Author Topic: rust removal  (Read 6834 times)
rust removal
« on: November 05, 2010, 10:44:34 PM »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: rust removal
« Reply #1 on: November 05, 2010, 11:29:01 PM »
And you can pour it out in the yard when your done :)
Re: rust removal
« Reply #2 on: November 05, 2010, 11:37:20 PM »
i like mollasses about 50/50 with water,soak steel for say a week and it comes out like it was just made,use it over and over,pour it on the garden if you want,smells good,my wife came out once when i was using it and asked have you split beer everywhere?its a mans world.i put some pictures of cruddy car brake discs in the tricks and tips section,anything treated with this stuff will flash rust instantly so use a prep acid afterwards.
« Last Edit: November 05, 2010, 11:39:44 PM by dave500 »
Offline lone*X
Re: rust removal
« Reply #3 on: November 06, 2010, 09:44:23 AM »
Both vinegar and molasses work and are non toxic and bio degradable.  In my opinion vinegar wins for the following reasons:  It is a lot cheaper, it works faster, isn't sticky therefore cleanup is easier, the used liquid can be used as a spot weed killer, and when you do pour it out behind the shop it doesn't attract ants.
Vinegar rust removal was a tech feature on Spikes TV's Trucks series a couple of years back but I have used it and seen it used since I was a kid (too many years to mention).
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Prospect
Re: rust removal
« Reply #4 on: November 06, 2010, 03:40:44 PM »
I wonder if this would work on removing rust from inside a tank.  I've tried electrolysis but couldn't get everything off.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: rust removal
« Reply #5 on: November 06, 2010, 04:14:50 PM »
Just bought out the local grocery store ;D
Will try this on some rusty bits from my GS1100E project today.
Offline gnarlycharlie4u
  • Far from being an
Re: rust removal
« Reply #6 on: November 06, 2010, 11:48:22 PM »
Thanks for the tip. I can vouch for this method, it works well. Not the best but still really well.
A couple other options:
Electrolysis
Coke or (even better) Phosphoric acid
Offline old76cr
Re: rust removal
« Reply #7 on: November 11, 2010, 03:10:16 PM »
This is why I love this forum! Bought a gallon of pickling vinegar. This has 7% versus 5% acid for table vinegar. Shock was sitting overnight and then I just took a brass brush to it for about 5 minutes. Only problem is ... I really want some french fries...
cb750 k5        76 Husqvarna 250cr                                                       77 Can-Am 175   1973 honda SL125
Offline SOHC Digger
  • I'm not an
Re: rust removal
« Reply #8 on: November 11, 2010, 03:14:37 PM »
Get Prep-N-Etch from the paint department at Home Depot!  I just used it on my gas tank and it did an amazing job!!!  I used about a 50/50 mix with water and let it set for 48 hours.
« Last Edit: November 11, 2010, 03:17:49 PM by SOHC Digger »
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: rust removal
« Reply #9 on: November 11, 2010, 03:55:01 PM »
Electrolysis
Careful with the plain phosphoric acid (rust remover), it will flash rust. I think the prep and etch mentioned above is the ticket.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline SOHC Digger
  • I'm not an
Re: rust removal
« Reply #10 on: November 11, 2010, 04:00:34 PM »
Electrolysis
The prep-n-etch actually advertises that it actually leaves a layer of rust inhibitor behind.  I had no flash rusting when I did my tank.
  • Far from being an
Re: rust removal
« Reply #11 on: November 12, 2010, 06:31:36 AM »
YESSSSSSSSSSSS!!!! I've been looking for phosporic acid FOREVER!!!
Ideally I want to make my own custom solutions (for different levels/processes) of removal but I have been COMPLETELY unable to procure any more concentration.
In other words I can't get it from school and can't order it through the pharmacy.
This however sounds like a much better solution and I also don't have to swirl a 1% gas/oil in the tank.
Thanks!
Edit:
I wonder if the vinegar has any negative effects on the bushings or seals...
« Last Edit: November 12, 2010, 06:35:09 AM by gnarlycharlie4u »
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: rust removal
« Reply #12 on: November 12, 2010, 08:31:52 AM »
Electrolysis
Experience is something you get, right after you need it!  ;D
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Rio_CB750
Re: rust removal
« Reply #13 on: November 12, 2010, 08:54:56 AM »
I love to use electrolysis, worked wonders for my gas tank and I do parts here and there, also can just pour it into the grass.
http://www.rowand.net/shop/Tools/Electrolysis.htm
1972 CB750 - Briar Brown - stock
1972 CB750 - Rust - currently a basketcase
  • Far from being an
Re: rust removal
« Reply #14 on: November 12, 2010, 09:35:53 AM »
That's a great tutorial. I had links to some good ones too but I just can't find them.
I'm glad he mentions NOT to use stainless steel as the anode because it produces (toxic) hexavalent chromium.
What few people realize though is that resistance is directly affected by the distance between cathode and anode (+ and - connection).
Therefore the closer you put the re-bar (or whatever sacrificial anode material) to the item having the rust removed, the more effective / faster the process will be.
Re: rust removal
« Reply #15 on: November 12, 2010, 05:49:25 PM »
ive used this stuff
http://www.kbs-coatings.com.au/KBS-RustBlast_p_9.html
it also comes as part of their fuel tank sealer kit,i used this stuff on a bare metaled tank and it works as advertised.yeah lonex i expected bees and ants to go for mollasses but it didnt happen,had a few kamikazi moths though.
« Last Edit: November 12, 2010, 05:52:23 PM by dave500 »
Offline fmctm1sw
Re: rust removal
« Reply #16 on: November 12, 2010, 09:18:55 PM »
Lots of info like this in the tank cleaning threads.  Toilet bowl cleaner is another alternative.  Noe, I'll sit back and wait for the "boiling lemon juice contingent."
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
Re: rust removal
« Reply #17 on: November 13, 2010, 01:00:46 AM »
DeOx-C - Absolute magic stuff. Bio friendly and can be disposed of down the drain. Safe on Chrome - it was the only thing I would use on the 750 frear fender I got which had slight rust on the underside. There is also a Gel version Try it you will be amazed!
Cheers
Ash
http://www.bilthamber.com/deoxcbuy.php
http://www.agriemach.com/product_info.php?cPath=94&products_id=1062
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Re: rust removal
« Reply #18 on: November 13, 2010, 04:41:21 AM »
Doesn't electrolysis create Hydrogen gas? BOOM!  ;D
  • Far from being an
Re: rust removal
« Reply #19 on: November 13, 2010, 07:29:46 AM »
haha yea. but u don't do it indoors. or you have a candle lit to burn off the hydrogen.
