Author Topic: 1973 CB750K3 - One Owner Barn Find - 5,310 miles - Final with Pics  (Read 47782 times)
Online Johnie
Re: 1973 CB750K3 - One Owner Barn Find - 5,310 miles
« Reply #25 on: October 20, 2011, 05:28:26 PM »
It deserves some new bling.   Heck, I'd offer to double your buying price....as is - you wouldn't even have to buy the pipes.  ;D
I hear you green jeans, but you will have to hop in line.  :) Since I started this thread I have had quite a few generous offers. My plan was not to flip it, but restore it this winter. This will be a fun one.
« Last Edit: October 20, 2011, 06:13:59 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Old Scrambler
« Reply #26 on: October 20, 2011, 05:31:57 PM »
Nice Score Johnny...............when you add the 341s we will have matching bikes!  That production is early and the shape of the fins on the front of the head matches your earlier bikes. That changed during the K3 run.  Could be 105 main jets.  Kinda slow around here but does well on Pikes Peak.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline dhall57
« Reply #27 on: October 20, 2011, 05:35:35 PM »
I hear you green jeans, but you will have to hop in line. Since I started this thread I have had quite a few generous offers. My plan was not to flip it, but restore it this winter. This will be a fun one.
Don't sell it!!
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Online Johnie
« Reply #28 on: October 20, 2011, 05:47:39 PM »
Dennis....the build date is 10/72.
Oshkosh, WI  USA
« Reply #29 on: October 20, 2011, 06:10:18 PM »
Same as mine...........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline hoodellyhoo
  • CB350F
« Reply #30 on: October 20, 2011, 07:44:05 PM »
now either you or I need to buy an original K5 so we can line all our bikes up for a picture of all the original-styled cb750's K0-K6 :)
Online Johnie
« Reply #31 on: October 20, 2011, 07:48:18 PM »
That went through my mind. It would be a cool pic of all the early 750's.
Oshkosh, WI  USA
« Reply #32 on: October 21, 2011, 09:00:07 AM »
Nice bike I think you and Dennis should compare serial numbers.
 Ran into a guy this simmer had a KO since new, serial # was 305 higher than one of my motors..
Online Johnie
« Reply #33 on: October 21, 2011, 02:59:17 PM »
Dennis...this K3 has the 110 mains. Success...I was able to break the oil filter bolt free today. Not as bad as some I have seen. What are you guys replacing these bolts with? I have an identical one from a parts bike I may use and should not have a problem knowing they do not need to be so tight. Here are a couple pics taken after giving it a wash.
Oshkosh, WI  USA
« Reply #34 on: October 21, 2011, 04:43:07 PM »
Nice and clean..............better than mine!  Replacement oil-filter bolts are available with a 14mm head........otherwise just look for a clean stock unit.
My motor number is E 2210097
754 (Frank) had a Bucchus Olive Green bike but installed an 836-kit many years ago.
A lady in Fond du Lac gave her son a Green K3 with original pipes about 8 years ago..........I followed him to their service garage business but lost track since.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online Johnie
« Reply #35 on: October 21, 2011, 05:37:32 PM »
My motor is 2210336 which was 239 bikes down the line from old scramblers K3.
« Last Edit: October 22, 2011, 08:10:08 AM by Johnie »
Oshkosh, WI  USA
Offline dhall57
« Reply #36 on: October 23, 2011, 04:43:39 AM »
Johnie and Scrambler, never really thought about it much, but comparing vin#'s and eng#'s on other members bikes is really a good idea especially with your K3's having the same 10/72 build date. Just a little bit of history think about it you two, in October 39 years ago in Japan the K3's your now have in your garages here in the good USA came of the assembly line in Japan only a couple hundred bikes apart. And now both of these 750's are in Wisconsin and the owners are talking to each other over the internet on this forum about these two bikes all these years later. What are the odds of that happening. Things that make you go hmmm ;D
dhall
« Last Edit: October 23, 2011, 05:22:33 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Online Johnie
« Reply #37 on: October 23, 2011, 07:11:23 AM »
dhall...I never thought about it that way. You are correct, after 39 years who would figure this to happen. And without the internet we would never know.
Today I plan to get the old oil out of the K3 and put on a new filter and filter bolt. May pull the carbs too. The tank is very clean with no rust and no gas. The carbs did not fair so good. He left gas in them. I have some clean extra carbs here with 120 mains compared to the 110 mains in this set. I may put those 120 carbs on just to get this fired up before winter. I want to get oil into the motor and through the engine.
Oshkosh, WI  USA
Offline dhall57
« Reply #38 on: October 23, 2011, 07:30:34 AM »
Yeah Johnie get some clean fresh oil in her, that was one of the first things I did also on my KO when I got it back in May. ;D
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Online Johnie
« Reply #39 on: October 23, 2011, 04:51:28 PM »
Got the oil changed and put some in the top end through the valve adjuster caps. Also put a little in each spark plug port. Turned it over a bit to run that fresh oil around. Noted the oil had been changed as I see the oil filter washer next to the spring was gone as most of them are. Replaced that and plan to check compression this week. I would hope it is fine with only 5,310 miles on the bike, but I know weird things happen when they sit for long periods. Appears this was in a dry place during the storage.
Oshkosh, WI  USA
« Reply #40 on: October 23, 2011, 05:48:26 PM »
Hey Johnie. Out of curiosity today when I went for a ride I checked my numbers on a couple of 73's in the shop and took a few pics. My Bacchus Green is pretty far off from yours,build date of 1/73 and engine number 2222680.
   The Flake Orange 73 has a build date of 2/73 with an engine number 2239207.
  Guess I can't hang with you guys  :D
 PS-Still got your Gold K1's sister over here  ;
  Sounds like your close to firing that new one up if you haven,t already.  Enjoy it,sure its going to be fine.      Eric
Online Johnie
« Reply #41 on: October 24, 2011, 09:06:58 AM »
Great pics there Eric. Love looking at your collection! I did a compression check this AM and here are the numbers: #1 = 150. #2 started at 100, then after a bit went to 110, then after a bit went to 120. #3 = 150 and #4 = 160. These were done with a little oil in the cylinders and throttle wide open. That #2 was a weird one starting low and then increasing as I checked the others. Therefore, I am banking that there is a bit of a stuck ring that will free up once I get the bike running. I noted spark on 1&4 points, but no spark on 2&3 points. The carbs are so dirty I plan to remove them today and have at it. Here are a few more pics from today.
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #42 on: October 24, 2011, 10:09:29 AM »
Looks like it is coming along. Are those spark plugs in order from left to right 1-4? In the pic, the 2nd spark plug is missing the metal gasket. Could this cause the compression test to be off on the 2nd cylinder? Maybe the metal gasket is still on the head
1970 Honda CB750 survivor.
Online Johnie
« Reply #43 on: October 24, 2011, 10:15:52 AM »
Good eyes there Tews...I did catch that before the compression check. That plug gasket might have rolled somewhere on the floor as it is not in the plug port. With #2 increasing so fast from 100 to 110 then 120 in a few short minutes, plus the fact the bike has 5,310 miles on it, I am keeping my fingers crossed continues to improve as this motor gets freed up.
Oshkosh, WI  USA
Online Johnie
« Reply #44 on: October 24, 2011, 03:23:48 PM »
OK...another update. This afternoon I took off the carbs and these are the worst I have seen. All needle valves with the exception of one is froze. Have the bowls soaking now. The 110's and the 40's have small BB like globules of old gas on them. The gas that was still in the bowls must have been about 35 cents a gallon then. The air box is like new as is the OEM filter. The air box rubbers are a bit loose. Not sure if I should try to seal them up or buy some new ones. They seem to have shrunk a little. What a labor of love guys... ;)
Oshkosh, WI  USA
Offline smpls70
« Reply #45 on: October 24, 2011, 05:37:17 PM »
Nice barn find Johnie , I have a 10/72 build date as well , just over the border here in MN. , to the basement I go to look at my engine # ;D
ROTHNOTHAGAR !
Online Johnie
« Reply #46 on: October 24, 2011, 06:12:12 PM »
Great...let's see where your 10/72 ended up in the line-up on the way to the USA.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #47 on: October 24, 2011, 06:21:54 PM »
 ;D Nice score Johnie!! Truly a dusty jewel! I bet when you put the carbs back on that mutha will fire right up.
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Online Johnie
« Reply #48 on: October 24, 2011, 06:26:21 PM »
Hey ZZ I am expecting this baby to fire right up...fingers crossed. Everything seems to be in order.
Oshkosh, WI  USA
Offline zzpete
  • You better get an
« Reply #49 on: October 24, 2011, 06:42:51 PM »
When you get one running thats been sitting for a while, its an even better feeling than when you get it out of the barn!!!!
