Author Topic: What's going on with my timing??  (Read 1620 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: August 01, 2011, 08:18:49 AM »
Did a tune up over the weekend.
Did timing with the static method then pulled out the strobe to double check.
At idle:
1-4 are fine: right on the "F" mark.
2-3 are jumping. The "F" bounces back & forth a few degress either way with no real pattern. The engine doesn't sound very smooth. It cleans up a bit if reved but it doesn't go a way completely.
so.... WTH?
(mosly stock 750K3 BTW. stock air box, OEM pipes.)
« Last Edit: August 01, 2011, 08:20:37 AM by grumpy »
Offline geminimotors
Re: What's going on with my timing??
« Reply #1 on: August 01, 2011, 10:02:58 AM »
Funky 2-3 points?
KingCustomCycles.com
« Reply #2 on: August 01, 2011, 10:05:03 AM »
Bad condensors will do that.
Offline grumpy
« Reply #3 on: August 01, 2011, 11:15:40 AM »
Points "should" be good. They're TEC, not very old, just dressed, gapped & cleaned...
Condensors are the same.
But I will try swapping with others...
Offline grumpy
« Reply #4 on: August 01, 2011, 07:06:49 PM »
well, not the condensors. swapped for another set - same issue...
Offline fmctm1sw
« Reply #5 on: August 01, 2011, 07:42:59 PM »
That shaft the points are may be bent.  There is something in the FAQ about it I think.  Use a dial indicator and bend it back straight....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline jahmic
    • 78 750F
Re: Re: What's going on with my timing??
« Reply #6 on: August 01, 2011, 07:52:49 PM »
+1 Sounds like a bent shaft to me. If anybody put a socket and breaker bar on that nut to turn the engine...especially with the spark plugs still installed, there's a good chance that shaft bent. Sadly, it doesn't take much...been there, done that (on an old trail bike years ago).
Offline grumpy
« Reply #7 on: August 01, 2011, 08:06:42 PM »
I thought about it being a bent shaft but it only happens on 2-3.
If it was bent it would also do it on 1-4, no?
« Reply #8 on: August 01, 2011, 08:16:34 PM »
The strobe should be a placid smooth appearance. There is a component of magic to it, so don't dismiss anything. Logic says if it happens to 2-3 it should happen to 1-4, esp about the shaft and the advancer.
A saying I picked up recently (from Click and Clack the Tappet Brothers, I think) "reality often astonishes theory".
My experience has been that the jumping is caused by weak springs on the advancer weights. New advancers are unavailable (Unless David Silvers Spares has them, they seem to come up with odd out of production pieces). Look at the coils of the advancer springs. They should all be laying against each other tight, with no spaces.
Offline jahmic
    • 78 750F
« Reply #9 on: August 01, 2011, 08:28:58 PM »
Not according to this link:
http://forums.sohc4.net/index.php?topic=54028.0
Can't say for sure that's what you're experiencing, but...it's worth looking in to.
« Reply #10 on: August 01, 2011, 08:35:08 PM »
Thanks for the link. As with every "magic" illusion, look deep enough and one can find the secret, per HM.
Offline Skunk Stripe
« Reply #11 on: August 01, 2011, 08:42:28 PM »
I was thinking springs too.
Offline Spanner 1
« Reply #12 on: August 01, 2011, 08:46:03 PM »
Here's why you never want to turn your motor with a socket on the points anvancer 'nut'......... that little shart can bend easily and mess-up the points cam 'trueness' for sure  :(
Offline grumpy
« Reply #13 on: August 01, 2011, 09:00:58 PM »
well, how 'bout that.
I swear I'm just gonna send my bike to HM and have him iron out all the kinks - even the ones I don't yet know I have.
« Last Edit: August 01, 2011, 09:02:42 PM by grumpy »
