Author Topic: I think I blew my oil pump at 75mph, Pre case split findings, with gory pics?  (Read 10822 times)
Offline manjisann
Ok, the obvious thought from the subject like is "bugger". Quick story. I went on a trip with a small oil leak from my oil pump. I figured I'd keep an eye on the oil level and just add as needed. This worked great for the first couple of days. Sometime within the last two days I developed a ticking noise on the top end. At first I thought it was my tach cable as it was old and you could pull it out of the end that holds it into the tach gear on top of the engine. It turns out this wasn't it, I'm beginning to suspect it may have been valve noise.
I was trying to use the power of positive thinking and get back home, about a 160 mile drive. After 60 miles I stopped to stretch and fill the gas tank. I also checked the oil level, it seemed to be full. I get back on the freeway and enjoy how well the bike is working. 13 miles later she starts to lose power drastically. My initial thought was that I was having electical issues again so I tried giving her more juice in the vain hope she'd snap out of it. I don't remember why but I looked down at my left foot and saw this huge geyser of oil coming out from my starter motor cover, I think. I was doing 75 and trying not to get hit so my full attention wasn't there. I pulled off to the side of the road and the bike died. I called some family to come get me and then proceded to push the bike the .4 miles to the freeway exit. When I got there I wondered if I had siezed the engine so I left the ignition off and hit the starter. it sounded like there was some metal or something banging around in the head. I figured it was just the top end complaining that it had no oil. I waited 5 hours in the blazing hot
« Last Edit: July 30, 2010, 09:04:26 PM by manjisann »
1980 CB650 Custom
Offline scunny
  • don't call me expert
#$%*e, doesn't sound good. when you have calmed down take your tappet covers off and check out the cam and followers.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Frankenkit
  • Industrial Strength
oh noooooo
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
If this is a 500/550 you probably dont want to hear that the cam bearings are part of the head and rocker cover
Offline crazypj
  • I'm brill, me
If it's a 500/550 you should have known the oil pressure switch literally 'blows it's top' that would have been a quick easy fix, just screw in a new one.
 Riding with even a small oil leak where it can get on tyre is just dumb (not same as oil leak between cylinder fins, another common 'problem')
 Saying that, I really  hope get lucky with it and don't have any terminal damage
PJ
Offline Spanner 1
+1 with crazypj... the oil pressure switch 'blew'.... maybe the plastic part was already cracked ?   The o/p switch sits in the main oil galley so an  opening here would would receive the full pressure of the oil pump and quickly steal any oil circulation, starting with the cam/topend....... prolly the worst place to spring a leak ( hole really ) just above the oil pump....... best of luck with it mjn.
I think the OP's bike is a CB650.
FYI
Offline Spanner 1
O.K., if it's an '80 CB650, then the oil pressure switch is directly on the oil pump on the left side and oil would appear at the starter recess quickly and spray as described too IMO.
Offline manjisann
TT's right, it is a 650. Sorry for not putting that info in. By the time I got home it was about 11pm and after 6hrs sitting in the desert sun I suppose I forgot to include important details like that  :-[
So the bright side is my oil pump didn't blow, and if my head seized it is the least of my worries. I opened the sprocket cover and found this awaiting me. Guess I'll be looking for a new engine, or at the very least, new cases.
Thanks everyone for chiming in  :)
Brandon
1980 CB650 Custom
Offline camelman
  • Man... Myth... Legend
Is that a crack in the case?
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
That's a bloody hole mate, what the hell would have caused that? :o
Offline manjisann
As Hush would say, Terry wins the Chocolate Fish. I'm guessing I threw a bearing from the crank, but I could be really off. I've never been into an engine far enough to really know what is down there. I've got a spare engine but I don't know if it works or not, it came with a frame I bought to fix the buggered one during the build. I'm crossing my fingers that the spare engine works with minimal tlc, if not I'll have to reassess my options. I've put out a couple feelers for running engines, but if that falls through there's a guy locally selling some cases for about $100 so I'll be doing a huge ass rebuild. Either way, I'll be very busy for a bit. Guess I'd better do some searchfu and see what it's going to take to rebuild it. Anyone know a source for quality gaskets that won't break the bank?
Brandon
1980 CB650 Custom
Offline Frankenkit
I've heard from others not to cheap out on the head gasket, to go OEM, but fwiw, my $86 Athena gasket kit hasn't leaked (yet). though the rubber gaskets for the tappet adjustment covers started to flay away and leak shortly after installation.
1973 CL350- Lola?
Stuff for sale
Offline vern401
I would get your backup engine out of moth balls.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
G'Day mate, yeah, if it was me I'd install the spare engine and just use what you need from your buggared one, like carbs, ignition etc to get it going. Chances are, it's OK, and even if you need to take the head off later you can do that with the engine in the frame anyway, and as my old dad always says to me, if it aint broke, don't fix it! Just change the oil and filter, and fire that sucker right up! Cheers, Terry. ;D
Offline crazypj
  • I'm brill, me
Damn, now I feel bad.
 That must have been cracked for a while before it let go.
Will be interested to see if all the pistons are still in one piece
Looks like something solid got picked up by crank web
 I think you would have known if it was rod bearing
PJ
This is the bike with the 750 carbs on it, right?
Offline manjisann
Yes it is, er was. I don't really think that had anything to do with it though.
Yeah, I'm hoping it will be a simple move over, I just don't want to stick it in the frame if it's not going to run. I'll give it a checkup in a bit and see what I'm looking at. The bike it came from had some fried electrics and I suspect that's what got it a trip to the junkers. Hopefully the engine was fine. we'll see soon enough :)
Brandon
1980 CB650 Custom
Out of morbid curiosity, I request a proper autopsy be performed on the deceased. :(
Offline Spanner 1
Wow, never seen the like of it!.... may/must have been a bad casting from the get-go... anyone else got an explaination ?
Threw a cam chain? It looks like something was trying to punch it's way out like in Alien!
Offline Spanner 1
 Too far to the left for cam chain IMO.... #2 big-end bearing ??
Thought the same thing about being on the left side, but a rod bearing, no matter how worn, would not allow major contact with the case wall. ???
Maybe more damage is hidden behind the starter, more to the right?
« Last Edit: July 24, 2010, 09:54:16 PM by scottly »
Offline Spanner 1
Agreed, the visible hole may not be all the damage, may be a bigger hole under the starter motor!
