AM »
Jerry, It is easier to ride one bike 1400 miles vs me bringing two. ;)  Any time you want to make the trip up this way give me a shout, you have a place to stay.  I love the burt orange... If I lived closer I would break into your garage and finish that build up for you. ;D
« Reply #790 on: June 16, 2012, 07:23:09 AM »
For now I was talking about that "other" builder up your way. What was his name anyway?? BrandEn?! Mine is not running yet so I couldn't do it but we'll see what this next week brings as I'll have some play time.  ;)
Offline tweakin
  • tear down
« Reply #791 on: June 16, 2012, 09:08:47 AM »
Yes Jerry we will get some picks with brandEns bike in the mix.  I met brandEn when I was about half way into building the 915 and its great to have another builder into the same things so close.  The majority of the work we do on all our bikes is a joint effort.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #792 on: June 16, 2012, 09:24:26 AM »
Awesome pair of 750’s Tige.
Let’s consider taking them both on the Cascade Loop and leaving my anemic little 550 at home.
Four hot 750’s……that would be so keul.  ;D
« Reply #793 on: June 16, 2012, 09:27:19 AM »
Two awesome bikes, you should be very, very proud.
What's next? (othervthan riding) any plans for another build?
Offline brandEn
« Reply #794 on: June 16, 2012, 11:24:47 AM »
Im in for a photo shoot. Two 78's and a 77. Sounds like a Johnny Cash song.
« Reply #795 on: June 16, 2012, 11:40:15 AM »
Only if "you walk the line"  ::)
Offline tweakin
  • tear down
« Reply #796 on: June 16, 2012, 12:48:45 PM »
Jim, I am tentativly planning on riding the 78 on the trip just because the 915 gas milage sucks.  You 550 is far from anemic.
Thanks Stev-o.  The real plan is to just enjoy these bikes for awhile.  WHen I get the itch again; it would be cool to have a 76f added to the line or I have always wanted to do an "over the top" 400f.
Offline kap384@telus.net
« Reply #797 on: June 17, 2012, 09:32:39 PM »
Sweet.  you do the "over the top" 400f and I'll do the stocker 400f and we'll do our respective photoshoots with our '750's'!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline nvr2old
« Reply #798 on: June 25, 2012, 12:46:13 PM »
What a beautiful pair of bikes, tweakin.  I can't pick a favorite.  It's like trying to pick a favorite child.  Both are so perfect in their own respective ways.  Your attention to detail is so spot on for each of them.  Can't wait to see brandEn's next to them.  Proud to've been a small part of them all.  Thanks, man.
Larry
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline madScientist
« Reply #799 on: June 26, 2012, 12:10:36 PM »
I am pretty new to the forums and read through this entire thread (twice). To say you have inspired me is an understatement!
I have 2 78 750f's. After reading through this I have an idea of what I'm going to do with the one i'm not restoring. Thanks for this great read and the inspiration!
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
