Author Topic: Callin all Masters - 3 ohm v.s 5 ohm coils  (Read 19995 times)
Offline RpBet
Re: Callin all Masters - 3 ohm v.s 5 ohm coils
« Reply #25 on: February 11, 2011, 08:27:06 AM »
I love this site! You guys are awesome. My questions have been answered plus some ;D.
Thanks to all. I will check out Hondamans set up. Fastbroshi really I appreciate the info and tips.
I have decided to go with 3 ohms, manly because of Hondamans information regarding late model 750's. And they don't get any older than my SOHC. I know I said I wanted "as reliable as possible" however, I was looking to advance my system slightly with the dyna ignition. Plus I personally am not a fan of the points system.
Thanks again to all!!!!!!
78 cb750 Cafe'
Offline Skunk Stripe
« Reply #26 on: February 11, 2011, 08:34:22 AM »
I will see if I find anything for those denso plugs.
Offline Roach
« Reply #27 on: February 11, 2011, 09:07:58 AM »
RpBet you have a PM
1978 CB550K Cafe Racer
Offline fastbroshi
  • Puppet
« Reply #28 on: February 11, 2011, 12:01:52 PM »
Does that mean I should be gapping the plugs on my K1 at 0.45"?
Sorry,  thought you were the original poster and had the 3 ohm coils.  If you set to that gap with your 5'ers,  I think you may have inconsistent spark.
Just call me Timmaaaaay!!!
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #29 on: February 11, 2011, 01:12:14 PM »
i wonder what the proper gap would be with 3 ohm coils, iridium plugs and a Hondaman box??
« Reply #30 on: February 11, 2011, 02:04:16 PM »
I think it is something to test but on most cars with their high energy sparks that top 60,000 volts, it seems to average around .045.
I would probably not go over .035 myself but who knows, maybe .040 works.
Offline Kong
« Reply #31 on: February 11, 2011, 04:17:35 PM »
I believe Dyna rates both the 5- and 3-Ohm coils at 35,000 volts - I know, it doesn't make any sense to me either.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #32 on: February 11, 2011, 10:49:31 PM »
set the gap standard,but file the earth electrode back so it exposes about 50%or less of the centre electrode,this is an old hot rod trick and costs nothing.
Sounds interesting. Makes sense. Any minuses?
Does any of you guys have experience with Denso's new Twin Tip plugs? They're much cheaper.
place a hacksaw blade or similar to protect the centre electrode as you file, and file nice and square with finesse,de burr and blow it out with compressed air after,itll expose a little more spark thats otherwise shrouded,im sure some older hot rod fellas will know this old one?it works best at cruise and light throttle,dont expect to be suddenly doing wheel stands,im not one for twin electrodes,the standard singles do as good,i like denso with the groove in the earth electrode.
  • I'm back
« Reply #33 on: February 12, 2011, 12:12:04 AM »
No, no, that twin tip spark plug doesn't have an extra electrode. It has a tip of the precious stuff soldered on the earth electrode to save iridium.
Offline Kong
« Reply #34 on: February 12, 2011, 05:19:02 AM »
This discussion should be moved to the humor section.  Split-fire plugs?  You gotta be kiddin, right?
1978 Honda CB550K
1977 Honda CB550K
Offline btriepke
« Reply #35 on: May 28, 2013, 05:05:50 AM »
I know i'm pulling up an old thread here, but i'm a bit confused. I have the dyna ign with "green" dyna coils. I assume 3ohm? The only marking on the coils are "12v 8-84" Should i have NGK Spark Plug Cap - XD05F - on the end of the wires, or just a regular spark plug wire? it says those NGK's are 5K Ohm Resistance???? i'm using a modern reg/rec unit if it makes a difference!  thanks   Trip
« Last Edit: May 28, 2013, 06:14:36 AM by btriepke »
« Reply #36 on: May 28, 2013, 01:34:23 PM »
yep use the 5kohm.
