Author Topic: 1973 CB750K3 - One Owner Barn Find - 5,310 miles - Final with Pics  (Read 48737 times)
Offline Johnie
Re: 1973 CB750K3 - One Owner Barn Find - 5,310 miles
« Reply #75 on: November 01, 2011, 05:55:16 PM »
Tews...don't have a video camera for that, sorry. If I can work it out with my son to be here I will. But once I am ready to fire it up I don't think I will be able to wait for him to show up with his camera... :D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #76 on: November 02, 2011, 08:32:30 AM »
Seems most every 750 I get the clutch is stuck as they have been sitting so darn long. Never have had to disassemble though,they usually break free for me after a good warm up or two,some fresh oil getting around. On a 71 I did this summer for a guy though I had to tie the clutch handle back for awhile and it finally came around.
  Anxious to hear those words "Fire in the Hole"
Offline Johnie
« Reply #77 on: November 02, 2011, 10:48:33 AM »
Eric...I guess it would not hurt to tie back the clutch handle for a few days just to help it out. Just picked up some no ethanol fuel for the bike. Now waiting for my new petcock, OEM air filter and air box rubbers. Replaced the cracked fuel cap gasket last night. Getting close. This winter will be rebuilding front caliper and master, the fork seals, polishing the fork legs, pack the steering head, new chain, and whatever else I find. Probably new 341's too.
« Last Edit: November 02, 2011, 10:53:35 AM by Johnie »
Oshkosh, WI  USA
Offline Johnie
« Reply #78 on: November 02, 2011, 05:04:55 PM »
Just doing some putzing tonight while I await those parts. Got the fuel lines in place and cleaned the small amount of old fuel from the tank. Put a bit of the no ethanol in to swish it around a little in case there was something I could not see. I was able to get a few pics of the tank interior after the cleaning and hands down this is the cleanest tank I have ever found. A complete contrast to those filthy carbs which were the worst I have ever seen.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #79 on: November 02, 2011, 05:17:17 PM »
WOW! Why do you think it remained that clean? Did the P.O. coat it with something?
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline Johnie
« Reply #80 on: November 02, 2011, 05:34:37 PM »
ZZ I was wondering the same thing? I plan to ask the PO sometime about it. Did not feel like anything in there except that little bit of old smelly varnish color fuel. At least it smelled like old fuel. I wonder if it could have been some kind of coating? If it was fuel then it was put in there prior to ethanol which would explain the no rust on the bottom from no water.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
« Reply #81 on: November 02, 2011, 05:36:47 PM »
 ;D Great luck!!! Looks fantastic!!!  Pretty soon she'll be purrin' like a kitten. Did you check the exhaust for mice?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #82 on: November 02, 2011, 05:41:22 PM »
How did I miss this one?!
Offline zzpete
  • You better get an
« Reply #83 on: November 02, 2011, 05:43:14 PM »
You've must have been sucked into the SANDCAST thread vortex!!!!
Offline Johnie
« Reply #84 on: November 02, 2011, 07:25:14 PM »
ZZ I probably should check for mice. Did not think of that as there was no sign of mice crapola anywhere. But thanks for the reminder.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
« Reply #85 on: November 02, 2011, 07:29:09 PM »
It happened to me ......twice! I have one now that looks like its inhabited! I'll take them off and give em a good cleaning!
Offline MrGardman
  • Northern Indiana
« Reply #86 on: November 02, 2011, 07:36:35 PM »
Wow, the inside of that tank looks as good as new. I agree with you about it being the cleanest you have seen.
Offline Johnie
« Reply #87 on: November 04, 2011, 02:47:56 PM »
Well, I had much success today. I got the new petcock in place, new fuel lines connected, air box rubbers and OEM filter installed, new battery, new plugs, cleaned the points, checked connections, added fuel to the tank, turned on the fuel...good...no leak from the overflow. Time to hit the starter and VROOOOOM. She fired up very nice. The cam chain was very noisey so I took care of that. Let it run to operating temp per Hondaman. Let it cool. Fired it up again and took it out for a gentle break in of 20 miles. Stayed close to home just in case there was a problem. Dang with only 5,310 miles on it she runs like a new bike. Shifting and clutch were excellent. It suprised me how this Mack 4 to 1 sounds a lot like the 341's. I thought it would be much louder. The only problem I had was I knew my low beam was out, but then the high burned out. So here I was out riding this K3 with no headlight (required here), not registered, and the plate I put on is for a 360T which I sold. I thought I was going up the river if I got caught by the cops. Not much riding season left here in WI and it was only 52 today, but the ride was very nice. The other bikes are all put away, but I think I will keep this one ready for a bit. Get a few more miles on it before bringing it into the patio for the winter work on it. Probably won't be much new on this project thread until I get it inside. Then with deer hunting, Thanksgiving, Christmas, New Years and my son getting married Jan. 7th, it does not look like I will get much done until mid January.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
« Reply #88 on: November 04, 2011, 04:21:32 PM »
Nice bike Johnie. Congratulations on YOUR SON getting married! You think you have no time now!!!
 ;D ;D
« Last Edit: November 04, 2011, 07:54:03 PM by zzpete »
Offline Tews19
  • I am no
« Reply #89 on: November 04, 2011, 04:26:51 PM »
Congrats on becoming married soon!!!!!
1970 Honda CB750 survivor.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #90 on: November 04, 2011, 05:09:03 PM »
Guys, read his post! His SON is getting married January 7th...
Congrats Johnnie on getting the bike back from it long hibernation.
Good to have another K3 on the road..... 8)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline tango911
« Reply #91 on: November 04, 2011, 05:10:54 PM »
great score.   i also have one with an original sales receipt, its only a bout 20 bucks off of yours.    $1557.00 and mine was a 72.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Tews19
  • I am no
« Reply #92 on: November 04, 2011, 06:56:33 PM »
LOL I know his son is gettign married.. Thought we add some humor to his great post on having her fire up.
Offline Johnie
« Reply #93 on: November 04, 2011, 07:23:44 PM »
 ;D Yah, if it was me getting married my wife would kill me!!!  :)  She can not wait until I push this beast into the heated patio for winter...
Oshkosh, WI  USA
Offline zzpete
  • You better get an
« Reply #94 on: November 04, 2011, 08:00:34 PM »
OOPS! Sorry Johnie! Anyway I was looking at the pictures, that thing is super clean. Did you ever find out if the P.O. coated the inside of the tank with anything?
Offline Johnie
« Reply #95 on: November 05, 2011, 05:11:48 AM »
ZZ - have not contacted the PO yet. He still has to give me the center stand and some exhaust flanges he has on a work bench. I will find out about the tank at that time. I was able to locate a new OEM Honda diamond for that left side cover so they are ready to go. I found it in Canada at a dealership. I checked it out and it was 18 days from the time I got it home to the time I fired it up. I just did not think there were bikes in this condition still out there. I feel very lucky to have landed this one. Looking forward to getting the 341's on there by spring. I plan to enroll in the "Pipe-A-Month Club" so the expense does not knock my wife off her feet... :D
Oshkosh, WI  USA
« Reply #96 on: November 05, 2011, 05:44:35 AM »
Beautiful work Johnnie and congratulations on getting it running so fast. Very inspirational so thanks for sharing.
All the best
Andy
Offline dhall57
« Reply #97 on: November 05, 2011, 06:55:30 AM »
Johnie, you made the comment to me when I got my KO that I must be living right, well I think you fall in there with me now buddy;) what a super nice K3 and for what you got it for makes it even nicer! Its like it was put away and than 30 some years later you came along and blew the dust off it and a few other minor things and your good to go ;D. I would with out question add to my collection if I could run across a deal like you got on that K3. I agree with you, it's hard to believe a 38 year bike could be in such great shape. Keep pics coming as your progress continues.
dhall
Im sure MM would go for a ride with you on it :) ;) :D
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline bjatwood
  • 1973 CB750-K3
« Reply #98 on: November 05, 2011, 08:16:35 AM »
Pipe a month club does sound like a plan. By spring the collection of pipes would be ready for riding! With some new 341's on that baby, it should be ready for concours judging at Pebble Beach! LOL
Brian
#24193
« Reply #99 on: November 05, 2011, 09:00:03 AM »
 Nice .. sure reminds me of, my 73 CBO 750 I picked up in may 76..still run my green tank/covers on my current ride, but they are looking pretty tired..
