Author Topic: Add oil to top end before starting for the first time?  (Read 1148 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 29, 2011, 07:44:15 AM »
Well, not the first time, but the first time in a long time. Finally got my replacement motor cleaned up as much as I'm willing to, and am ready to chuck it back on the frame and fire it up. I've read about putting some oil onto the top end via the tappet covers and into the cylinders via the spark plug holes prior to starting old engines. Is this advisable? And if so, how much do I add to the top end and to the cylinders?
Offline boatsdickson
  • 1978 836 K8
Re: Add oil to top end before starting for the first time?
« Reply #1 on: March 29, 2011, 08:04:57 AM »
Good question, but im not here with the answer. I wondered the same when i got mine back into the frame. I put a healthy squirt in each of the intake tappet covers and hoped it would drain down. Probably 1/8th of a cup in each hole. Overkill, i dont know. Maybe one with more knowledge than me will chime in. 8)
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
« Reply #2 on: March 29, 2011, 08:49:22 AM »
It won't hurt anything.Dump in a 1/2 qt or so between both sides on the centerstand.
« Reply #3 on: March 29, 2011, 09:19:26 AM »
i alvays do this..take that battery drill..or turn back weel to turn the engine
« Last Edit: March 29, 2011, 09:21:19 AM by strynboen »
Offline Whaleman
« Reply #4 on: March 29, 2011, 09:28:47 AM »
More important is to make sure you get oil pressure before starting. Squirting oil in will not get to the cam bearings where you need it. Not even mentioning the crank and rod bearings. Kick or spin until you see oil in the top end. If you see oil in the top end being pumped you know you got the crank and rods also. Dan
« Reply #5 on: March 29, 2011, 10:04:03 AM »
I always add a quart of oil to the top end through #1 tappet cover. Then check with oil pressure guage when fire it up - should go up almost instantly.
Offline Motoguy23
« Reply #6 on: March 29, 2011, 10:43:41 AM »
I just add a dab of Lubriplate No.105 motor assembly grease to the cam bearings and lobes and then fill the little wells under the cam with oil.  The grease should take care of it in until the oil gets there.  It also dissolves in oil so you don't have to worry about it clogging up the filter or anything like that.
All glory to the hypno-toad.
« Reply #7 on: March 29, 2011, 02:30:24 PM »
You should know Andy as you've done it enough times. ;)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #8 on: March 29, 2011, 03:07:22 PM »
If I add a quart to the top end via the tappet covers, how much goes in the oil tank then?
Offline jtb
  • An unlikely
« Reply #9 on: March 29, 2011, 06:38:35 PM »
Add 2 qts to the tank after one in the tappet covers.  Start and run for a few minutes, then stop and check the level.  Add more if necessary.  Sounds like you're coming along pretty good, Tugboat.  Look forward to seeing you in acouple of weeks.
1977 CB750F
1985 V65 Sabre
Offline Ernest T
« Reply #10 on: March 29, 2011, 06:58:37 PM »
That's all you need, the grease is sticky so it'll hang in there until the motor starts and ou get good oil pressure.  I've done that for over 40 years on all kinds of engines.
