Author Topic: MIG or TIG?  (Read 4432 times)
Offline joe29
MIG or TIG?
« on: October 12, 2010, 11:21:48 AM »
I've always wanted to learn basic welding and found a local shop offering a series of introductory classes.  They offer classes for MIG and TIG.  Which should I take?  I see myself welding frame hoops (BCR style) and simple mounting brackets for rearsets, gauges, etc.  That's probably the most welding I would want/need to do.
Any thoughts?
Here are the class descriptions:
http://techshop.ws/take_classes.html?categoryId=Welding+%2F+HotShop&submit=Change+Category
-joe
1976 CB750K
1974 CB750K
1972 CB750K
Re: MIG or TIG?
« Reply #1 on: October 12, 2010, 11:37:03 AM »
If you are only going to be welding steel, I would go with MIG. These are point-and-shoot welders, are easy to use, and small ones are reasonably priced. TIG welding is more versatile and more precise, but takes greater skill to master.
Offline tramp
Re: MIG or TIG?
« Reply #2 on: October 12, 2010, 02:30:09 PM »
mig is for general welding
tig is for fine welding
as a rule of thumb
1974 750k
Offline syth82
  • 1976 cb550f project
Re: MIG or TIG?
« Reply #3 on: October 12, 2010, 04:15:09 PM »
If you learn tig, mig is easy. If it's one or the other,  I'd go for the tig class.
-Luke
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
Re: MIG or TIG?
« Reply #4 on: October 12, 2010, 05:14:12 PM »
I'd search vids on youtube if I were you.  It might help you decide.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline Alan F.
Re: MIG or TIG?
« Reply #5 on: October 12, 2010, 06:06:01 PM »
+1
Re: MIG or TIG?
« Reply #6 on: October 12, 2010, 06:12:07 PM »
+1
+ Another one. I bought a MIG years ago, and after a couple of hours I was welding like a pro. I've owned an AC/DC TIG since March and I'm still struggling. Nothing wrong with knowing too much! ;D
Offline joe29
Re: MIG or TIG?
« Reply #7 on: October 12, 2010, 06:21:09 PM »
Thanks for the feedback. I went ahead and signed up for the MIG class. I think MIG will cover the basic stuff I want to do and sounds easier to get the hang of.
-joe
1976 CB750K
1974 CB750K
1972 CB750K
Re: MIG or TIG?
« Reply #8 on: October 12, 2010, 08:06:47 PM »
When you go to buy a welder, I would recommend a 220 volt input unit. The 110 volt jobs are a bit gutless, especially when used with gas, vs flux-core. My personal preferred brand is Lincoln..
Re: MIG or TIG?
« Reply #9 on: October 12, 2010, 08:09:28 PM »
Yep, I've got a 220 AMP, 240V MIG and it'll weld anything from tin cans to railroad tracks. Don't buy a "gasless" MIG, they're shiit. ;D
Re: MIG or TIG?
« Reply #10 on: October 12, 2010, 08:38:09 PM »
Flux-core has it's place. Greater penetration than solid wire with gas; that's why the cheapie 110 volt jobs tend to be gasless. My 135 amp, 220 volt Lincoln has served me well for 18 years now, both with flux-core and solid wire/gas...
Offline KeithTurk
Re: MIG or TIG?
« Reply #11 on: October 14, 2010, 05:33:08 PM »
I've got a SP135 Lincoln as well as a Lincoln square wave Tig....  I'd go Mig first as well... thought I'd take the Class in Tig cause it's going to be a much steeper learning curve....
I've had both 220 and 110 Mig's and far prefer the 110 simply because with a fair extension cord I can go anywhere...
K
Re: MIG or TIG?
« Reply #12 on: October 14, 2010, 08:01:26 PM »
You should have heard my buddy #$%*ing about his 110v Miller this afternoon; he was ready to pitch it down a mine shaft!!!
My Lincoln is also an SP135. I saw recently Lincoln has a very reasonably priced spool gun, for welding aluminum, that will work on our machines.
Offline KeithTurk
Re: MIG or TIG?
« Reply #13 on: October 15, 2010, 02:47:54 AM »
Lincoln also has a push set up for a Mig gun..simply change the liner to a .045 liner and push .030 Aluminum wire through it with Argon...
Downside is, like the spool gun... it takes a bunch of practice and set up time...  but once your doing it every day it's pretty good...
The Tig is the poo poo for Aluminum work... it's just very controllable...
K
ZanderJay
Re: MIG or TIG?
« Reply #14 on: October 17, 2010, 09:29:31 PM »
If we are going to choose what the best welder was, we might to think about the feature and the purposes why we need it. You can determine the function of the welder. For me, I having use the MIG welder and I assume that this welder, I can used every single day I weld.
Offline Boner
Re: MIG or TIG?
« Reply #15 on: October 17, 2010, 10:04:26 PM »
Maybe Zander can clear something up for me with his course instructor, when I took my apprenticeship cough cough a few years ago :) mig was quite new.
At that time my welding instuctor told me Mig with or without gas was a very porous weld and therefore very weak and not to be used for sturctural welds. Stick is a farmers weld but is much stronger and Tig is the cats ass.
Thanks
Bones
1971 Honda 750
1950/64 Norton 500 single in Featherbed
1964 Norton 650ss
1974 Trident
1968 500 Trumpet
1971 Commando
3 x Suzy T20's
1997 Triumph Trophy
Re: MIG or TIG?
« Reply #16 on: October 18, 2010, 06:28:24 PM »
tig is for building the bike
mig is for building the trailer
Re: MIG or TIG?
« Reply #17 on: October 18, 2010, 08:15:14 PM »
What welding process did Honda use to weld the CB frames?? My guess is MIG. ;)
Re: MIG or TIG?
« Reply #18 on: October 19, 2010, 12:31:02 AM »
From the appearance I'd say mig
Offline memet14
Re: MIG or TIG?
« Reply #19 on: January 19, 2012, 08:03:31 PM »
MIG and TIG are both shielded arc welding applications, they are very different from one another. MIG welds are created with a consumable electrode, while TIG welds are created with a non-consumable electrode. TIG welding typically includes filler metal as well. That's what I got in my research. I've been using TIG in my welding activities. This is the best weld for me.
Offline jgmmgood
  • You don't need proof when ya got instinct.
Re: MIG or TIG?
« Reply #20 on: January 20, 2012, 07:38:41 AM »
Personally, I wouldnt trust MIG on anything that needs to be dependable, IE:  frame joints, etc.  Stick welding (also known as SMAW or shielded metal arc welding) is very sound if the processes are understood and care is taken in preparation.
TIG welding is extremely strong as well - again, if the process is understood.
Welding is a bit like painting in the fact that proper preparation is a key point.  Also key is knowing what makes a weld "bad" and trying to account for it.
For example, on any type of weld, porosity is the enemy as well as contamination.
Porosity can be caused by may factors such as moisture, incorrect gas flow, wrong voltage/amperage, wrong angle of electrode, etc.
Contaminiation can also be very detrimental and can be caused from "contaminants" such as ill-prepared surfaces, dirty filler material, dirty electrode (TIG), etc.  Grinding starts and stops is also a key to ensuring a good weld.
Bottom line is that good welding takes practice and understanding what is happening will help ensure a dependable weld.
At least that is what I was taught in the nuclear plant welding school back in the Navy days.
Lookin' is for free, Touchin's gonna cost ya sumthin - Chaz Michael Michaels.
Re: MIG or TIG?
« Reply #21 on: January 20, 2012, 08:54:03 AM »
Learn to jog before you run... I doubt they would even bother to sign you up for TIG class if you have no prior experience..
 ..hey..what the heck happened to Heli-arc......????... JK..
MIG or TIG?
« Reply #22 on: January 20, 2012, 09:35:06 AM »
There is nothing wrong with Mig for structural welding - if you know how. I saw Mig welded valves for nuclear power stations and the following X ray only confirmed the quality of the weld - and the safety koeficient for that job was much higher than motorcycle frame.
But home owner who just got a HF buzz box should not attempt to weld anything important:)
« Last Edit: January 20, 2012, 09:37:02 AM by 70CB750 »
Re: MIG or TIG?
« Reply #23 on: January 20, 2012, 10:23:58 AM »
Heli-arc is tig, they just stopped using helium for a shielding gas. Hence the name change.
Re: MIG or TIG?
« Reply #24 on: January 20, 2012, 02:45:04 PM »
I wouldn't be fussed about MIG welding for motorcycle frames, Ducati MIG welded their beautiful steel "Trellis" frames for 30-odd years and I haven't heard of one disassembling itself yet? Cheers, Terry. ;D
