Author Topic: Oil coming out of tach drive.....  (Read 2159 times)
Offline Dunstall_74
« on: August 11, 2010, 05:29:33 PM »
Been trying to find the phantom oil leak.  Looks as though it's coming from where the tach cable mates up to the valve cover.  Anyone ever experience this?  Is there a remedy?
''It is clear our nation is reliant upon big foreign oil. More and more of our imports come from overseas.''
—President George W. Bush, Beaverton, Ore., Sep. 25, 2000
Offline wookie
  • I would get up if i knew i fell
Re: Oil coming out of tach drive.....
« Reply #1 on: August 11, 2010, 05:32:27 PM »
put a new oil seal in.  easy fix.
Offline Dunstall_74
« Reply #2 on: August 11, 2010, 05:36:18 PM »
Do I have to pick one up from the Honda shop, or is it something I can get at the hardware store?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: August 11, 2010, 05:37:22 PM »
It's specific to the bike, so ......dealer, or order one online.
Offline Dunstall_74
« Reply #4 on: August 11, 2010, 05:42:48 PM »
OK,  Thanks
« Reply #5 on: August 11, 2010, 05:48:15 PM »
Or do the cheap arse fix and just splooge some sealant around the end of the cable housing and poke it back into the rocker cover, making sure there's a fine bead of sealant all the way around it. I know I should do it properly, but hey, it works! ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #6 on: August 11, 2010, 05:55:03 PM »
Yeah, they cost what.......$4.95 ;D
Offline Dunstall_74
« Reply #7 on: August 11, 2010, 05:56:53 PM »
I was waiting for someone with the McGyver trick,  Just a little duct tape and zip ties and anything's fixable  ;D
« Reply #8 on: August 11, 2010, 06:19:10 PM »
That's it mate, I've been doing that trick for the last 30-odd years that I've owned CB750's, and it works fine. Cheers, Terry. ;D
Offline Shenanigans
  • Right turn?
« Reply #9 on: August 11, 2010, 06:30:27 PM »
I think I remember reading that you could put a tach seal in from a early DOHC Honda 4 and that it would seal/last a little better than the "correct" one since it was slightly larger?
Offline Johnie
« Reply #10 on: August 11, 2010, 06:41:57 PM »
Correct...that Honda number is 91256-425-003
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Silverback
« Reply #11 on: August 11, 2010, 06:49:05 PM »
Just did this last week, plus a little around the base of the bolt head and outer mating area. Used the black stuff. Clean as a whistle!!
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
« Reply #12 on: August 12, 2010, 02:52:07 AM »
That's it mate, and I made my own seal for a Suzuki GS1000E a year ago, my Suzuki dealer didn't have one in stock (why was I surprised?) but I had a sheet of 4mm thick rubber and so I just cut my own seat with a couple of round gasket punches, the sealant trick doesn't work on this model, but my cheap-arse seal works like a dream! Cheers, Terry. ;D
Offline Dunstall_74
« Reply #13 on: August 12, 2010, 01:49:05 PM »
Just tried Terry's McGyver trick.  Weather is too nice to wait around for oil seal to show up in the mail  :D  Will see how it holds up.  Thanks!
Offline Dunstall_74
« Reply #15 on: August 13, 2010, 10:39:10 AM »
Sealant at the tach drive worked like a charm!  Any good McGyver tricks for fixing a leaky head gasket??? ;D
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #16 on: August 13, 2010, 11:28:12 AM »
Macguyver fix for the head gasket... Hmm how'd they do it on my bike? Oh yeah! Red high temp sillycone fix your head, valve train, and oil pump all at once. Fix it real good lol
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
« Reply #17 on: August 13, 2010, 06:25:13 PM »
Ha ha, nah, sorry mate, the "cheap arse" approach would be just to re-torque the head and re-seal the little rubber pucks under the rockers, but really, by the time you've gone to that extent you may as well go the whole hog and replace the head gasket and all the top end seals.
There is a McGyver trick though, the manual tells you to torque the head to 15 ft lbs, (from memory) if you follow the instructions, a year or two down the track, it'll leak again. Torque it down in 4 ft lb increments to 16 ft lbs, then in 2 ft lbs increments to 20 ft lbs. Make sure all the threads are clean and lightly oiled before you start torqueing it down.
Leave it overnight, then in the morning, loosen all the nuts off again and re-torque it in the same manner described above, and it won't leak. Ever. Make sure you piut a little sealant around the little rubber pucks too, quite often oil leaking from them is misdiagnosed as a leaking head gasket. Cheers, Terry. ;D
