Author Topic: Air filter, type sandwich  (Read 6704 times)
« on: November 28, 2011, 04:14:45 AM »
Very simple replacement of those pods the bike came with.
The side plates are 1/4" - aluminum, the filter is 6 bucks Purolator from PepBoys.
Pipe nipples I turned from the stem of an old sunbrella, they stick into the filter 2mm to position the paper element.  I turned them to be a press fit, but peened the plate around them on the inside to make sure they stay there.
The rubber connectors are pieces of an old radiator hose - I want to replace them with something better looking eventually, maybe urethan and thinner walled too, but it works like this.
Two bolts hold it together sandwiching the paper element - hence the name - I should have used metric, but didn't have any on hand.
Re: Air filter, type sandwich
« Reply #1 on: November 28, 2011, 04:17:07 AM »
Assembled and installed.
Offline Scott S
« Reply #2 on: November 28, 2011, 04:38:48 AM »
 Now THAT'S ingenuity!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: November 28, 2011, 06:39:48 AM »
A couple spacers inside, on the bolt shanks, would provide the proper tightness on the filter for sealing but not crush it.  I like the look.  I am amazed no one has written you a lengthy prose on how that won't work at all and your engine will seize? Citing issues like; no velocity stacks inside your filter to "distribute the pressure drop evenly and to smooth the incoming air" :-)
« Reply #4 on: November 28, 2011, 07:00:49 AM »
Its early Rig,those comments may still come. Better get my Jiffy Pop next to the microwave just to be ready.     ;)
Offline Dimitri13
  • 1974 CB550K
« Reply #5 on: November 28, 2011, 11:08:05 AM »
Looks nice and all...
But.
But.. But...
THE TURBULENCE!
Offline johnrdupree
« Reply #6 on: November 28, 2011, 12:07:28 PM »
I thought about doing something similar on my 550 but with there just isn't enough room, the down tubes get in the way.
My idea was similar to yours but used 4 of the stock, center intake trumpets (they're straight, the outer two are angled) and .060 aluminum with a rolled edge to match the outline of the filter.  It would have basically been a homemade version of a Henry Abe airbox with a modern filter.  Maybe I should go buy a 750 so I can try it out.
I second the need for spacers on the rods to keep from crushing the filter.  And all that 1/4" aluminum has got to be heavy.  Do you have the assembly supported in some way or is it all just hanging off the carbs?
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
« Reply #7 on: November 28, 2011, 01:16:52 PM »
The spacers are not necessary, the filter element is harder to crush than it seems. As far as the weight and support, I measured the distance filter to frame and keep an eye on it. So far it  holds without a change.
As far as  the Turbulance and air velocity :)  - it uses same jets as pods, I expected rejetting to be necessary, but the power and seat of the pants evaluation is excellent so far.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #8 on: November 28, 2011, 01:22:52 PM »
no velocity stacks inside your filter to "distribute the pressure drop evenly and to smooth the incoming air.
Uh huh, yeah. That. ^
Offline Rgconner
« Reply #9 on: November 28, 2011, 01:50:44 PM »
I recommend Menthols... smooooth.  ;D
1975 CB550K aka "Grease Monkey"
« Reply #10 on: January 01, 2012, 01:59:19 AM »
That looks good mate, well done! This same situation came up a couple of years ago, someone posted a pic of a filter very similar to yours that they'd made, and that was the inspiration for Tintops "anti-pod". How does the paper filter stand up to rain? Cheers, Terry. ;D
72500john
« Reply #11 on: January 01, 2012, 07:34:54 PM »
instead of aluminum make the parts from unobtianium..will be way cooler!
seriously..nice job!!
« Reply #12 on: January 02, 2012, 05:32:19 AM »
Thanks, guys. Technically I could make nipples to connect to carburetors directly, but hole saw and drill press has its precision limits.
In the rain - hmm - never rode it in heavy rain. I think/hope it will do ok.
Offline wedoo2
« Reply #13 on: January 02, 2012, 06:02:58 AM »
I like reading these air box replacement threads.  One of these days I will come across one that will help me get rid of that stupid %@#$ thing on my 550.  The damn things just needs to be about 3 inches shorter.
Some days the sun is too loud.
Offline Mantree
« Reply #14 on: April 11, 2016, 12:16:33 PM »
Just a thought what about covers over the sides so It is not pulling water in the rain.  I have pods and the only time they give me troble is in the rain when the 2 outer filters get wet but I supose you would still get good dry air from the potlrtion under the tank
Sent from my SM-G900V using Tapatalk
« Reply #15 on: April 11, 2016, 06:28:35 PM »
I have gotten good and wet with an old school Henry Abe breadbox with un-oiled UNI foam filter material.  It resulted in no major running issues, just some minor spittin' and sputterin'.
Online Stev-o
« Reply #16 on: April 11, 2016, 08:36:23 PM »
So, whatever happened to the sandwich, Prokop?
« Reply #17 on: April 12, 2016, 12:51:04 AM »
When I had my first K1 I didn't know how wonderful the OEM airbox is, but I still blamed my old round K&N pods every time my bike sputtered in heavy rain, until one night I saw my wet plug leads arcing against my frame. Ooops.......... ;D
Offline enwri
  • So that noise is normal?
« Reply #18 on: April 12, 2016, 01:46:53 AM »
Alright, I'll do it. That actually looks pretty good, tubes have almost the length of the stacks, just missing the bellmouths on the filter side of the plates. The bellmouth does flow much less "turbulently" than a sharp 90 degree edge.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #19 on: April 12, 2016, 03:48:43 AM »
Stev-o:  sandwich is boxed away with Dorothy.  I will probably put it back after I rebuild her.
I may even adapt the sandwich plate to use stock rubber boots.
As far as riding in the rain.  Bringing PZ from Barber I was on US40 and US81 for hours, most of it in rain and Dorothy started to die above 4000 rpms.  It felt like she had no power in higher rpms.  When I finally decided it was the air filter, I poked holes in it with a knife and the problem went away.
But that was really extreme, with heavy traffic around me the air was full of water.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20 on: April 12, 2016, 07:41:29 AM »
Probably best idea since you get the benefit of the stacks, but nice high airflow. Or even some machined stacks (but price goes uuuuuuuuup).
At least we know that this is possible!
« Last Edit: April 12, 2016, 07:43:00 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
