Author Topic: im totally crushed :( by cb550 build is now kinda dead in the water  (Read 13536 times)
Re: im totally crushed :( by cb550 build is now kinda dead in the water
« Reply #50 on: September 06, 2011, 10:30:52 PM »
you have to totally dissemble the motor xsmooth to replace the primary chain.
Offline WarwickE36
« Reply #51 on: September 07, 2011, 04:47:29 AM »
Yeah, it requires a lot of work, and little bit of know how Xsmooth. Mostly annoying gasket removal, and remembering what orientation things were sitting in their respective case.  You have to pay atttention to lots of little details....otherwise you just picked yourself a whole bouquet of oopsie daisies.  But a bigger mistake may be not doing it while you have the motor out.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline xsmooth69x
« Reply #52 on: September 07, 2011, 03:05:06 PM »
wow wait a sec so if the chain is loose and sloppy like the video i have to replace it aghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
1975 CB550 (FINISHED?!?!?)
Offline lucky
Re: im totally crushed :( by cb550 build is now dead in the water
« Reply #53 on: September 07, 2011, 03:25:26 PM »
A skilled tig welder could get that back together for well under $100.  No disassembly required.
I agree. And I am a skilled TIG welder.
Certified welding inspector too.
 Do not use JB weld.
Welding is not like glue.
Welding actually fuses the two metals together.
You may have to take the clutch off to make it easier to work on.
« Last Edit: September 07, 2011, 03:27:05 PM by lucky »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #54 on: September 07, 2011, 03:26:24 PM »
If it's really loose like Warwick's, it will eat away at the case into the oil gallery...then you need new cases.
Offline CrankyOldGuy
  • Wish I was a
« Reply #55 on: September 07, 2011, 03:52:27 PM »
Dave or anyone else,
Is there a method to measure the serviceability limits of the 550 primary chain stretch similar to checking the 750K1?
For the 750K1  you take a measurement from the primary chain tensioner bracket to the oil pan mounting flange and check it against an allowable max. dimension.  You also have to do a visual check of the rubber roller for wear, deterioration or damage.
Harry O.
750 K1 Original Owner
Offline Greggo
  • Somebody's
« Reply #56 on: September 07, 2011, 04:02:36 PM »
My original Honda Shop Manual makes no mention of measuring serviceability limits of the primary chain.
Offline xsmooth69x
« Reply #57 on: September 07, 2011, 05:08:51 PM »
sir this is fighting words
Offline Greggo
  • Somebody's
« Reply #58 on: September 07, 2011, 05:26:15 PM »
Does the Clymer mention it?  I'm talking about the 500/4 shop manual.  Not much of a fighting words type of guy myself.
« Reply #59 on: September 07, 2011, 11:17:24 PM »
if its sloppy it needs to be replaced,ive never seen a spec on them.
Offline xsmooth69x
« Reply #60 on: September 08, 2011, 01:35:00 AM »
sorry im an instigator.... i wanted twotired to chime in and drop a bomb .... ow well
« Reply #61 on: September 08, 2011, 03:53:13 AM »
There is no spec in an manual i have (and i have lots) for the 500 or 550 mentioning primary chain play.
Basicaly if you remove the sump pan and feel the gallery if there is a groove worn by the chain it needs replacing!
