Author Topic: J.Webster Designs Phase 2 build....project "SHINOBI".... (Updated 04/19/2012)  (Read 37805 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
I have heard good things about the auto set... It is definitely not perfect, but pretty dang close from what i hear.
Another selling point on the the 211 was that it has the MVP system. i can weld off of 220V or 110V... very nice feature. Obviously you loose duty cycle and material thickness, but it is nice to be able to have the option.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline cdoggy81
so it can be always be run off your 220v dryer outlet but then plugged into your friends 110v when he needs to borrow it... :)
I have a really odd feeling that your trying to hint at something chris.... ;D
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline cdoggy81
I have no idea what you are talking about man............
Offline 23tbucket
Midnight: Nice to see you back at it again. You are getting a real nice selection of toys for sure. I'm looking forward to when you start setting up and tuning the Microsquirt. My project is in a "holding pattern" for a bit...(ignition meltdown !!), and I was getting the tuning so nice too!! #$%* happens!! Sitting at a laptop and programming an engine is just "simply amazing."
Take care; Clifford
23T... I am excited to get to that point as well... I am VERY close to starting...
I hear you on the sitting at a laptop tuning being amazing... The first time the computer communicated with the bike... I was in disbelief...  a laptop communicating from 2005 communicating with a motorcycle from the late 70's... its ridiculous!
VISIT OUR WEBSITE!
Facebook:
Instagram:
posted some stuff for sale in the for sale section...
http://forums.sohc4.net/index.php?topic=87230.0
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
I've been following this thread and have gone back and read 23bucket's.  Question - which MAP are you using, and were did you locate it?
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Very Cool Thread!
are you talking about the MAP sensor? or the base map for tuning?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
The MAP sensor.  I've been going through the list of the extra stuff required for EFI (MAP, CHT, ITA...).  Trying to get an idea were everything needs to be located.
77 CB550 Cafe build
The MAP sensor is a GM 3-bar MAP sensor. It will be tapped into the throttle bodies I have it mounted to the spine of the frame under the tank.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline brah pitt
do you still have the stuff i bought way back?
Any updates.?
Retro, I will be updating in the next couple of days.
Brah, PM sent
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Red67lemans326
Midnight!....i found you!
I'll be calling you in the near future so you can help me out with a couple things...i want you there when i start it for the first time.
My build is so...damn...close.
-Blaine
whats up blaine!!! bought time i saw you on here!
VISIT OUR WEBSITE!
Facebook:
Instagram:
OK.... SO.... It has been a while since I have updated this... But work and life have gotten a little busy lately...
Put in a bid for a house... Hoping to hear back on that soon...Then moving and properly building out the garage.
Getting married in October... been doing wedding stuff with the fiancee..
Without further delay... Some updates...
Got the fuel rail built up. It needs some cleaning up and then i think i am going to powder coat it black.
I got the Throttle bodies, fuel rail, fuel pressure regulator, fuel pump, etc... all mounted and completely plumbed. I have not pressure tested yet... I am kinda nervous about that one. But, I think it will be fine. All of the fuel lines are tucked away nicely and hide themselves pretty well. All of the wiring for the microsquirt is hidden under the fuel tank. If a person wasn't paying attention really well, the probably wouldn't even notice that it has been fuel injected, especially after I get the K&N pods on them... Which is what I was shooting for. (modification and modernization without killing the looks of the bike)
The fuel pressure regulator location worked out just as I had hoped... The fuel pressure gauge peaks out just beneath the left hand side cover for easy viewing access. It looks like it is right above the chain in the picture, but it is about an inch to an inch and a half behind the chain. plenty of clearance. It is also an oil filled pressure gauge so it should stay pretty steady and not damage as easily.
I Finally got enough cajones to cut the steering stem on the lathe... and it came out GREAT...
I started with this....
And ended up with this....
Obviously I still need to add the threads, tapers and need to part the stem from the rest of the stock. I was also able to gain the extra length that I needed due to the length differences between the steering heads on a CB750 and a CBR1000RR.... The below picture is with the bottom machined surfaces lined up... ( if you reference the above picture, you can see the difference)
So, all in all, I am getting pretty close to having the front end bolted on, and the fuel injection to a starting point. I wish there were more hours in a day so that I could work to pay the bills, then come home and enjoy working on my motorcycle...
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Syscrush
  • Sold. :(
Wow.  Lookin' great, man!
Thanks sys!
VISIT OUR WEBSITE!
Facebook:
Instagram:
well, got more done on the steering stem... Threads are cut and the stem is parted to length... just need to do some tapering so that the stem and bearings press in nice and easy. Checked the fit of the top triple on the new stem and my stem actually has a better fit than the stock triple... I am also going to have my logo engraved onto the top of the steering stem... should turn out pretty cool.
More updates to come!!!
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
very nice work, looks like you've got a handle on the lath.
77 CB550 Cafe build
thank you sir... I am still learning...dont think i will ever stop learning.
I am currently trying to figure out how to drill a hole in the fuel tank for my return line without getting a crap ton of metal chips in the tank... any suggestions?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
I hear when you stop learning, its called dead. ;) :)
About the only thing I can think of would be one of those small car vacs.  Feed the hose in close, and try to suck up as much as possible as its being made.
77 CB550 Cafe build
Offline paulh1282
Ok so after getting a late start on seeing this thread, i am completely jealous...looks great. I have also determined that i need to do a whole lot more research so that i can someday do something like this.
oh yeah i also need your wallet  ;) lol
