Author Topic: 1972 CB750k Semi Restore - Indiana  (Read 30078 times)
Offline tweakin
  • tear down
Re: 1972 CB750k Semi Restore - Indiana
« Reply #75 on: December 29, 2010, 05:36:30 AM »
Off to a great start and looking good.
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #76 on: December 29, 2010, 05:38:26 AM »
Rear sprocket looks fantastic!  The whole thing looks great, but for some reason, I love that rear sprocket....
« Last Edit: December 29, 2010, 05:40:57 AM by Nortstudio »
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline tango911
« Reply #77 on: December 31, 2010, 06:58:02 AM »
arg, did i mention i hate cleaning a dirty engine.   I guess ive made progress.   I think im going to strap this engine to my moto rack and take it to the car wash,  use some degreaser and power wash it.  this takes for ever in my garage with a brush and mineral spirits.  I hate to use to use anything strong smelling in my garage.   Im getting ready to build a new house and will be building an external garage, cant wait.
« Last Edit: December 31, 2010, 07:00:19 AM by tango911 »
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
« Reply #78 on: December 31, 2010, 07:03:40 AM »
That engine looks as though it had never been cleaned!
Happy New Year!!
Offline cafe550
  • 74 cb550four
« Reply #79 on: December 31, 2010, 07:03:59 AM »
great work keep it up
I HAVE THE SOHC4 SICKNESS!!!
Offline tango911
« Reply #80 on: January 03, 2011, 04:21:03 PM »
After calling around for quotes to paint my tank and side cover ive decided im def going to rattle it myself.  No way im spending $400-600 on a tank and side cover paint job when im doing a full but low budget restore.
So i started sanding..............and after a little stripper, brushing and sanding its getting there.  I have a couple of very small dents to get out. but all in all the tank is good.
QUESTION:  do i kreem the tank before I paint or after?  Seems as if i should do it now as to not mess up the paint job.
« Last Edit: January 03, 2011, 04:28:47 PM by tango911 »
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Brown Bomber
« Reply #81 on: January 03, 2011, 05:14:57 PM »
Yep, I'd line the tank before painting. I've heard the POR15 is better than the Kreem. Also, I'd get a quote from a radiator shop before trying it myself.
You might want to take the rattle can a step farther, and get an aerosol kit from a paint shop. They can mix up good quality paint for you, that you use in an aerosol sprayer. A little trickier to apply, but harder than rattle can paint. (Extra hardener in the clear coat around the gas cap is a safe bet too.)
Allen
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Hinomaru
« Reply #82 on: January 03, 2011, 06:55:34 PM »
Allen
+1 on the above post  ;)
I've used House of Kolor in the rattle can with good results, here's is an example:
http://stores.ebay.com/Stevensons-Paint-and-Supply/House-of-Kolor-Spray-Cans-/_i.html?_fsub=1521397018&_sid=43860718&_trksid=p4634.c0.m322
Offline englishwheeler
« Reply #83 on: January 03, 2011, 07:25:21 PM »
Nice bike! Great to see another Indy guy here!
« Reply #84 on: January 03, 2011, 08:00:49 PM »
+1 on letting the radiator shop line it.
I found a guy that will paint my tank & sidecovers for $150.
And maybe cheaper if I paint it Blue, he has that paint leftover from painting a 69 Chevelle.
Nice job stripping the tank!
Offline tango911
« Reply #85 on: January 04, 2011, 04:57:36 AM »
Allen
nice link i like some of those colors!!
thanks English -  where are you in indy, im brownsburg.
thanks Stev-0
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #86 on: January 10, 2011, 02:24:29 PM »
got the front wheel on with the new tire, now for the rear.   The rim is original, i bought new spokes from cb750supply. Installed new bearings and cleaned up the hub.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline cafe550
  • 74 cb550four
« Reply #87 on: January 10, 2011, 04:45:19 PM »
looks nice what kind of rubber did you get?
« Reply #88 on: January 10, 2011, 04:49:25 PM »
Looks like a Spitfire.  And looks great, Tango!
Offline tango911
« Reply #89 on: January 10, 2011, 05:07:18 PM »
Stev-O called it.
spitfires
just got the back tire on, prob photo it tomorrow or tonight.
CURRENT STABLE:
K2 (project)
2006 CRF250R
« Reply #90 on: January 10, 2011, 05:10:45 PM »
Stev-O called it.
spitfires
Same as what I bought for the 550. Can't beat 'em for the price.
Offline cafe550
  • 74 cb550four
« Reply #91 on: January 10, 2011, 07:33:29 PM »
i got a spitfire on the front of mine but i need a rear
Offline tango911
« Reply #92 on: January 11, 2011, 05:31:12 PM »
rear wheel/tire on, brakes working great,  threw the seat and tank and frankencover on :P just for some motivational pics.   id say a few more weeks and it will be very close to done if i dont hit any snaggs.  fingers crossed.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #93 on: January 13, 2011, 08:06:01 PM »
Ok guys , i did some wiring and have some questions.  Below are some photos. Im starting to get a grip on the electrical.
Im using a K3 harness from cb750supply.com
1st pic is at the coils,  pretty sure the coil wires are connected correctly, the black/white from each coil connect to the same black/white, and the yellow and blue to its matching wire that go to the points. The left 2 wires go to the horn.
2nd pic,  the 2 wires on the left   green/yellow and black, go to the front brake switch.  right?
3rd pic is the battery box area, the 2 connectors left over are (Red connector) Engine Safety Unit and the (white connector) 3 fuse, fuse box for the Headlight, main and tail lights.
4th pic, the left over wires are grey, green and black,  which i believe to be for the turn signal relay.
Hondaman quote:  GREEN = (-) or "G" terminal, the BLACK to the (+) terminal, and the grey to the "F" terminal
5th pic, rear lighting,  had some extra wiring so i tucked it way gently in the lil pocket under the seat, hope thats ok. I know the thick greet should go on the bottom seat latch bolt but this bolt goes directly to the frame so i thot it would be ok.  Im not going for a WIN at any show, just nice low budget clean K2 750 :)
Last pic,  oh cant wait to get all up in the hub YO!!!
Thanks for watchin..........stay tuned for the bondo and rattle can job coming next :P
CURRENT STABLE:
K2 (project)
2006 CRF250R
« Reply #94 on: January 13, 2011, 08:19:59 PM »
Dang, those wires look good. You want to come clean up that bowl of spaghetti under my headlight?
        Vito Corleone
Offline tango911
« Reply #95 on: January 14, 2011, 06:00:19 AM »
well it helps when you start off with a new harness :P  $76 www.cb750supply.com
the k3 has alot more to it than the k2 or k1 harness.  Ill prob be getting the hondaman relay for the headlight and key.
CURRENT STABLE:
K2 (project)
2006 CRF250R
« Reply #96 on: January 14, 2011, 06:05:08 AM »
Of the 3 green, black, and grey, I think you'll find the green female is homeless.
Your wiring routing looks more reasonable than mine. The green ground wire may go where you have it. Mine I put on the lower seat latch bolt but that may not be right. I'll have to revisit my routing next shopday.
That oval cutout in the frame is likely there for a reason.
« Last Edit: January 14, 2011, 06:07:12 AM by MCRider »
« Reply #97 on: January 14, 2011, 06:29:09 AM »
To reduce weight maybe? That cutout is open on mine and the wires feed under like yours Ron, but the wires could feed through the oval without obstructing anything. The rubber feet that support the saddle rest on either side of the oval.
        Vito Corleone
Offline tango911
« Reply #98 on: January 14, 2011, 06:37:49 AM »
MC your right about the 3 wires,  you can use a 2 prong relay for the turnsigals or a 3 prong from my quick research.
I think i will run the tail wires like you under the cutout, it does look better. Your bike looks nice, MC, i hope to see it in person this spring. Some day ill do a nice restore on one of these now that i know kind of what im doing.
 just got a caliper for $15,  needs painted and maybe a rebuild kit, but we'll see when i get to it.
getting so close. once the wiring is finished and its all tested and working, ill get it fired up. then move on to the painting.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline going4speed
« Reply #99 on: January 14, 2011, 06:42:16 AM »
I would recommend the wires going into the small recess be placed in some sort of loom to prevent chaffing.
Source:
8 years of engineering experience including Caterpillar heavy.
