Author Topic: Dorothy III - CB750  (Read 327485 times)
Re: Dorothy III - CB750
« Reply #100 on: May 07, 2012, 09:26:01 AM »
Took 211 to Skyline drive and back - 100 miles total. Longest distance so far.
« Reply #101 on: May 15, 2012, 04:07:12 AM »
Yesterday I installed swing arm from 73, it went smoothly, except the right shock bottom bolt gave me some crap.
I deepened grooves in the bushing according to The Book, greased it before installation and pumped it full of grease afterward.
It seems to be tighter, the old arm had a noticeable side movement 5mm or so, but I need to ride it first to verify.
Offline Gurp
  • I'm no.......
  • Once was a...
Re: CB750 made in March, 1970
« Reply #102 on: June 19, 2012, 08:53:32 AM »
Air filter is on.
What kind of air filter is this? where to find one?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #103 on: June 19, 2012, 09:29:56 AM »
My kind:)
http://forums.sohc4.net/index.php?topic=99066.0
You can build one yourself.
But 734 said he will be making something similar for somebody.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #104 on: June 19, 2012, 10:18:28 AM »
Thank You
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #105 on: June 19, 2012, 10:30:15 AM »
Tried to pm 734 but it said member does not exist.. i don't know how to make the search work yet...I'm still a newb here.... Does anyone have a thread on the specifics of making one of these?
Thanks again
Ron and
P.S. sorry to bother you with such trivial questions
« Reply #106 on: June 19, 2012, 10:35:05 AM »
Sorry, doing too many things -754 is the name. He repliex to the cyclex filter thread.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #107 on: June 19, 2012, 10:56:46 AM »
Awesome thanks
Dorothy III - CB750
« Reply #108 on: June 27, 2012, 03:59:21 AM »
The baffle on my second hand Mac kicked the bucket.
I made a new one from piece of pipe - I think it was traffic sign post or something like that.
It works well enough, but it sounds like Nascar - 5 AM start to go to work is bit on the loud side.
Also the front brake locked up, turns out the bracket pin was frozen solid, replaced it with different C bracket and used antiseize this time.
« Last Edit: June 27, 2012, 04:01:41 AM by 70CB750 »
Dorothy III - CB750
« Reply #109 on: June 29, 2012, 04:19:59 AM »
Made and installed SS oil hoses.
« Reply #110 on: June 29, 2012, 04:30:26 AM »
Looking good mate, but what's happened to your air filter? Cheers, Terry. ;D
« Reply #111 on: June 29, 2012, 04:34:45 AM »
Thank you.
The filter got squished somewhat when I was messing with carbs.  I will make and use spacers next time I have it off - just like somebody here (Rigid?) suggested.
« Reply #112 on: June 29, 2012, 06:23:54 AM »
What about a strip of some nice perforated metal sheet between the two "bookends"? ;D
http://arrowmetal.com.au/products/perforated-metal/?gclid=CP7l56jF87ACFcNMpgodCzhwQQ
« Reply #113 on: July 10, 2012, 08:08:29 PM »
Started on a dual disc today, I have all the parts for a long time and it should not be hard.
Photo for the record, i just made a mark for a photo scavenger hunt.
« Reply #114 on: July 10, 2012, 08:09:54 PM »
I had one disc already drilled, duplicating.
« Reply #115 on: July 10, 2012, 08:11:19 PM »
Drilled, that SS disc creates some nasty shavings.
Hot too, especially when they jump in your shoe.
« Reply #116 on: July 10, 2012, 08:12:48 PM »
Assembled wheel, till this moment, it was smooth sailing, from now on, the merde is all over the fan.
« Reply #117 on: July 10, 2012, 08:17:55 PM »
I put the wheel in and the right disc was dragging on the fork.  Left one had some clearance, not much, but the right one was  right smack on the fork.
I measured the triple tree and turns out my bottom is narrower than the top.  When I got her, the top was cracked, I replaced it with a piece from ebay, the bottom stayed original K0 (I believe) and those  two brackets just did not see eye to eye.
Not a biggy, back than I bought the whole tree so I replaced the bottom too and it lined right up.  Of course I spilled bearing balls in the grass and did not find them all, time to order all balls kit, for now, lets go with what I got.
« Reply #118 on: July 10, 2012, 08:20:28 PM »
Bloody L, she looks like Stuka, the dive bomber :(
I measured it at and at the bottom bracket of the tree, the difference is 2.5"
« Reply #119 on: July 10, 2012, 08:23:42 PM »
Here is the reason, the middle pair is the original K0 forks, outside are K3 that I got as a part of rolling frame.   The PO had on it 16" Harley rear, I guess this is hot he lowered the front.
« Reply #120 on: July 10, 2012, 08:29:15 PM »
Not sure what to do, I have forks for C bracket brakes in original length.  I even have one extra C bracket, frozen solid, but that should be fixable, right?
Than I have brackets and brakes and forks from K2/K3 to run nice and pretty dual break setup using T brake brackets.
And on top of that I have forks about 4 inches longer than the K0  >:(
Now what would Jimmy Buffet do?  ;)  I am afraid if I run the short fork in front, she will not behave very friendly and she will feel too small for me - I am 6'2" and 240 pounds.
« Reply #121 on: July 11, 2012, 07:19:37 PM »
Today I kept working on it.  Made spacers to center the front wheel for the dual disc setup.  Installed the wheel and left caliper including brake line Made In Slingshot.
The screw securing the tach drive has to be shortened.
Mocked up right side caliper on long M6 bolts to measure how bug spacers I need for it.
At ten o'clock, mosquitos and darkness made me quit.
I may have to go back to K0 forks/brakes.  Baking the frozen C caliper in the oven now to try to loosen it up - yes you guessed it, my wife is traveling  ;D
Offline fastbroshi
  • Puppet
« Reply #122 on: July 11, 2012, 08:17:23 PM »
Keep at it buddy.   It's a test of will to be working outside all the time.
Just call me Timmaaaaay!!!
Dorothy III - CB750
« Reply #123 on: July 17, 2012, 05:11:11 PM »
Double brakes with short forks but she feels good. I had her @ 60 today, repeatedly and she is stable and all.
The trail is still over 4" i may be measuring it wrong.
Dorothy III - CB750
« Reply #124 on: July 17, 2012, 05:13:55 PM »
Two more.
